Small screen makes modules overlap
5 Posts 3 Posters 2.2k Views 3 Watching
  • H Offline
    henry56
    I was using a monitor to use MagicMirror at first, then changed to using a 7" screen. This made all my modules overlap and look super clustered. Does anyone know how to fix this? Or would ordering a 10" screen solve the problem?
    M 1 Reply Last reply Aug 7, 2018, 11:26 AM Reply Quote 0
      Mykle1 Project Sponsor Module Developer @henry56
      @henry56
      Try shrinking the modules while MM is running
      Zoom Out = Control and - (That’s a dash/minus sign)
      H 1 Reply Last reply Aug 7, 2018, 11:52 AM Reply Quote 0
        doubleT Module Developer
        The modules usually have fixed pixel widths and heights, so when two modules in one row both have 300 px width and the screen is 800 px wide, there’s 200 px space in between or left and right but when the screen is only 500 px wide, you’ll have at least 100 px overlap (if there’s no space left and right).
        A bigger screen might not help if it has the same resolution (compare 1024 px 15" and 1024 px 19").
        What you’ll probably need to do is (manually) scale down all modules’ sizes in your custom.css. In theory, if all settings were done in rem, you could just change the default font size and be done, but … that’d be too easy. ;)
        • H Offline
          henry56 @Mykle1
          @mykle1 Thanks!
          M 1 Reply Last reply Aug 7, 2018, 11:23 PM Reply Quote 0
            @henry56
            You are welcome, sir. Enjoy your MM experience.
