    MMM-Swipe - Hand gestures
    45 Posts 17 Posters 50.6k Views 16 Watching
      paviro @mochman
      @mochman to use GPIOs without root try exporting them via a shell command within node. The user than only has to be part of the gpio-group‘ :) check my MMM-PIR-Sensor` for an example!
      – The Doctor
        mochman Module Developer @paviro
        @paviro Does that only work with setting pins directly? I am using a helper_node that takes care of all of the pin setting and timing for the sensors. It looks like your code sets pins directly with the exec command. I’m not sure how to do that with the npm usonic functions.
          Mitchfarino Module Developer
          @mochman I’m a complete amateur here mate
          I’ve got this far, but no idea what to do next :(
          Now what?
          I didn’t understand in the readme what it meant by pins etc.
            @Mitchfarino Looks almost all good. I’m not sure if you have your trigger pin hooked up to ground from this picture. The pins in the config are not the actual pin #'s of the header. It uses the GPIO#. I use this picture as a reference.
            RP3 GPIO
            As an example you can see that pin 32 is called GPIO12. If you connected your Trig wire to that and your Echo wire to GPIO16 (physical pin 36). In the config.js you would use :
            echoLeftPin: 12,
            triggerLeftPin: 16,
            and then a similar setup for your other sensor.
            If you are still having issues with the setup, please let me know.
            As a reference point, your red wire is connected to physical pin #2.
              BeLuGe
              @mochman I have a problem when installing the modules. When I enter the module in the config. When I start the Magic Mirror I get the following error message and a white screen.
              Loading config ...
              Loading module helpers ...
              WARNING! Could not load config file. Starting with default configuration. Error found: Error: Module version mismatch. Expected 49, got 48.
              App threw an error during load
                  at Error (native)
                  at process.module.(anonymous function) [as dlopen] (ELECTRON_ASAR.js:167:20)
                  at Object.Module._extensions..node (module.js:568:18)
                  at Object.module.(anonymous function) [as .node] (ELECTRON_ASAR.js:167:20)
                  at Module.load (module.js:458:32)
                  at tryModuleLoad (module.js:417:12)
                  at Function.Module._load (module.js:409:3)
                  at Module.require (module.js:468:17)
                  at require (internal/module.js:20:19)
                  at Object.<anonymous> (/home/pi/MagicMirror/node_modules/mmm-usonic/lib/usonic.js:5:14)
                  at Error (native)
              Launching application.
                @BeLuGe Have you run npm install in the MMM-Swipe folder? Are you running the mirror with sudo? If so would you mind posting your config.js file. Thanks.
                  BeLuGe
                  @mochman Yes I have run npm install in the MMM-Swipe folder. I running the mirror without sudo.
                  Error Message without sudo:
                  Loading config ...
                      at Error (native)
                      at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-Swipe/node_modules/mmm-usonic/lib/usonic.js:5:14)
                      at Error (native)
                  Error Message with sudo:
                  No protocol specified
                  npm ERR! Linux 4.4.19-v7+
                  npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "start"
                  npm ERR! node v6.4.0
                  npm ERR! npm  v3.10.3
                  npm ERR! code ELIFECYCLE
                  npm ERR! magicmirror@2.0.0 start: `electron js/electron.js`
                  npm ERR! Exit status 1
                  npm ERR!
                  npm ERR! Failed at the magicmirror@2.0.0 start script 'electron js/electron.js'.
                  npm ERR! If you do, this is most likely a problem with the magicmirror package,
                  npm ERR! not with npm itself.
                  npm ERR!     electron js/electron.js
                  npm ERR!     npm bugs magicmirror
                  npm ERR! Or if that isn't available, you can get their info via:
                  npm ERR!     npm owner ls magicmirror
                  npm ERR!     /home/pi/MagicMirror/npm-debug.log
                  config.js
                  /* Magic Mirror Config Sample
                   * MIT Licensed.
                  var config = {
                          port: 8080,
                          language: 'de',
                          timeFormat: 24,
                          units: 'metric',
                                          module: 'alert',
                          module: 'motiondetector',
                              timeout: 600000 // time in milliseconds for to switch off the display after last movement is detected.
                          module: 'MMM-Swipe',
                          position: 'bottom_left',    // Doesn't matter after it's setup.  It should be blank.
                                                      // Best results in one of the side regions like: bottom_left
                              echoLeftPin: 24,        //Left Sensor's BCM Numbered Echo pin - REQUIRED
                              triggerLeftPin: 23,     //Left Sensor's BCM Numbered trigger pin - REQUIRED
                              echoRightPin: 26,       //Right Sensor's BCM Numbered Echo pin - REQUIRED
                              triggerRightPin: 25,    //Right Sensor's BCM Numbered trigger pin - REQUIRED
                              useAsButton: false,     //Enable a GPIO output when you "press".
                              buttonPin: 8,
                              verbose: true,
                              calibrate: true
                                          module: 'clock',
                                          position: 'top_left'
                                          module: 'calendar',
                                          header: 'Feiertage',
                                          position: 'top_left',
        symbol: 'calendar-check-o ',
        url: ''
                          module: 'MMM-FRITZ-Box-Callmonitor',
                          position: 'top_right',  // This can be any of the regions. Best results in left or right regions.
                          header: "Letzte Anrufe", // This is optional
                                          module: 'compliments',
                                          position: 'lower_third'
                                          module: 'currentweather',
                                                  locationID: '',  //ID from http://www.openweathermap.org
                                                  appid: ''
                                          module: 'weatherforecast',
                                          header: 'Wettervorhersage',
                                      appid: ''
                                          module: 'newsfeed',
                                          position: 'bottom_bar',
                                                  feeds: [
        title: "N24 News",
        url: "http://feeds.n24.de/n24/homepage.xml"
                                                  showSourceTitle: true,
                                                  showPublishDate: true
                    Mitchfarino Module Developer @mochman
                    @mochman I’m only just back looking at this
                    Any tutorial I find online says I need a breadboard too - is that correct?
                    What pins should put these in? Or where can I find resource on how to do it?0_1472852546333_IMG_20160902_223136.jpg
                      mochman Module Developer @BeLuGe
                      @BeLuGe So I just tried this myself. When I created the module, I was connected to the pi to test. I just tried using SSH to start the program and got the same error you’re getting. Looks like it’s a issue with running a sudo command over SSH, the workaround I found was to run sudo cp ~/.Xauthority /root/ then run DISPLAY=:0 sudo npm start. The problem with this is that everytime you restart your mirror you will need to run the copy command again.
                      @Mitchfarino You don’t need a breadboard. I just used one to test out my configuration. You can hook it up directly to the pi using those wires you have already connected. When I tested out my setup, I used these pins.
                      echoLeftPin: 24,
                      triggerLeftPin: 23,
                      echoRightPin: 26,
                      Remember that those are the GPIO #'s and not the physical pin #.
                        @mochman I have vcc, trig, echo and gnd on my sensor - how do they map to the config you have posted?
                          mochman Module Developer @Mitchfarino
                          @Mitchfarino
                          Your left sensor
                          Vcc goes to pin #2
                          Gnd goes to pin #6
                          Trig goes to physical pin #26 (Which is labeled GPIO 23)
                          Echo goes to physical pin #18 (Which is labeled GPIO 24)
                          Your right sensor
                          Vcc goes to pin #4
                          Gnd goes to pin #9
                          Trig goes to physical pin #22 (Which is labeled GPIO 25)
                          Echo goes to physical pin #37 (Which is labeled GPIO 26)
                          You need both sensors if you want to detect movement.
                            @mochman OK, I’m an idiot!
                            I only have one sensor! Ha
                            Thanks very much for your help, I’m gonna get one ordered then get back on it.
                            Sorry for the daft questions
                              No worries. Yeah the sensor looks like it has 2 detectors on it. I’m pretty sure one is the speaker and the other is the microphone detector.
                                BeLuGe
                                @mochman when I use your workaround i get the following errormessage and a whitescreen:
                                Loading config ...
                                    at Error (native)
                                    at Error (native)
                                  Can you make another config.js file with just the MMM-Swipe module in there? I don’t know what the:
                                  WARNING! Could not load config file. Starting with default configuration. Error found: Error: Module version mismatch. Expected 49, got 48. means.
                                    BeLuGe
                                    @mochman I change the config file to default and add your Module. The same errormessage.
                                      @BeLuGe Try running rm -rf node_modules/ inside the MMM-Swipe folder then running npm install again.
                                        BeLuGe
                                        @mochman I have delete the directory and install the packages with npm install
                                        And I have reinstall the complete Raspberry and install only your module.
                                        The error is still there
                                          I can’t help you then. That was my last option. I don’t receive that error nor do I know what that error means.
                                            bob123bob
                                            @mochman and @BeLuGe can you tell us what are the versions you are using :
                                            Raspbian Jessie or Wheezy, which version of nodes, npm … ?
                                            From where are you running npm start (local, ssh) using sudo or not ?
                                            I have the same issue as @BeLuGe and I would like to debug/understand what’s is the problem.
                                            I already red it could be a nodejs version issue (compiling vs running version)
                                            So guys tell us what are your configuration
                                            Here is mine :
                                            Rpi 3 updated firmware with rpi-update
                                            Raspbian Jessie last version (apt-get update && upgrade && dist-upgrade)
                                            Nodejs last version 6.5.0 ARM version (not sure if it’s 64 bit or 32 bit) from https://nodejs.org
                                            Then install of MM and packages
                                            MM is working fine until I add MMM-Swipe module configuration then got same error message about
                                            Hope we will find the solution …
