MMM-Swipe - Hand gestures
45 Posts 17 Posters 40.1k Views 16 Watching
    paviro Admin @mochman
    @mochman to use GPIOs without root try exporting them via a shell command within node. The user than only has to be part of the gpio-group‘ :) check my MMM-PIR-Sensor` for an example!
    – The Doctor
    M 1 Reply Last reply Jun 4, 2016, 7:26 PM Reply Quote 1
      mochman Module Developer @paviro
      @paviro Does that only work with setting pins directly? I am using a helper_node that takes care of all of the pin setting and timing for the sensors. It looks like your code sets pins directly with the exec command. I’m not sure how to do that with the npm usonic functions.
        Mitchfarino Module Developer
        @mochman I’m a complete amateur here mate
        I’ve got this far, but no idea what to do next :(
        Now what?
        I didn’t understand in the readme what it meant by pins etc.
          @Mitchfarino Looks almost all good. I’m not sure if you have your trigger pin hooked up to ground from this picture. The pins in the config are not the actual pin #'s of the header. It uses the GPIO#. I use this picture as a reference.
          RP3 GPIO
          As an example you can see that pin 32 is called GPIO12. If you connected your Trig wire to that and your Echo wire to GPIO16 (physical pin 36). In the config.js you would use :
          echoLeftPin: 12,
          triggerLeftPin: 16,
          and then a similar setup for your other sensor.
          If you are still having issues with the setup, please let me know.
          As a reference point, your red wire is connected to physical pin #2.
          M 1 Reply Last reply Sep 2, 2016, 9:43 PM Reply Quote 0
            BeLuGe
            @mochman I have a problem when installing the modules. When I enter the module in the config. When I start the Magic Mirror I get the following error message and a white screen.
            Loading config ...
            Loading module helpers ...
            WARNING! Could not load config file. Starting with default configuration. Error found: Error: Module version mismatch. Expected 49, got 48.
            App threw an error during load
                at Error (native)
                at process.module.(anonymous function) [as dlopen] (ELECTRON_ASAR.js:167:20)
                at Object.Module._extensions..node (module.js:568:18)
                at Object.module.(anonymous function) [as .node] (ELECTRON_ASAR.js:167:20)
                at Module.load (module.js:458:32)
                at tryModuleLoad (module.js:417:12)
                at Function.Module._load (module.js:409:3)
                at Module.require (module.js:468:17)
                at require (internal/module.js:20:19)
                at Object.<anonymous> (/home/pi/MagicMirror/node_modules/mmm-usonic/lib/usonic.js:5:14)
                at Error (native)
            Launching application.
              @BeLuGe Have you run npm install in the MMM-Swipe folder? Are you running the mirror with sudo? If so would you mind posting your config.js file. Thanks.
                BeLuGe
                @mochman Yes I have run npm install in the MMM-Swipe folder. I running the mirror without sudo.
                Error Message without sudo:
                Loading config ...
                    at Error (native)
                    at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-Swipe/node_modules/mmm-usonic/lib/usonic.js:5:14)
                    at Error (native)
                Error Message with sudo:
                No protocol specified
                npm ERR! Linux 4.4.19-v7+
                npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "start"
                npm ERR! node v6.4.0
                npm ERR! npm  v3.10.3
                npm ERR! code ELIFECYCLE
                npm ERR! magicmirror@2.0.0 start: `electron js/electron.js`
                npm ERR! Exit status 1
                npm ERR!
                npm ERR! Failed at the magicmirror@2.0.0 start script 'electron js/electron.js'.
                npm ERR! If you do, this is most likely a problem with the magicmirror package,
                npm ERR! not with npm itself.
                npm ERR!     electron js/electron.js
                npm ERR!     npm bugs magicmirror
                npm ERR! Or if that isn't available, you can get their info via:
                npm ERR!     npm owner ls magicmirror
                npm ERR!     /home/pi/MagicMirror/npm-debug.log
                config.js
                /* Magic Mirror Config Sample
                 * MIT Licensed.
                var config = {
                        port: 8080,
                        language: 'de',
                        timeFormat: 24,
                        units: 'metric',
                                        module: 'alert',
                        module: 'motiondetector',
                            timeout: 600000 // time in milliseconds for to switch off the display after last movement is detected.
                        module: 'MMM-Swipe',
                        position: 'bottom_left',    // Doesn't matter after it's setup.  It should be blank.
                                                    // Best results in one of the side regions like: bottom_left
                            echoLeftPin: 24,        //Left Sensor's BCM Numbered Echo pin - REQUIRED
                            triggerLeftPin: 23,     //Left Sensor's BCM Numbered trigger pin - REQUIRED
                            echoRightPin: 26,       //Right Sensor's BCM Numbered Echo pin - REQUIRED
                            triggerRightPin: 25,    //Right Sensor's BCM Numbered trigger pin - REQUIRED
                            useAsButton: false,     //Enable a GPIO output when you "press".
                            buttonPin: 8,
                            verbose: true,
                            calibrate: true
                                        module: 'clock',
                                        position: 'top_left'
                                        module: 'calendar',
                                        header: 'Feiertage',
                                        position: 'top_left',
        symbol: 'calendar-check-o ',
        url: ''
                        module: 'MMM-FRITZ-Box-Callmonitor',
                        position: 'top_right',  // This can be any of the regions. Best results in left or right regions.
                        header: "Letzte Anrufe", // This is optional
                                        module: 'compliments',
                                        position: 'lower_third'
                                        module: 'currentweather',
                                                locationID: '',  //ID from http://www.openweathermap.org
                                                appid: ''
                                        module: 'weatherforecast',
                                        header: 'Wettervorhersage',
                                    appid: ''
                                        module: 'newsfeed',
                                        position: 'bottom_bar',
                                                feeds: [
        title: "N24 News",
        url: "http://feeds.n24.de/n24/homepage.xml"
                                                showSourceTitle: true,
                                                showPublishDate: true
                M 1 Reply Last reply Sep 2, 2016, 11:06 PM Reply Quote 0
                  Mitchfarino Module Developer @mochman
                  @mochman I’m only just back looking at this
                  Any tutorial I find online says I need a breadboard too - is that correct?
                  What pins should put these in? Or where can I find resource on how to do it?0_1472852546333_IMG_20160902_223136.jpg
                    mochman Module Developer @BeLuGe
                    @BeLuGe So I just tried this myself. When I created the module, I was connected to the pi to test. I just tried using SSH to start the program and got the same error you’re getting. Looks like it’s a issue with running a sudo command over SSH, the workaround I found was to run sudo cp ~/.Xauthority /root/ then run DISPLAY=:0 sudo npm start. The problem with this is that everytime you restart your mirror you will need to run the copy command again.
                    @Mitchfarino You don’t need a breadboard. I just used one to test out my configuration. You can hook it up directly to the pi using those wires you have already connected. When I tested out my setup, I used these pins.
                    echoLeftPin: 24,
                    triggerLeftPin: 23,
                    echoRightPin: 26,
                    Remember that those are the GPIO #'s and not the physical pin #.
                    M 1 Reply Last reply Sep 2, 2016, 11:46 PM Reply Quote 0
                      @mochman I have vcc, trig, echo and gnd on my sensor - how do they map to the config you have posted?
                      M 1 Reply Last reply Sep 3, 2016, 11:21 AM Reply Quote 0
                      • 1 / 5
