    MMM-Swipe - Hand gestures
    45 Posts 17 Posters 51.3k Views 16 Watching
      mochman Module Developer
      @BeLuGe Have you run npm install in the MMM-Swipe folder? Are you running the mirror with sudo? If so would you mind posting your config.js file. Thanks.
        BeLuGe
        @mochman Yes I have run npm install in the MMM-Swipe folder. I running the mirror without sudo.
        Error Message without sudo:
        Loading config ...
        Loading module helpers ...
        WARNING! Could not load config file. Starting with default configuration. Error found: Error: Module version mismatch. Expected 49, got 48.
        App threw an error during load
            at Error (native)
            at process.module.(anonymous function) [as dlopen] (ELECTRON_ASAR.js:167:20)
            at Object.Module._extensions..node (module.js:568:18)
            at Object.module.(anonymous function) [as .node] (ELECTRON_ASAR.js:167:20)
            at Module.load (module.js:458:32)
            at tryModuleLoad (module.js:417:12)
            at Function.Module._load (module.js:409:3)
            at Module.require (module.js:468:17)
            at require (internal/module.js:20:19)
            at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-Swipe/node_modules/mmm-usonic/lib/usonic.js:5:14)
            at Error (native)
        Launching application.
        Error Message with sudo:
        No protocol specified
        npm ERR! Linux 4.4.19-v7+
        npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "start"
        npm ERR! node v6.4.0
        npm ERR! npm  v3.10.3
        npm ERR! code ELIFECYCLE
        npm ERR! magicmirror@2.0.0 start: `electron js/electron.js`
        npm ERR! Exit status 1
        npm ERR!
        npm ERR! Failed at the magicmirror@2.0.0 start script 'electron js/electron.js'.
        npm ERR! If you do, this is most likely a problem with the magicmirror package,
        npm ERR! not with npm itself.
        npm ERR!     electron js/electron.js
        npm ERR!     npm bugs magicmirror
        npm ERR! Or if that isn't available, you can get their info via:
        npm ERR!     npm owner ls magicmirror
        npm ERR!     /home/pi/MagicMirror/npm-debug.log
        config.js
        /* Magic Mirror Config Sample
         * MIT Licensed.
        var config = {
                port: 8080,
                language: 'de',
                timeFormat: 24,
                units: 'metric',
                                module: 'alert',
                module: 'motiondetector',
                    timeout: 600000 // time in milliseconds for to switch off the display after last movement is detected.
                module: 'MMM-Swipe',
                position: 'bottom_left',    // Doesn't matter after it's setup.  It should be blank.
                                            // Best results in one of the side regions like: bottom_left
                    echoLeftPin: 24,        //Left Sensor's BCM Numbered Echo pin - REQUIRED
                    triggerLeftPin: 23,     //Left Sensor's BCM Numbered trigger pin - REQUIRED
                    echoRightPin: 26,       //Right Sensor's BCM Numbered Echo pin - REQUIRED
                    triggerRightPin: 25,    //Right Sensor's BCM Numbered trigger pin - REQUIRED
                    useAsButton: false,     //Enable a GPIO output when you "press".
                    buttonPin: 8,
                    verbose: true,
                    calibrate: true
                                module: 'clock',
                                position: 'top_left'
                                module: 'calendar',
                                header: 'Feiertage',
                                position: 'top_left',
                                                        symbol: 'calendar-check-o ',
                                                        url: ''
                module: 'MMM-FRITZ-Box-Callmonitor',
                position: 'top_right',  // This can be any of the regions. Best results in left or right regions.
                header: "Letzte Anrufe", // This is optional
                                module: 'compliments',
                                position: 'lower_third'
                                module: 'currentweather',
                                        locationID: '',  //ID from http://www.openweathermap.org
                                        appid: ''
                                module: 'weatherforecast',
                                header: 'Wettervorhersage',
                            appid: ''
                                module: 'newsfeed',
                                position: 'bottom_bar',
                                        feeds: [
                                                        title: "N24 News",
                                                        url: "http://feeds.n24.de/n24/homepage.xml"
                                        showSourceTitle: true,
                                        showPublishDate: true
        M 1 Reply Last reply
          Mitchfarino Module Developer @mochman
          @mochman I’m only just back looking at this
          Any tutorial I find online says I need a breadboard too - is that correct?
          What pins should put these in? Or where can I find resource on how to do it?0_1472852546333_IMG_20160902_223136.jpg
            mochman Module Developer @BeLuGe
            @BeLuGe So I just tried this myself. When I created the module, I was connected to the pi to test. I just tried using SSH to start the program and got the same error you’re getting. Looks like it’s a issue with running a sudo command over SSH, the workaround I found was to run sudo cp ~/.Xauthority /root/ then run DISPLAY=:0 sudo npm start. The problem with this is that everytime you restart your mirror you will need to run the copy command again.
            @Mitchfarino You don’t need a breadboard. I just used one to test out my configuration. You can hook it up directly to the pi using those wires you have already connected. When I tested out my setup, I used these pins.
            echoLeftPin: 24,
            triggerLeftPin: 23,
            echoRightPin: 26,
            Remember that those are the GPIO #'s and not the physical pin #.
              @mochman I have vcc, trig, echo and gnd on my sensor - how do they map to the config you have posted?
                mochman Module Developer @Mitchfarino
                @Mitchfarino
                Your left sensor
                Vcc goes to pin #2
                Gnd goes to pin #6
                Trig goes to physical pin #26 (Which is labeled GPIO 23)
                Echo goes to physical pin #18 (Which is labeled GPIO 24)
                Your right sensor
                Vcc goes to pin #4
                Gnd goes to pin #9
                Trig goes to physical pin #22 (Which is labeled GPIO 25)
                Echo goes to physical pin #37 (Which is labeled GPIO 26)
                You need both sensors if you want to detect movement.
                  @mochman OK, I’m an idiot!
                  I only have one sensor! Ha
                  Thanks very much for your help, I’m gonna get one ordered then get back on it.
                  Sorry for the daft questions
                    No worries. Yeah the sensor looks like it has 2 detectors on it. I’m pretty sure one is the speaker and the other is the microphone detector.
                      BeLuGe
                      @mochman when I use your workaround i get the following errormessage and a whitescreen:
                      Loading config ...
                          at Error (native)
                          at Error (native)
                        Can you make another config.js file with just the MMM-Swipe module in there? I don’t know what the:
                        WARNING! Could not load config file. Starting with default configuration. Error found: Error: Module version mismatch. Expected 49, got 48. means.
                          BeLuGe
                          @mochman I change the config file to default and add your Module. The same errormessage.
                            @BeLuGe Try running rm -rf node_modules/ inside the MMM-Swipe folder then running npm install again.
                              BeLuGe
                              @mochman I have delete the directory and install the packages with npm install
                              And I have reinstall the complete Raspberry and install only your module.
                              The error is still there
                                I can’t help you then. That was my last option. I don’t receive that error nor do I know what that error means.
                                  bob123bob
                                  @mochman and @BeLuGe can you tell us what are the versions you are using :
                                  Raspbian Jessie or Wheezy, which version of nodes, npm … ?
                                  From where are you running npm start (local, ssh) using sudo or not ?
                                  I have the same issue as @BeLuGe and I would like to debug/understand what’s is the problem.
                                  I already red it could be a nodejs version issue (compiling vs running version)
                                  So guys tell us what are your configuration
                                  Here is mine :
                                  Rpi 3 updated firmware with rpi-update
                                  Raspbian Jessie last version (apt-get update && upgrade && dist-upgrade)
                                  Nodejs last version 6.5.0 ARM version (not sure if it’s 64 bit or 32 bit) from https://nodejs.org
                                  Then install of MM and packages
                                  MM is working fine until I add MMM-Swipe module configuration then got same error message about
                                  Hope we will find the solution …
                                    BeLuGe
                                    @bob123bob I use Raspbian Jessie last version, Nodejs 6.5.0.
                                    I have test it with Nodejs 5.11.1, the same issue.
                                    I run MM without sudo.
                                      I’m running:
                                      RasPi 3 with Jessie
                                      NodeJs 6.7.0
                                      Fully updated with
                                      sudo apt-get update
                                      sudo apt-get dist-upgrade
                                      sudo rpi-update
                                      I just removed the entire MMM-Swipe Folder
                                      cd ~/MagicMirror/modules/
                                      git clone https://github.com/mochman/MMM-Swipe
                                      cd MMM-Swipe/
                                      npm install
                                      cd ~/MagicMirror/
                                      sudo npm start
                                      I don’t get any of those errors. I don’t know what module version 49 is?
                                      J 1 Reply Last reply
                                        Jopyth Moderator @mochman
                                        @mochman Similar issue here. They changed the package.json to fix it. Seems to be a problem with a new Electron version.
                                        You would only get this error if you newly install Magic Mirror (npm install in the MagicMirror folder gets the new package, if you want to reproduce it).
                                          @Jopyth Thanks! I was able to reproduce the error. I updated the package.json file and it runs correctly.
                                            DirkS
                                            Did you try to use the HR-SR04 behind the mirror glas? I would like to use it like that but don’t know if the ultrasonic sensor will work behind the glas.
