    MMM-Swipe - Hand gestures
    45 Posts 17 Posters 47.0k Views 16 Watching
    • mochmanM Offline
      mochman Module Developer
      @BeLuGe Have you run npm install in the MMM-Swipe folder? Are you running the mirror with sudo? If so would you mind posting your config.js file. Thanks.
        BeLuGe
        @mochman Yes I have run npm install in the MMM-Swipe folder. I running the mirror without sudo.
        Error Message without sudo:
        Loading config ...
        Loading module helpers ...
        WARNING! Could not load config file. Starting with default configuration. Error found: Error: Module version mismatch. Expected 49, got 48.
        App threw an error during load
            at Error (native)
            at process.module.(anonymous function) [as dlopen] (ELECTRON_ASAR.js:167:20)
            at Object.Module._extensions..node (module.js:568:18)
            at Object.module.(anonymous function) [as .node] (ELECTRON_ASAR.js:167:20)
            at Module.load (module.js:458:32)
            at tryModuleLoad (module.js:417:12)
            at Function.Module._load (module.js:409:3)
            at Module.require (module.js:468:17)
            at require (internal/module.js:20:19)
            at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-Swipe/node_modules/mmm-usonic/lib/usonic.js:5:14)
            at Error (native)
        Launching application.
        Error Message with sudo:
        No protocol specified
        npm ERR! Linux 4.4.19-v7+
        npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "start"
        npm ERR! node v6.4.0
        npm ERR! npm  v3.10.3
        npm ERR! code ELIFECYCLE
        npm ERR! magicmirror@2.0.0 start: `electron js/electron.js`
        npm ERR! Exit status 1
        npm ERR!
        npm ERR! Failed at the magicmirror@2.0.0 start script 'electron js/electron.js'.
        npm ERR! If you do, this is most likely a problem with the magicmirror package,
        npm ERR! not with npm itself.
        npm ERR!     electron js/electron.js
        npm ERR!     npm bugs magicmirror
        npm ERR! Or if that isn't available, you can get their info via:
        npm ERR!     npm owner ls magicmirror
        npm ERR!     /home/pi/MagicMirror/npm-debug.log
        config.js
        /* Magic Mirror Config Sample
         * MIT Licensed.
        var config = {
                port: 8080,
                language: 'de',
                timeFormat: 24,
                units: 'metric',
                                module: 'alert',
                module: 'motiondetector',
                    timeout: 600000 // time in milliseconds for to switch off the display after last movement is detected.
                module: 'MMM-Swipe',
                position: 'bottom_left',    // Doesn't matter after it's setup.  It should be blank.
                                            // Best results in one of the side regions like: bottom_left
                    echoLeftPin: 24,        //Left Sensor's BCM Numbered Echo pin - REQUIRED
                    triggerLeftPin: 23,     //Left Sensor's BCM Numbered trigger pin - REQUIRED
                    echoRightPin: 26,       //Right Sensor's BCM Numbered Echo pin - REQUIRED
                    triggerRightPin: 25,    //Right Sensor's BCM Numbered trigger pin - REQUIRED
                    useAsButton: false,     //Enable a GPIO output when you "press".
                    buttonPin: 8,
                    verbose: true,
                    calibrate: true
                                module: 'clock',
                                position: 'top_left'
                                module: 'calendar',
                                header: 'Feiertage',
                                position: 'top_left',
                                                        symbol: 'calendar-check-o ',
                                                        url: ''
                module: 'MMM-FRITZ-Box-Callmonitor',
                position: 'top_right',  // This can be any of the regions. Best results in left or right regions.
                header: "Letzte Anrufe", // This is optional
                                module: 'compliments',
                                position: 'lower_third'
                                module: 'currentweather',
                                        locationID: '',  //ID from http://www.openweathermap.org
                                        appid: ''
                                module: 'weatherforecast',
                                header: 'Wettervorhersage',
                            appid: ''
                                module: 'newsfeed',
                                position: 'bottom_bar',
                                        feeds: [
                                                        title: "N24 News",
                                                        url: "http://feeds.n24.de/n24/homepage.xml"
                                        showSourceTitle: true,
                                        showPublishDate: true
        mochmanM 1 Reply Last reply Reply Quote 0
        • MitchfarinoM Offline
          Mitchfarino Module Developer @mochman
          @mochman I’m only just back looking at this
          Any tutorial I find online says I need a breadboard too - is that correct?
          What pins should put these in? Or where can I find resource on how to do it?0_1472852546333_IMG_20160902_223136.jpg
          • mochmanM Offline
            mochman Module Developer @BeLuGe
            @BeLuGe So I just tried this myself. When I created the module, I was connected to the pi to test. I just tried using SSH to start the program and got the same error you’re getting. Looks like it’s a issue with running a sudo command over SSH, the workaround I found was to run sudo cp ~/.Xauthority /root/ then run DISPLAY=:0 sudo npm start. The problem with this is that everytime you restart your mirror you will need to run the copy command again.
            @Mitchfarino You don’t need a breadboard. I just used one to test out my configuration. You can hook it up directly to the pi using those wires you have already connected. When I tested out my setup, I used these pins.
            echoLeftPin: 24,
            triggerLeftPin: 23,
            echoRightPin: 26,
            Remember that those are the GPIO #'s and not the physical pin #.
            MitchfarinoM 1 Reply Last reply Reply Quote 0
              @mochman I have vcc, trig, echo and gnd on my sensor - how do they map to the config you have posted?
              • mochmanM Offline
                mochman Module Developer @Mitchfarino
                @Mitchfarino
                Your left sensor
                Vcc goes to pin #2
                Gnd goes to pin #6
                Trig goes to physical pin #26 (Which is labeled GPIO 23)
                Echo goes to physical pin #18 (Which is labeled GPIO 24)
                Your right sensor
                Vcc goes to pin #4
                Gnd goes to pin #9
                Trig goes to physical pin #22 (Which is labeled GPIO 25)
                Echo goes to physical pin #37 (Which is labeled GPIO 26)
                You need both sensors if you want to detect movement.
                MitchfarinoM 1 Reply Last reply Reply Quote 1
                  @mochman OK, I’m an idiot!
                  I only have one sensor! Ha
                  Thanks very much for your help, I’m gonna get one ordered then get back on it.
                  Sorry for the daft questions
                  • mochmanM Offline
                    No worries. Yeah the sensor looks like it has 2 detectors on it. I’m pretty sure one is the speaker and the other is the microphone detector.
                      BeLuGe
                      @mochman when I use your workaround i get the following errormessage and a whitescreen:
                      Loading config ...
                          at Error (native)
                          at Error (native)
                      • mochmanM Offline
                        Can you make another config.js file with just the MMM-Swipe module in there? I don’t know what the:
                        WARNING! Could not load config file. Starting with default configuration. Error found: Error: Module version mismatch. Expected 49, got 48. means.
                        • 1 / 5
