    cant get magicmirror to show up on screen
    pm2troubleshoot
    28 Posts 4 Posters 25.7k Views 5 Watching
    • yo-lessY Offline
      yo-less Module Developer
      Are you, by any chance, using a Raspberry Pi 1?
      • L Offline
        lysnikolaou
        No, i am not. I am using the Raspberry Pi 3 Model B.
        • yo-lessY Offline
          Alright. What happens when you open a browser window on your Pi and go to http://localhost:8080?
          • L Offline
            lysnikolaou
            I get the “this site cant be reached” error
            • yo-lessY Offline
              What information comes up when you enter “pm2 logs mm” in the terminal window?
              • L Offline
                lysnikolaou
                I get a whole bunch of errors, but the output tells me that I either have wrong versions of nodejs or npm or the magicmirror package itself is the one to blame. After that comes the message that electron js/electron.js fails
                Here is the log file that need to be submitted according to the log output:
                1 verbose cli [ ‘/usr/bin/nodejs’, ‘/usr/bin/npm’, ‘start’ ]
                2 info using npm@3.10.3
                3 info using node@v6.5.0
                4 verbose run-script [ ‘prestart’, ‘start’, ‘poststart’ ]
                5 info lifecycle magicmirror@2.0.0~prestart: magicmirror@2.0.0
                6 silly lifecycle magicmirror@2.0.0~prestart: no script for prestart, continuing
                7 info lifecycle magicmirror@2.0.0~start: magicmirror@2.0.0
                8 verbose lifecycle magicmirror@2.0.0~start: unsafe-perm in lifecycle true
                9 verbose lifecycle magicmirror@2.0.0~start: PATH: /usr/lib/node_modules/npm/bin/node-gyp-bin:/home/pi/MagicMirror/node_modules/.bin:/usr/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/local/games:/usr/games
                10 verbose lifecycle magicmirror@2.0.0~start: CWD: /home/pi/MagicMirror
                11 silly lifecycle magicmirror@2.0.0~start: Args: [ ‘-c’, ‘electron js/electron.js’ ]
                12 info lifecycle magicmirror@2.0.0~start: Failed to exec start script
                13 verbose stack Error: magicmirror@2.0.0 start: electron js/electron.js
                13 verbose stack spawn ENOENT
                13 verbose stack at ChildProcess. (/usr/lib/node_modules/npm/lib/utils/spawn.js:33:16)
                13 verbose stack at emitTwo (events.js:106:13)
                13 verbose stack at ChildProcess.emit (events.js:191:7)
                13 verbose stack at maybeClose (internal/child_process.js:877:16)
                13 verbose stack at Process.ChildProcess._handle.onexit (internal/child_process.js:226:5)
                14 verbose pkgid magicmirror@2.0.0
                15 verbose cwd /home/pi/MagicMirror
                16 error Linux 4.4.13-v7+
                17 error argv “/usr/bin/nodejs” “/usr/bin/npm” “start”
                18 error node v6.5.0
                19 error npm v3.10.3
                20 error file sh
                21 error code ELIFECYCLE
                22 error errno ENOENT
                23 error syscall spawn
                24 error magicmirror@2.0.0 start: electron js/electron.js
                24 error spawn ENOENT
                25 error Failed at the magicmirror@2.0.0 start script ‘electron js/electron.js’.
                25 error Make sure you have the latest version of node.js and npm installed.
                25 error If you do, this is most likely a problem with the magicmirror package,
                25 error not with npm itself.
                25 error Tell the author that this fails on your system:
                25 error electron js/electron.js
                25 error You can get information on how to open an issue for this project with:
                25 error npm bugs magicmirror
                25 error Or if that isn’t available, you can get their info via:
                25 error npm owner ls magicmirror
                25 error There is likely additional logging output above.
                26 verbose exit [ 1, true ]
                • yo-lessY Offline
                  Ok, there might be a problem with your electron installation.
                  Can you go into your MagicMirror folder and type “node serveronly”?
                  Then, go back to your browser window and type in “localhost:8080”
                  • L Offline
                    lysnikolaou
                    Ok it is now working.
                    I will now try to enable kioskmode.
                    • yo-lessY Offline
                      This would mean that there seems to be a problem with your electron installation. Since you’ve got a Pi 3, I would try to get that fixed, it’s much easier to have the mirror act the way you want it to if the kiosk mode comes up automatically. I’m running the mirror on a Pi 1 and it took me forever to get everything set up so that the system boots into the mirror, I had to make sure the browser didn’t start too early, and so on. It requires many manual modifications and I’m almost certain that’s not the path you want to take :).
                      Your mirror installation is not properly set up, I would try to fix that.
                      I’m not sure if the problem on your system is electron or the mirror installation, as I’m not able to use electron on my Pi I have no experience with using it. But you can try going to your MagicMirror folder and typing in: “npm install electron”, this may set things right.
                      If it doesn’t, maybe try a reinstall.
                      • L Offline
                        lysnikolaou
                        I get an error every time. Both with npm install electron and by reinstalling the whole package. I dont get what the error is but it seems to be with nodejs.
