    MMM-crypto-portfolio
    26 Posts 12 Posters 16.9k Views 11 Watching
      Joshrobbs1
      This is amazing! Where is this pulling the info from? Binance?
        Charley Module Developer
        The data comes from coincapmarket.com
        MMM-Bose-Soundtouch, MMM-Domoticz, MMM-crypto-portfolio, MMM-Fibaro, MMM-rain-forecast
        PowellaJasonP 1 Reply Last reply
          callum8004
          Hi on the MMM-crypto-portfolio module im struggling to display both SingularDTV and Linda - I’ve tried teh obvious ‘linda’ and ‘singularDTV’ but no luck - any suggestions?
            SingularDTV is at position 280 and Linda at 351 at coincapmarket.
            Just increase the limit: 100 in config.js to 380
            If you look at the example config.js the last line tells you increase if your currency doesn’t appear there are over 1000 at coincapmarket.com (at this moment 1656)
              Did it help you?
              C 1 Reply Last reply
                callum8004 @Charley
                @charley Hi Charley - solved the issue thanks for your reply!
                • MarosM
                  Maros
                  how do i increase font ? i’ve tried to put entry to custom.css .MMM-crypto-portfolio but with no sucess :( i’ve also changed in MMM-crypto-portfolio.css font-size from small to medium but also font stays on same size as before …
                    Charley Module Developer @Maros
                    @maros If you look in the css file at line 54 it says
                    font-size:14px
                    You can increase or decrease the number (this size is chosen so it will align properly)
                    • MarosM
                      Maros
                      ok thank you i’ll try :)
                      • twosquirrelsT
                        twosquirrels
                        Is there an easy way to remove the “total assets” line at the bottom? I am only tracking one currency, so it’s redundant to have it displayed twice. Thanks.
                        • K
                          kornface13
                          Is this working for anyone currently? I’ve copied the example config but nothing shows up in my dashboard at all. Wondering if the coinmarketcap data output has changed and this is no longer working. Thoughts?
                          • PowellaJasonP
                            PowellaJason @Charley
                            • PowellaJasonP
                              PowellaJason
                              Ammetto, sono un trader alle prime armi e non so da che parte muovermi. Ho iniziato per gioco ma mi piacerebbe sviluppare le mie conoscenze fidandomi e affidandomi a qualcuno di specializzato. Mio cognato intanto mi ha fatto andare sulla piattaforma di FBS broker e ne sono rimasto colpito. Seminari gratuiti, interfaccia utente personalizzata e la possibilità di parlare con chi se ne intende per davvero. Penso proprio che continuerò su questa linea.
                                duxnobis
                                I know it’s been a while since this was used last time but I decided to give it a try. Where can I find this module?
                                D 1 Reply Last reply
                                  duxnobis @duxnobis
                                  @duxnobis Found the module, but even using the demo config entry it does not show up but give me an error on the mirror. Anyone info about if this still works?
                                  • iMAGiCI
                                    iMAGiC @Charley
                                    @charley this repo is cool, and I’ve added into my mirror for while.
                                    I don’t know if you are farming Chia (Chia Network), Chia has many forks there, many farmer farming many forks at the same time on the same machine, that cause not easy to check their wallet and cold wallet also.
                                    I found an APP on Google store that can track all your wallet via “network browser” ex.https://alltheblocks.net/ , user can add all different fork wallets, it’s very easy get an update via a swipe down on mobile phone screen.
                                    Is possible that you combine your repo and create a new one that similar as Chiew ?
                                    so that MM user can see updated wallets amount every 15mins or 30mins.
                                    iMAGiC
                                    Choice * Judgment * Values
                                    • F
                                      fischi87
                                      Hello, I install ur module and just copy and paste ur config from the readme but I get just a header with ‘my crypto portfolio’ and nothing more. is this module just update? or what I did wrong?
                                      thanks
                                      MarosM 1 Reply Last reply
                                      • MarosM
                                        Maros @fischi87
                                        Is it possible to add to this API from Helium network ? so i will be able to see current amount in my helium wallet ?
                                        I don’t want to manually write amount as this is changing.
                                        I tried to search modules but i don’t see any suitable module.
                                        Maybe edit MMM-Coinbase module to show only Helium wallet from (explorer.helium.com)
