    MMM-crypto-portfolio
    26 Posts 12 Posters 16.4k Views 11 Watching
    • A
      AmDDJunkie
      Very cool. Would you add Feathercoin and Nexus images to the repo?
      2_1524598358179_feather-white.png 1_1524598358179_white-square-nexus-logo.png 0_1524598358178_blue-square-nexus-logo.png
        Charley Module Developer
        @amDDJunkie I have just added the logos
        If someone else needs a logo added please send the logo size 50x50 pixels in colour and in white.
        MMM-Bose-Soundtouch, MMM-Domoticz, MMM-crypto-portfolio, MMM-Fibaro, MMM-rain-forecast
          jaminben
          Hi Charley,
          Is it possible to swap the icon from right to the left side of the text and to be able to remove the text word ‘Price’?
          If not no worries.
          Thanks for another classy module :)
            @jaminben Yes it is possible
            In the newest update from today you have three new options
                    showLabels: true,       // true or false
                    logoPosition: "front",  // option front, middle, back
                    graphPosition: "back",  // option front, back
            However the labels for price changes will always be visible (just percentages without label look silly)
            Hope you like it
              jaminben
              @Charley said in MMM-crypto-portfolio:
              logoPosition: “front”,
              Cool… it appears to work but are the logos centered?.. mine look off center or rather the back edge of the logo is the edge which then makes the logos look slightly off.
                To prevent alignment problems the portfolio is a nested table.
                The only way to get the alignment properly for now I have removed the total asset label if the logo is set to ‘back’
                Your assets are too high if you keep your wealth below the 1000 GDP it would have worked fine :-)
                  jaminben
                  Ok, thanks for taking the time and looking into this for me :)
                    Joshrobbs1
                    This is amazing! Where is this pulling the info from? Binance?
                      The data comes from coincapmarket.com
                      PowellaJasonP 1 Reply Last reply Reply Quote 0
                        callum8004
                        Hi on the MMM-crypto-portfolio module im struggling to display both SingularDTV and Linda - I’ve tried teh obvious ‘linda’ and ‘singularDTV’ but no luck - any suggestions?
                          SingularDTV is at position 280 and Linda at 351 at coincapmarket.
                          Just increase the limit: 100 in config.js to 380
                          If you look at the example config.js the last line tells you increase if your currency doesn’t appear there are over 1000 at coincapmarket.com (at this moment 1656)
                            Did it help you?
                              callum8004 @Charley
                              @charley Hi Charley - solved the issue thanks for your reply!
                              • MarosM
                                Maros
                                how do i increase font ? i’ve tried to put entry to custom.css .MMM-crypto-portfolio but with no sucess :( i’ve also changed in MMM-crypto-portfolio.css font-size from small to medium but also font stays on same size as before …
                                  Charley Module Developer @Maros
                                  @maros If you look in the css file at line 54 it says
                                  font-size:14px
                                  You can increase or decrease the number (this size is chosen so it will align properly)
                                  • MarosM
                                    Maros
                                    ok thank you i’ll try :)
                                    • twosquirrelsT
                                      twosquirrels
                                      Is there an easy way to remove the “total assets” line at the bottom? I am only tracking one currency, so it’s redundant to have it displayed twice. Thanks.
                                      • K
                                        kornface13
                                        Is this working for anyone currently? I’ve copied the example config but nothing shows up in my dashboard at all. Wondering if the coinmarketcap data output has changed and this is no longer working. Thoughts?
                                        • PowellaJasonP
                                          PowellaJason @Charley
                                          • PowellaJasonP
                                            PowellaJason
                                            Ammetto, sono un trader alle prime armi e non so da che parte muovermi. Ho iniziato per gioco ma mi piacerebbe sviluppare le mie conoscenze fidandomi e affidandomi a qualcuno di specializzato. Mio cognato intanto mi ha fatto andare sulla piattaforma di FBS broker e ne sono rimasto colpito. Seminari gratuiti, interfaccia utente personalizzata e la possibilità di parlare con chi se ne intende per davvero. Penso proprio che continuerò su questa linea.
