    Installing on Ubuntu 18.04
    11 Posts 5 Posters 5.9k Views 4 Watching
    • gwylsG Offline
      gwyls @Mykle1
      @mykle1 said in Installing on Ubuntu 18.04:
      npm install
      No I just ran the sh script. Just ran the npm command and found I needed to install. I am now running the npm install command. I’ll let you know.
      Thanks for the help.
      Learning the unforced rhythms of grace
      https://gwyls.co.uk
      gwylsG 1 Reply Last reply Reply Quote 0
      • gwylsG Offline
        gwyls
        I have it installed now. Do you mind me asking some silly questions please?
        1. How do I now make it run?
        2. Does it take over the computer? Can I still use it with magic mirror in the background?
          I am testing it to see what it is like, hopefully with a view to running it on a computer all the time.
        https://gwyls.co.uk
          A Former User @gwyls
          @gwyls
          • You can run with npm start in MagicMirror Directory.
          • It will occupy your front but you can send it to backward, but anyway, it will not like desktop background. It’s not that purpose.
          gwylsG 1 Reply Last reply Reply Quote 1
          • gwylsG Offline
            gwyls @Guest
            @sean Thanks
            It really does need to be a standalone computer then.
            https://gwyls.co.uk
            • gwylsG Offline
              gwyls @gwyls
              I tried to run as suggested and came up with this problem:
              WARNING! Could not find config file. Please create one. Starting with default configuration.
              What is the default configuration please? Is there a dummy one that I could copy or should I create a config.txt file and let MagicMirror write to it please?
              https://gwyls.co.uk
              E ? 2 Replies Last reply Reply Quote 0
              • E Offline
                electros Project Sponsor @gwyls
                @gwyls in the magic mirror folder you have a folder config, check there and you find a file named config.js.sample just rename that one to config.js and should be work.
                  @gwyls I think you need to read Manual.
                  https://github.com/MichMich/MagicMirror
                  • cowboysdudeC Offline
                    cowboysdude Module Developer @Guest
                    @sean said in Installing on Ubuntu 18.04:
                    HEHEHEHHEHE seen that MANY times
                      Mykle1 Project Sponsor Module Developer @electros
                      @electros said in Installing on Ubuntu 18.04:
                      @gwyls
                      What you are supposed to do is make a COPY of the config.js.sample (so that you never lose it) and rename the pasted copy to config.js.
                      Once you have MM running you can press Ctrl M to hide MM and use your PC for other things. Simply clicking the MM icon in the task bar will bring MM to the front.
