Installing on Ubuntu 18.04
Complete novice here who thought it would be fun to run on his home computer. Downloaded and unzipped. Ran:
./run-start.shAnd was told electron: command not found.
Where do I go from here please?
Thanks -
Did you run
npm installin the MagicMirror directory? -
@mykle1 said in Installing on Ubuntu 18.04:
npm install
No I just ran the sh script. Just ran the npm command and found I needed to install. I am now running the npm install command. I’ll let you know.
Thanks for the help. -
I have it installed now. Do you mind me asking some silly questions please?
- How do I now make it run?
- Does it take over the computer? Can I still use it with magic mirror in the background?
I am testing it to see what it is like, hopefully with a view to running it on a computer all the time.
- You can run with
npm startin MagicMirror Directory. - It will occupy your front but you can send it to backward, but anyway, it will not like
desktop background. It’s not that purpose.
- You can run with
@sean Thanks
It really does need to be a standalone computer then. -
I tried to run as suggested and came up with this problem:
WARNING! Could not find config file. Please create one. Starting with default configuration.
What is the default configuration please? Is there a dummy one that I could copy or should I create a config.txt file and let MagicMirror write to it please? -
@gwyls in the magic mirror folder you have a folder config, check there and you find a file named config.js.sample just rename that one to config.js and should be work.
@gwyls I think you need to read Manual.
https://github.com/MichMich/MagicMirror -
@sean said in Installing on Ubuntu 18.04:
https://github.com/MichMich/MagicMirrorHEHEHEHHEHE seen that MANY times
