    Installing on Ubuntu 18.04
    11 Posts 5 Posters 6.2k Views 4 Watching
    • gwylsG Offline
      gwyls
      Complete novice here who thought it would be fun to run on his home computer. Downloaded and unzipped. Ran:
      ./run-start.sh
      And was told electron: command not found.
      Where do I go from here please?
      Learning the unforced rhythms of grace
      https://gwyls.co.uk
        Mykle1 Project Sponsor Module Developer @gwyls
        @gwyls
        Did you run npm install in the MagicMirror directory?
        gwylsG 1 Reply Last reply Reply Quote 0
        • gwylsG Offline
          gwyls @Mykle1
          @mykle1 said in Installing on Ubuntu 18.04:
          npm install
          No I just ran the sh script. Just ran the npm command and found I needed to install. I am now running the npm install command. I’ll let you know.
          Thanks for the help.
          https://gwyls.co.uk
          • gwylsG Offline
            gwyls
            I have it installed now. Do you mind me asking some silly questions please?
            1. How do I now make it run?
            2. Does it take over the computer? Can I still use it with magic mirror in the background?
              I am testing it to see what it is like, hopefully with a view to running it on a computer all the time.
            https://gwyls.co.uk
              A Former User @gwyls
              @gwyls
              • You can run with npm start in MagicMirror Directory.
              • It will occupy your front but you can send it to backward, but anyway, it will not like desktop background. It’s not that purpose.
              gwylsG 1 Reply Last reply Reply Quote 1
              • gwylsG Offline
                gwyls @Guest
                @sean Thanks
                It really does need to be a standalone computer then.
                https://gwyls.co.uk
                • gwylsG Offline
                  gwyls @gwyls
                  I tried to run as suggested and came up with this problem:
                  WARNING! Could not find config file. Please create one. Starting with default configuration.
                  What is the default configuration please? Is there a dummy one that I could copy or should I create a config.txt file and let MagicMirror write to it please?
                  https://gwyls.co.uk
                  E ? 2 Replies Last reply Reply Quote 0
                  • E Offline
                    electros Project Sponsor @gwyls
                    @gwyls in the magic mirror folder you have a folder config, check there and you find a file named config.js.sample just rename that one to config.js and should be work.
                      @gwyls I think you need to read Manual.
                      https://github.com/MichMich/MagicMirror
                      • cowboysdudeC Offline
                        cowboysdude Module Developer @Guest
                        @sean said in Installing on Ubuntu 18.04:
                        HEHEHEHHEHE seen that MANY times
                          Mykle1 Project Sponsor Module Developer @electros
                          @electros said in Installing on Ubuntu 18.04:
                          @gwyls
                          What you are supposed to do is make a COPY of the config.js.sample (so that you never lose it) and rename the pasted copy to config.js.
                          Once you have MM running you can press Ctrl M to hide MM and use your PC for other things. Simply clicking the MM icon in the task bar will bring MM to the front.
