    Help choosing more than one item from an array
    18 Posts 4 Posters 8.3k Views 4 Watching
    • strawberry 3.141S Offline
      strawberry 3.141 Project Sponsor Module Developer @justjim1220
      @justjim1220 It looks like you are trying to do multiple request, as mykles description sounds like one request with a comma seperated list.
      justjim1220J Mykle1M 2 Replies Last reply Reply Quote 1
      • justjim1220J Offline
        justjim1220 Module Developer @strawberry 3.141
        @strawberry-3-141
        Yeah, I got that while trying to write what I had going. Your example looks more correct.
        So, now I’m looking at your example but not exactly sure where to insert it into the code to get it to work.
        in the config.js, I am looking at the lifeforms array as such:
        lifeForms: "Striped Bass,Praying Mantis,Tigers,Hummingbirds,Venus Flytrap,Fox,Bald Eagle",
        then I added this to the defaults in the MMM-EOL.js:
        lifeForms: ["", "", ""],
        then I added your example to the start function:
                var lifeFormIds = this.config.lifeForms.split(',');
                var lifeFormIds =[];
                for (let lifeForm of lifeForms) {
                    if (this.config.lifeFormArray[lifeForm]) {
                        lifeFormIds.push(this.config.lifeFormArray[lifeForm]);
                //  Set locale.
                this.url = "http://eol.org/api/pages/1.0.json?batch=false&id=" + this.config.lifeFormIds.join(',') +
        I know this is definitely NOT right. This is where I am getting confused…
        Having 2 separate < var lifeFormIds > declared doesn’t look right.
        And, placing the ‘join’ part after the URL doesn’t look right either…
        Jim Hallock - 1995
          ok, your source ‘lifeFormArray’ is a hash… good for looking up randomly
          now to get the user specified list into something usable, split is the way as already posted
          // if user specified something
          if(this.config.lifeForms.length >0 )
               // split will return an array with only one entry if no comma found
               this.config.user_keys=this.config.lifeForms.split(',');
          else
               // add an entry to a special lifeFormArray entry for missing config info
               this.config.user_keys.push("none");
          now, you want random, or walk the array of user_keys?
          function getRandomInt(max) {
            return Math.floor(Math.random() * Math.floor(max));
          // get one of the user specified data keys, using random
          var key=this.config.user_keys[this.getRandomInt(this.config.user_keys.length)];
          // append that id value to the url.
          this.url = "http://eol.org/api/pages/1.0.json?batch=false&id=" +this.lifeFormArray.key;
          its unclear if u wanted all or just one…
          justjim1220J 1 Reply Last reply Reply Quote 1
            justjim1220 Module Developer @sdetweil
            Random would be great!
            I’ll give it a try, Thanks!
            Jim Hallock - 1995
              sdetweil @justjim1220
              @justjim1220 make sure to add an entry to the lifeFormArray that matches the string you define for ‘none’ (no user entry supplied)
              justjim1220J 2 Replies Last reply Reply Quote 1
                So, would the entry be like this: “Cats”, “Bats”, “Bears”,
                or like This: “Cats,Bats,Bears”,
                Jim Hallock - 1995
                  Well, at the moment it is throwing the following error:
                  I’ll look at it some more here in a little bit…
                  Thanks for your input!
                  Jim Hallock - 1995
                    Mykle1 Project Sponsor Module Developer @strawberry 3.141
                    @strawberry-3-141
                    I am extremely grateful to both of you for your assistance and guidance. I thank you both. :thumbsup:
                    @justjim1220
                    Jim, as it seems you’ve taken over this topic, I will leave it to you.
                      justjim1220 Module Developer @Mykle1
                      @mykle1
                      I don’t know about taking it over, LOL.
                      Just trying to help!
                      Jim Hallock - 1995
                        @strawberry-3-141 said in Help choosing more than one item from an array:
                        what you describe above is actually not an array, it’s an object (hash). Arrays are always defined with [] not {}.
                        Object. Array. What’s the difference? (That’s a joke. Laugh) :-D
                          @justjim1220 that error looks like from the constructed url failing
                            @justjim1220 the second. Don’t depend on users to do multiple entries
