    Help with inserting a script into a <div> element
    11 Posts 5 Posters 3.9k Views 5 Watching
      A Former User @AdamBD
      @adambd
      There are several ways to insert script after loading. Here are examples;
      //insert before other scripts
      var tag = document.createElement("script")
      tag.src = "EXTERNAL_SCRIPT_URL"
      var firstScriptTag = document.getElementsByTagName("script")[0]
      firstScriptTag.parentNode.insertBefore(tag, firstScriptTag)
      //insert after other scripts
      var tag = document.createElement("script");
      tag.src = "EXTERNAL_SCRIPT_URL";
      document.getElementsByTagName("head")[0].appendChild(tag);
      Or, You can make a HTML file which contains the target widget, and load it with iFrame.
        AdamBD
        Hi Sean, thanks for answering!
        tag.src = “EXTERNAL_SCRIPT_URL”;
        What should this point to? A local file on my machine?
          sdetweil @AdamBD
          @adambd EXTERNAL url = “https://some_server_com/etc/whatever.js”
            AdamBD @sdetweil
            @sdetweil Hey sean, But then I need to have a ‘server’ running to pull this in. I would prefer just to keep it in another node file in the project. any thoughts on how to do that?
            ? S 2 Replies Last reply Reply Quote 0
              @adambd
              How about trying this?
              [card:eouia/MMM-Widget]
              Mykle1M justjim1220J 2 Replies Last reply Reply Quote 2
                sdetweil @AdamBD
                @adambd if you look at the MMM_ImagedPhotos and MMM_ImageSlideshow modules, you will see they map a url for the express server running in MM
                	extraRoutes: function() {
                		var self = this;
                		this.expressApp.get("/MMM-ImagesPhotos/photos", function(req, res) {
                			self.getPhotosImages(req, res);
                		this.expressApp.use("/MMM-ImagesPhotos/photo", express.static(self.path_images));
                	// return photos-images by response in JSON format.
                	getPhotosImages: function(req, res) {
                		directoryImages = this.path_images;
                		var imagesPhotos = this.getImages(this.getFiles(directoryImages)).map(function (img) {
                			return {url: "/MMM-ImagesPhotos/photo/" + img};
                		res.send(imagesPhotos);
                • justjim1220J Offline
                  justjim1220 Module Developer @AdamBD
                  @adambd
                  element.innerHTML =  `<div>     ENTER HTML CODE    </div>`
                  you have to have the ` before and after the div indicators
                  the key to the left of the 1 key
                  Jim Hallock - 1995
                    Mykle1 Project Sponsor Module Developer @Guest
                    @sean
                    You could not have made it any easier. Fantastic idea, sean!
                      justjim1220 Module Developer @Guest
                      @sean
                      The only problem with this widget module… It doesn’t allow clickable links to be clicked…
                      Otherwise, It’s pretty cool! :smiling_face_with_sunglasses:
                      Jim Hallock - 1995
                        Mykle1 Project Sponsor Module Developer @justjim1220
                        @justjim1220 said in Help with inserting a script into a <div> element:
                        Most people don’t use a mouse with their mirrors
