    MMM-fbPageCounter
    23 Posts 7 Posters 14.2k Views 6 Watching
      MSimonart
      Ok yeah perfect, got it working. Thanks ;)
      • H
        Hellonoonan
        How can I add this to mine?
        Mykle1M 1 Reply Last reply
        • Mykle1M
          Mykle1 Project Sponsor Module Developer @Hellonoonan
          @hellonoonan
          https://github.com/eouia/MMM-fbPageCounter
          H 1 Reply Last reply
          • H
            Hellonoonan @Mykle1
            @mykle1 Okay, so I did find that before and it is (at least for me) extremely confusing. I cant get past the making of an app. It says to just pick one but they all come with some sort of additional set up that I cant figure out.
            Is there one in particular I should use to make this easier?
            I am an absolute beginner with all of this and its only by copy and paste I was able to get as far as I did with the basic magic mirror set up.
            I dont even know how to update it. Believe me Ive tried on both of these for hours.
            ? 1 Reply Last reply
              A Former User @Hellonoonan
              @hellonoonan
              Installation and Configuration is not so difficult. The only hard part is to get proper “token” from Facebook.
              Where are you stuck now? I can help you. Give me a mail (eouia0819@gmail.com) or a Telegram chat (@eouia)
              H Atelier-Made-in-iKiA 2 Replies Last reply
              • H
                Hellonoonan @Guest
                @sean wow thank you! Email sent
                • justjim1220J
                  justjim1220 Module Developer @Guest
                  @sean
                  I’m not sure what I may have done wrong, but it’s not showing the current amount of likes that my page has…
                  Page says this: Total Page Likes as of Today: 574
                  MMM-fbPageCounter shows: 0
                  would you be able to help me figure out what the problem is?
                  Jim Hallock - 1995
                  • H
                    Hellonoonan
                    I cant even get by step 2. I get this error
                    {“access_token”:“EAAE2ASglvOABADkkXv4DXzN0BNIGSbEpfcPk9ZBLtZAZBSgh1pgKueD0ZBbpw9jio4dzeTYpIkVkZBhwByiCe68eE9TuiSaHN1KNxiMDN5tdodeRjMyHUCTBoGwZBTBFk347mXfff3v6Xnk84uZBV9ZAjLtkqlPIFmoZD”,“token_type”:“bearer”,“expires_in”:5184000}
                    any idea what Im doing wrong?
                    justjim1220J 1 Reply Last reply
                    • justjim1220J
                      justjim1220 Module Developer @Hellonoonan
                      @hellonoonan
                      this is the token you need for the next step…
                      Jim Hallock - 1995
                      • H
                        Hellonoonan @justjim1220
                        @justjim1220 I think I may have gotten the info I need. What files do I need to change? Sorry I have no clue what Im doing. I added the code to the config.js file but it doesnt come up. Are there other files I need to alter?
                        justjim1220J 2 Replies Last reply
                        • justjim1220J
                          @hellonoonan
                          shouldn’t be, you just need to make sure you put in the correct tokens and codes in the right places.
                          Did you go all the way through the steps?
                          The last output should look something like this…
                             "data": [
                                   "access_token": "ABCDEFGHIJKLMNOPQRSTUVWXYZ123567890987654321ABCDEFGHIJKLMNOPQRSTUVWXYZ123567890987654321ABCDEFGHIJKLMNOPQRSTUVWXYZ123567890987654321ABCDEFGHIJKLMNOPQRSTUVWXYZ123567890987654321ABCDEFGHIJKLMNOPQRSTUVWXYZ123567890987654321",
                                   "category": "Computer Repair Service",
                                   "category_list": [
                                         "id": "123567890987654321",
                                         "name": "Computer Repair Service"
                                         "name": "Business Service"
                                   "name": "Hallock Technical Services",
                                   "tasks": [
                                      "ANALYZE",
                                      "ADVERTISE",
                                      "MODERATE",
                                      "CREATE_CONTENT",
                                      "MANAGE"
                             "paging": {
                                "cursors": {
                                   "before": "NDAxxxxxxxxxxxxxxxxxxxx",
                                   "after": "NDAxxxxxxxxxxxxxxxxxxxx"
                          You need the access_token & the LAST “id” from this data…
                          For example:
                          			disabled: false,
                          			module: "MMM-fbPageCounter",
                          			header: "Hallock Technical Services",
                          			position:"bottom_left",
                          				access_token: "ABCDEFGHIJKLMNOPQRSTUVWXYZ123567890987654321ABCDEFGHIJKLMNOPQRSTUVWXYZ123567890987654321ABCDEFGHIJKLMNOPQRSTUVWXYZ123567890987654321ABCDEFGHIJKLMNOPQRSTUVWXYZ123567890987654321ABCDEFGHIJKLMNOPQRSTUVWXYZ123567890987654321",
                          				page_id: "123567890987654321",
                          				refresh_interval_sec: 12, //minimum 10. If your daily visitors of page are under 10, use 30 as this value.
                          Hope this helps!
                          Jim Hallock - 1995
                          • justjim1220J
                            @hellonoonan
                            This is what I meant by the LAST “id”
                            from this section:
                                     "tasks": [
                                        "ANALYZE",
                                        "ADVERTISE",
                                        "MODERATE",
                                        "CREATE_CONTENT",
                                        "MANAGE"
                            Jim Hallock - 1995
                            • H
                              @justjim1220 I did not get that. I keep getting errors. Ive only been able to get the basic magic mirror modules to work by help forums and copy/paste. This is beyond my knowledge. Honestly Id rather venmo you like $10 to do this for me haha. It seems like its easy for those who know what theyre doing but I dont.
                              I have the screen up in my office similar to what the OP shows (without any mirror) just as an information screen and I think this would be a nice touch to boost social media presence.
                              Any interest in taking on the job?
                              • justjim1220J
                                @hellonoonan
                                I sent you a chat message
                                Jim Hallock - 1995
                                • justjim1220J
                                  @hellonoonan
                                  Not sure what venmo is, but no need to send money!
                                  Jim Hallock - 1995
                                  • justjim1220J
                                    here’s what mine looks like…
                                    Jim Hallock - 1995
                                    • Atelier-Made-in-iKiA
                                      Atelier-Made-in-iKi @Guest
                                      @Sean thanks you for your module, many steps to follow for final result but… wonderful effect!
                                      • H
                                        Hellonoonan
                                        I know this is an old thread but I am back again having issues. It stopped working for me and Ive been able to get all codes to work up until the permanent code. When I do this it only says data and nothing else.
                                        Shown below. I never get a permanent access code. Even with the long live one my counter is still at zero.
                                        “data”: [
                                        Please help! and thank you
