    690 Posts 77 Posters 3.3m Views 70 Watching
      JRCelis
      Trying to update my MMM-NOAA but I’m getting the following message.
      pi@raspberrypi:~/MagicMirror/modules/MMM-NOAA3 $ git pull
      Updating 083122c…747044d
      error: The following untracked working tree files would be overwritten by merge:
      latlon.json
      Please move or remove them before you merge.
      Aborting
      justjim1220J 1 Reply Last reply
      • justjim1220J
        justjim1220 Module Developer @JRCelis
        @jrcelis
        rename or delete that file from the NOAA3 directory,
        Then try again
        Jim Hallock - 1995
          JRCelis @justjim1220
          @justjim1220
          Thanks!
          • justjim1220J
            @jrcelis
            No Problem. Always glad to help out when I can! :smiling_face_with_sunglasses:
            Jim Hallock - 1995
            • cowboysdudeC
              Description:
              A fork of @Sean MMM-WeatherBackground but remade for NOAA3
              Please follow Readme on Github!
              Day
              Night
              Version 1.0.0
              Download:
              [card:cowboysdude/MMM-WeatherBackground]
              • V
                Vauxdvihl
                @cowboysdude
                Thanks for this great module noaa3
                One question
                is there a possiblity to increase the size of the module?
                Regards
                cowboysdudeC justjim1220J 2 Replies Last reply
                Reply Quote -1
                • cowboysdudeC
                  cowboysdude Module Developer @Vauxdvihl
                  @vauxdvihl
                  This will increase or decrease the body element on the page. You would put that in your custom.css file in the CSS directory.
                  …the ONLY way to make ONLY NOAA bigger is by editing the css file itself…
                  body {
                  zoom: 75%;
                  • G
                    Galm @cowboysdude
                    @cowboysdude : Hello, did you manage to make the openweather API to work with your module?
                    • cowboysdudeC
                      cowboysdude Module Developer @Galm
                      @galm Sir I am working on it and hopefully will make some progress tomorrow before football starts :)
                      justjim1220J G 2 Replies Last reply
                      • justjim1220J
                        justjim1220 Module Developer @cowboysdude
                        @cowboysdude
                        Dude! Cowboys season… :face_with_stuck-out_tongue_closed_eyes:
                        Jim Hallock - 1995
                        • cowboysdudeC
                          cowboysdude Module Developer @justjim1220
                          @justjim1220
                          alt text
                          • justjim1220J
                            @cowboysdude
                            Jim Hallock - 1995
                            • G
                              Galm @cowboysdude
                              @cowboysdude : thanks a lot ;) Football first
                              • justjim1220J
                                justjim1220 Module Developer @Vauxdvihl
                                @vauxdvihl
                                I made it bigger by changing the font and image values in the css file I use. WHich, I use the CSS4 option.
                                Jim Hallock - 1995
                                  PILuke
                                  has someone tested the NOAA3 module with accuweather provider?
                                  I think something is wrong to identify the city with lan and long.
                                  With this config I don’t see any weather information from the module, only air quality:
                                  			disabled: false,
                                  			module: 'MMM-NOAA3',
                                  		 	position: 'top_right',
                                  				provider: "accuweather",
                                  				apiKey: "xxxxxxxxxxxx",
                                  				airKey: "yyyyyyyyy",
                                  				css: "NOAA3",                  // THIS MUST CONTAIN A CSS STYLE NAME
                                  				userlat: "45.483219", //MUST HAVE BOTH
                                  				userlon: "9.203567"  //MUST HAVE BOTH
                                  In the aw.js file I find this request:
                                  url =  "http://dataservice.accuweather.com/currentconditions/v1/"+zip+"?apikey="+this.config.apiKey+"&details=true";
                                  I think this request doesn’t pass the correct “location key” (the zip value).
                                  Infact if I manually force a “location key” the “current conditions” start to work:
                                  url =  "http://dataservice.accuweather.com/currentconditions/v1/214046?apikey="+this.config.apiKey+"&language="+config.language+"-it&details=true";
                                  This instead doesn’t work for the forecast, if I force the “location key” the module doesn’t show the “four day forecast”
                                  url: "http://dataservice.accuweather.com/forecasts/v1/daily/5day/214046?apikey="+this.config.apiKey+"&language="+config.language+
                                  "-us&details=true&metric=false",
                                  I found also another problem with the language because in the request is passed the right language but not the right region, it remains “us”, so the module doesn’t show any value :
                                  &language="+config.language+"-us&details=true&metric=false"
                                  Can someone resolve the problem?
                                  I’m not so able with js :-)
                                  cowboysdudeC 2 Replies Last reply
                                  • cowboysdudeC
                                    cowboysdude Module Developer @PILuke
                                    @piluke I will look into it. However the one problem AW provider does have is at times when you’re just starting the module you have to reload it to get the 4 day forecast…why, I’m not really sure it’s just how it’s been working.
                                    I’ve made some changes but a few more need to be made here’s an example of the update:
                                    P 1 Reply Last reply
                                    • cowboysdudeC
                                      @piluke the updated aw.js is uploaded to git hub.
                                      Do a git pull and the config has changed to include your zip…
                                      REMEMBER YOU MAY HAVE TO RELOAD IT TO GET THE BOTTOM FORECAST…tis an accuweather issue…
                                      			disabled: false,
                                      				css: "NOAA3",
                                      				userlon: "9.203567"
                                      			        zip: "11111" //YOUR ZIPCODE
                                      • cowboysdudeC
                                        Still working on openweather api as time permits…it’s a complete train wreck LOL
                                        Something has changed…but I am working to fix it.
                                          PILuke @cowboysdude
                                          @cowboysdude many many thanks for your help and your time.
                                          Now the module is working.
                                          I can see current conditions and forecast (without reload the page) but … they are not correct. :-)
                                          I make some test, with my zip code the aw system identify a city in Mexico not in Italy!
                                          I think it’s necessary to identify a single locationKey with aw API.
                                          I found three way:
                                          by lat and lon:
                                          https://developer.accuweather.com/accuweather-locations-api/apis/get/locations/v1/cities/geoposition/search
                                          or by zip code:
                                          https://developer.accuweather.com/accuweather-locations-api/apis/get/locations/v1/postalcodes/search
                                          or by name:
                                          https://developer.accuweather.com/accuweather-locations-api/apis/get/locations/v1/cities/search
                                          but i don’t know how to use it in javascript…
                                          Infact if I put (in config.js) the right locationKey for my city instead zipcode the module work perfectly.
                                          • cowboysdudeC
                                            @piluke Okay so use your location key LOL
                                            • 26
                                            • 27
                                            • 28
                                            • 29
                                            • 30
                                            • 34
                                            • 35
                                            • 28 / 35
