    690 Posts 77 Posters 3.3m Views 70 Watching
    • cowboysdudeC
      Maybe someone did but it certainly wasn’t me… but feel free to play with the css if you’d like.
      • cowboysdudeC
        Stay tuned I’ve modified Sean’s MMM-WeatherBackground to work with NOAA3 :) Working out some bugs but should be released soon!
        • cowboysdudeC
          A little sample…
          Mykle1M 1 Reply Last reply
          Reply Quote 2
          • Mykle1M
            @cowboysdude
            I hate you! :-)
            Reply Quote 2
            • cowboysdudeC
              @mykle1 Don’t hate me… @Sean made it… I just adapted it to NOAA3 LOL
              • cowboysdudeC
                Description:
                Added Moon Phases and some style updates
                Please follow Readme on Github!
                To update just do a ‘git pull’ in the MagicMirror/modules/MMM-NOAA3 directory
                Version 3.2.2
                Download:
                [card:cowboysdude/MMM-NOAA3]
                • H
                  Hubschra01
                  Hi together,
                  I´m new on this nice modul.
                  I install and setup the module and use Openweather. The measurements are shown on the Mirror but without any Unit. (% or °C…) And the Images of Sun and Moon and the 4 day Forecast will not appear. Anybody know the Mistakes I do in the Setup. I don´t use the AQI Key because is not nessesary for me.
                  In the Termial I got some Whoops… I show below…
                  TypeError: Cannot read property 'length' of undefined
                      at Object.parseForecast (/home/pi/MagicMirror/modules/MMM-NOAA3/providers/ow.js:184:42)
                      at Request.request [as _callback] (/home/pi/MagicMirror/modules/MMM-NOAA3/providers/ow.js:55:17)
                      at Request.self.callback (/home/pi/MagicMirror/modules/MMM-NOAA3/node_modules/request/request.js:185:22)
                      at emitTwo (events.js:126:13)
                      at Request.emit (events.js:214:7)
                      at Request.<anonymous> (/home/pi/MagicMirror/modules/MMM-NOAA3/node_modules/request/request.js:1161:10)
                      at emitOne (events.js:116:13)
                      at Request.emit (events.js:211:7)
                      at IncomingMessage.<anonymous> (/home/pi/MagicMirror/modules/MMM-NOAA3/node_modules/request/request.js:1083:12)
                      at Object.onceWrapper (events.js:313:30)
                  If you think this really is an issue, please open an issue on GitHub: https://gi                                   thub.com/MichMich/MagicMirror/issues
                  SyntaxError: Unexpected token c in JSON at position 0
                      at JSON.parse (<anonymous>)
                      at Object.parseUV (/home/pi/MagicMirror/modules/MMM-NOAA3/providers/ow.js:74:23)
                      at Request.request [as _callback] (/home/pi/MagicMirror/modules/MMM-NOAA3/providers/ow.js:69:17)
                  • G
                    Galm
                    I am trying to use your new module. I was using the previous one with openweathermap. I can’t get any info display on the screen as you can seen below :
                    FYI : my API key is working well with the default weather module and i use you API airkey on your 1st module without any problems
                    If i do understand well in your ow.js, you use this 1st url : http://api.openweathermap.org/data/2.5/forecast/daily?lat=“+this.config.userlat+”&lon=“+this.config.userlon+”&units=imperial&appid="+this.config.apiKey;
                    At 1st sight : you missed the use of one variable. Should it be written like this : http://api.openweathermap.org/data/2.5/forecast/daily?lat=“+this.config.userlat+”&lon=“+this.config.userlon+”&units=“+this.config.units+”&appid="+this.config.apiKey; ?
                    Another thing : daily forcast are not allowed in free plan so this url won"t work with free plan. I tested it on my browser, to get the forcast I have to use : http://api.openweathermap.org/data/2.5/forecast?lat=“+this.config.userlat+”&lon=“+this.config.userlon+”&units=imperial&appid="+this.config.apiKey; -> i don’t have any idea if you retrieve the info needed in your parser.
                    Hope it helps to debug my problems :)
                    Thanks a lot for your work
                    • cowboysdudeC
                      Thank you to @revere521 for finding a problem I didn’t even know existed!! Missing a file that the module is looking for!! I’ll fix that~ :)
                      ALL fixed…do a git pull and all will be well :)
                      • cowboysdudeC
                        cowboysdude Module Developer @Galm
                        @galm Do a git pull in the MagicMirror/modules/MMM-NOAA3 dir and it will work for you ;)
                        G 2 Replies Last reply
                        • G
                          Galm @cowboysdude
                          @cowboysdude said in MMM-NOAA - Another Weather Module:
                          MMM-NOAA3
                          It did not change anything :( still not showing any values
                          • H
                            Hubschra01
                            I do the git pull too, but I still get the Errors in the Terminalwindow shown on top.
                            No Forecast and now measurement units
                            The Api request work in the Browser for my coordinates an id.
                            Any Ideas.
                            • cowboysdudeC
                              What provider are you using? OpenWeather is proving to be a problem but I’m working on it.
                              H 1 Reply Last reply
                              • H
                                Hubschra01 @cowboysdude
                                @cowboysdude
                                Yes im Using Openweather
                                  JRCelis
                                  Trying to update my MMM-NOAA but I’m getting the following message.
                                  pi@raspberrypi:~/MagicMirror/modules/MMM-NOAA3 $ git pull
                                  Updating 083122c…747044d
                                  error: The following untracked working tree files would be overwritten by merge:
                                  latlon.json
                                  Please move or remove them before you merge.
                                  Aborting
                                  justjim1220J 1 Reply Last reply
                                  • justjim1220J
                                    justjim1220 Module Developer @JRCelis
                                    @jrcelis
                                    rename or delete that file from the NOAA3 directory,
                                    Then try again
                                    Jim Hallock - 1995
                                      JRCelis @justjim1220
                                      @justjim1220
                                      Thanks!
                                      • justjim1220J
                                        @jrcelis
                                        No Problem. Always glad to help out when I can! :smiling_face_with_sunglasses:
                                        Jim Hallock - 1995
                                        • cowboysdudeC
                                          Description:
                                          A fork of @Sean MMM-WeatherBackground but remade for NOAA3
                                          Day
                                          Night
                                          Version 1.0.0
                                          Download:
                                          [card:cowboysdude/MMM-WeatherBackground]
                                          • V
                                            Vauxdvihl
                                            @cowboysdude
                                            Thanks for this great module noaa3
                                            One question
                                            is there a possiblity to increase the size of the module?
                                            Regards
                                            cowboysdudeC justjim1220J 2 Replies Last reply
                                            Reply Quote -1
                                            • 25
                                            • 26
                                            • 27
                                            • 28
                                            • 29
                                            • 34
                                            • 35
                                            • 27 / 35
