    690 Posts 77 Posters 2.9m Views 70 Watching
    • E Offline
      epi
      Did someone managed to change css to make this module look more like this?
      Or like this
        Mykle1 Project Sponsor Module Developer @epi
        @epi said in MMM-NOAA - Another Weather Module:
        What you’re describing looks alot like the default weather module. Go figure.
        • cowboysdudeC Offline
          Maybe someone did but it certainly wasn’t me… but feel free to play with the css if you’d like.
            Stay tuned I’ve modified Sean’s MMM-WeatherBackground to work with NOAA3 :) Working out some bugs but should be released soon!
              A little sample…
                @cowboysdude
                I hate you! :-)
                  @mykle1 Don’t hate me… @Sean made it… I just adapted it to NOAA3 LOL
                    Description:
                    Added Moon Phases and some style updates
                    Please follow Readme on Github!
                    To update just do a ‘git pull’ in the MagicMirror/modules/MMM-NOAA3 directory
                    Version 3.2.2
                    Download:
                    [card:cowboysdude/MMM-NOAA3]
                    • H Offline
                      Hubschra01
                      Hi together,
                      I´m new on this nice modul.
                      I install and setup the module and use Openweather. The measurements are shown on the Mirror but without any Unit. (% or °C…) And the Images of Sun and Moon and the 4 day Forecast will not appear. Anybody know the Mistakes I do in the Setup. I don´t use the AQI Key because is not nessesary for me.
                      In the Termial I got some Whoops… I show below…
                      TypeError: Cannot read property 'length' of undefined
                          at Object.parseForecast (/home/pi/MagicMirror/modules/MMM-NOAA3/providers/ow.js:184:42)
                          at Request.request [as _callback] (/home/pi/MagicMirror/modules/MMM-NOAA3/providers/ow.js:55:17)
                          at Request.self.callback (/home/pi/MagicMirror/modules/MMM-NOAA3/node_modules/request/request.js:185:22)
                          at emitTwo (events.js:126:13)
                          at Request.emit (events.js:214:7)
                          at Request.<anonymous> (/home/pi/MagicMirror/modules/MMM-NOAA3/node_modules/request/request.js:1161:10)
                          at emitOne (events.js:116:13)
                          at Request.emit (events.js:211:7)
                          at IncomingMessage.<anonymous> (/home/pi/MagicMirror/modules/MMM-NOAA3/node_modules/request/request.js:1083:12)
                          at Object.onceWrapper (events.js:313:30)
                      If you think this really is an issue, please open an issue on GitHub: https://gi                                   thub.com/MichMich/MagicMirror/issues
                      SyntaxError: Unexpected token c in JSON at position 0
                          at JSON.parse (<anonymous>)
                          at Object.parseUV (/home/pi/MagicMirror/modules/MMM-NOAA3/providers/ow.js:74:23)
                          at Request.request [as _callback] (/home/pi/MagicMirror/modules/MMM-NOAA3/providers/ow.js:69:17)
                      • G Offline
                        Galm
                        I am trying to use your new module. I was using the previous one with openweathermap. I can’t get any info display on the screen as you can seen below :
                        FYI : my API key is working well with the default weather module and i use you API airkey on your 1st module without any problems
                        If i do understand well in your ow.js, you use this 1st url : http://api.openweathermap.org/data/2.5/forecast/daily?lat=“+this.config.userlat+”&lon=“+this.config.userlon+”&units=imperial&appid="+this.config.apiKey;
                        At 1st sight : you missed the use of one variable. Should it be written like this : http://api.openweathermap.org/data/2.5/forecast/daily?lat=“+this.config.userlat+”&lon=“+this.config.userlon+”&units=“+this.config.units+”&appid="+this.config.apiKey; ?
                        Another thing : daily forcast are not allowed in free plan so this url won"t work with free plan. I tested it on my browser, to get the forcast I have to use : http://api.openweathermap.org/data/2.5/forecast?lat=“+this.config.userlat+”&lon=“+this.config.userlon+”&units=imperial&appid="+this.config.apiKey; -> i don’t have any idea if you retrieve the info needed in your parser.
                        Hope it helps to debug my problems :)
                        Thanks a lot for your work
                          Thank you to @revere521 for finding a problem I didn’t even know existed!! Missing a file that the module is looking for!! I’ll fix that~ :)
                          ALL fixed…do a git pull and all will be well :)
                            cowboysdude Module Developer @Galm
                            @galm Do a git pull in the MagicMirror/modules/MMM-NOAA3 dir and it will work for you ;)
                            G 2 Replies Last reply Reply Quote 0
                            • G Offline
                              Galm @cowboysdude
                              @cowboysdude said in MMM-NOAA - Another Weather Module:
                              MMM-NOAA3
                              It did not change anything :( still not showing any values
                              • H Offline
                                Hubschra01
                                I do the git pull too, but I still get the Errors in the Terminalwindow shown on top.
                                No Forecast and now measurement units
                                The Api request work in the Browser for my coordinates an id.
                                Any Ideas.
                                  What provider are you using? OpenWeather is proving to be a problem but I’m working on it.
                                  • H Offline
                                    Hubschra01 @cowboysdude
                                    @cowboysdude
                                    Yes im Using Openweather
                                      JRCelis
                                      Trying to update my MMM-NOAA but I’m getting the following message.
                                      pi@raspberrypi:~/MagicMirror/modules/MMM-NOAA3 $ git pull
                                      Updating 083122c…747044d
                                      error: The following untracked working tree files would be overwritten by merge:
                                      latlon.json
                                      Please move or remove them before you merge.
                                      Aborting
                                      • justjim1220J Offline
                                        justjim1220 Module Developer @JRCelis
                                        @jrcelis
                                        rename or delete that file from the NOAA3 directory,
                                        Then try again
                                        "Life's Too Short To Dance With Ugly People"
                                        Jim Hallock - 1995
                                          JRCelis @justjim1220
                                          @justjim1220
                                          Thanks!
                                          justjim1220J 1 Reply Last reply Reply Quote 1
                                            @jrcelis
                                            No Problem. Always glad to help out when I can! :smiling_face_with_sunglasses:
                                            Jim Hallock - 1995
                                            • 25
                                            • 26
                                            • 27
                                            • 28
                                            • 29
                                            • 34
                                            • 35
                                            • 27 / 35
