    690 Posts 77 Posters 2.9m Views 70 Watching
    • cowboysdudeC Offline
      A little sample…
        @cowboysdude
        I hate you! :-)
          @mykle1 Don’t hate me… @Sean made it… I just adapted it to NOAA3 LOL
            Description:
            Added Moon Phases and some style updates
            Please follow Readme on Github!
            To update just do a ‘git pull’ in the MagicMirror/modules/MMM-NOAA3 directory
            Version 3.2.2
            Download:
            [card:cowboysdude/MMM-NOAA3]
            • H Offline
              Hubschra01
              Hi together,
              I´m new on this nice modul.
              I install and setup the module and use Openweather. The measurements are shown on the Mirror but without any Unit. (% or °C…) And the Images of Sun and Moon and the 4 day Forecast will not appear. Anybody know the Mistakes I do in the Setup. I don´t use the AQI Key because is not nessesary for me.
              In the Termial I got some Whoops… I show below…
              TypeError: Cannot read property 'length' of undefined
                  at Object.parseForecast (/home/pi/MagicMirror/modules/MMM-NOAA3/providers/ow.js:184:42)
                  at Request.request [as _callback] (/home/pi/MagicMirror/modules/MMM-NOAA3/providers/ow.js:55:17)
                  at Request.self.callback (/home/pi/MagicMirror/modules/MMM-NOAA3/node_modules/request/request.js:185:22)
                  at emitTwo (events.js:126:13)
                  at Request.emit (events.js:214:7)
                  at Request.<anonymous> (/home/pi/MagicMirror/modules/MMM-NOAA3/node_modules/request/request.js:1161:10)
                  at emitOne (events.js:116:13)
                  at Request.emit (events.js:211:7)
                  at IncomingMessage.<anonymous> (/home/pi/MagicMirror/modules/MMM-NOAA3/node_modules/request/request.js:1083:12)
                  at Object.onceWrapper (events.js:313:30)
              If you think this really is an issue, please open an issue on GitHub: https://gi                                   thub.com/MichMich/MagicMirror/issues
              SyntaxError: Unexpected token c in JSON at position 0
                  at JSON.parse (<anonymous>)
                  at Object.parseUV (/home/pi/MagicMirror/modules/MMM-NOAA3/providers/ow.js:74:23)
                  at Request.request [as _callback] (/home/pi/MagicMirror/modules/MMM-NOAA3/providers/ow.js:69:17)
              • G Offline
                Galm
                I am trying to use your new module. I was using the previous one with openweathermap. I can’t get any info display on the screen as you can seen below :
                FYI : my API key is working well with the default weather module and i use you API airkey on your 1st module without any problems
                If i do understand well in your ow.js, you use this 1st url : http://api.openweathermap.org/data/2.5/forecast/daily?lat=“+this.config.userlat+”&lon=“+this.config.userlon+”&units=imperial&appid="+this.config.apiKey;
                At 1st sight : you missed the use of one variable. Should it be written like this : http://api.openweathermap.org/data/2.5/forecast/daily?lat=“+this.config.userlat+”&lon=“+this.config.userlon+”&units=“+this.config.units+”&appid="+this.config.apiKey; ?
                Another thing : daily forcast are not allowed in free plan so this url won"t work with free plan. I tested it on my browser, to get the forcast I have to use : http://api.openweathermap.org/data/2.5/forecast?lat=“+this.config.userlat+”&lon=“+this.config.userlon+”&units=imperial&appid="+this.config.apiKey; -> i don’t have any idea if you retrieve the info needed in your parser.
                Hope it helps to debug my problems :)
                Thanks a lot for your work
                  Thank you to @revere521 for finding a problem I didn’t even know existed!! Missing a file that the module is looking for!! I’ll fix that~ :)
                  ALL fixed…do a git pull and all will be well :)
                    cowboysdude Module Developer @Galm
                    @galm Do a git pull in the MagicMirror/modules/MMM-NOAA3 dir and it will work for you ;)
                    G 2 Replies Last reply Reply Quote 0
                    • G Offline
                      Galm @cowboysdude
                      @cowboysdude said in MMM-NOAA - Another Weather Module:
                      MMM-NOAA3
                      It did not change anything :( still not showing any values
                      • H Offline
                        Hubschra01
                        I do the git pull too, but I still get the Errors in the Terminalwindow shown on top.
                        No Forecast and now measurement units
                        The Api request work in the Browser for my coordinates an id.
                        Any Ideas.
                          What provider are you using? OpenWeather is proving to be a problem but I’m working on it.
                          • H Offline
                            Hubschra01 @cowboysdude
                            @cowboysdude
                            Yes im Using Openweather
                              JRCelis
                              Trying to update my MMM-NOAA but I’m getting the following message.
                              pi@raspberrypi:~/MagicMirror/modules/MMM-NOAA3 $ git pull
                              Updating 083122c…747044d
                              error: The following untracked working tree files would be overwritten by merge:
                              latlon.json
                              Please move or remove them before you merge.
                              Aborting
                              • justjim1220J Offline
                                justjim1220 Module Developer @JRCelis
                                @jrcelis
                                rename or delete that file from the NOAA3 directory,
                                Then try again
                                "Life's Too Short To Dance With Ugly People"
                                Jim Hallock - 1995
                                  JRCelis @justjim1220
                                  @justjim1220
                                  Thanks!
                                  justjim1220J 1 Reply Last reply Reply Quote 1
                                    @jrcelis
                                    No Problem. Always glad to help out when I can! :smiling_face_with_sunglasses:
                                    Jim Hallock - 1995
                                      Description:
                                      A fork of @Sean MMM-WeatherBackground but remade for NOAA3
                                      Day
                                      Night
                                      Version 1.0.0
                                      Download:
                                      [card:cowboysdude/MMM-WeatherBackground]
                                      • V Offline
                                        Vauxdvihl
                                        @cowboysdude
                                        Thanks for this great module noaa3
                                        One question
                                        is there a possiblity to increase the size of the module?
                                        Regards
                                        cowboysdudeC justjim1220J 2 Replies Last reply Reply Quote -1
                                          cowboysdude Module Developer @Vauxdvihl
                                          @vauxdvihl
                                          This will increase or decrease the body element on the page. You would put that in your custom.css file in the CSS directory.
                                          …the ONLY way to make ONLY NOAA bigger is by editing the css file itself…
                                          body {
                                          zoom: 75%;
                                          • G Offline
                                            Galm @cowboysdude
                                            @cowboysdude : Hello, did you manage to make the openweather API to work with your module?
                                            • 25
                                            • 26
                                            • 27
                                            • 28
                                            • 29
                                            • 34
                                            • 35
                                            • 27 / 35
