    Strip Down Guide for BenQ 28" VA Monitor GC2870H
    61 Posts 10 Posters 77.7k Views 10 Watching
      MadScientist
      Are you sure the touch sensor works behind the mirror? It’s pretty expensive and it would be a pity if it doesn’t. Touch-anything generally doesn’t work behind the mirror because of the metallic coating.
      What mirror are you using and where did you get it from? I am still looking for a better alternative for mine. Not very happy with the transmission of only 8%.
      Y 2 Replies Last reply Reply Quote 0
      • Y
        yep_DD @MadScientist
        @madscientist that is what I am afraid of as well, the metal coating sure does not help… but worst case I will put them on the aluminum frame below from the outside and a nice cover on top
        I got the mirror from here: Glas-star.de
        • Y
          @madscientist you were right, it does not work well behind the mirror. I will keep the sensor anyway as the way it is designed it is easier to affix to my aluminum frame. I am now thinking of getting small black plexiglas casing to attach to the bottom part to control the mirror and make it look nice… let’s see.
          So this could be the plan:
          • Plexiglas with Cutout letters
          • behind that translucent plexiglas
          • glue together
          • LED Strip on top of translucent glas to illuminate the cutout letters
          • enjoy?
          • Y
            yep_DD
            I am just going to follow up on that, I found a different solution. I am using a HUE Dimmer Switch that is controlled via FHEM and it controls a python script running on MagicMirror to play my podcast and change the volume:
            (I found that script somewhere on github and modified it a bit)
            #!/usr/bin/python3 -u
            host_name = '10.0.1.49'
            host_port = 8000
            import RPi.GPIO as GPIO
            import os
            import subprocess
            import signal
            from subprocess import call
            from time import sleep
            from http.server import BaseHTTPRequestHandler, HTTPServer
            class MyServer(BaseHTTPRequestHandler):
                def do_HEAD(self):
                    self.send_response(200)
                    self.send_header('Content-type', 'text/html')
                    self.end_headers()
                def do_GET(self):
                    global proc
                    html = '''
                       <html>
                       <body style="width:960px; margin: 20px auto;">
                       <h1>Magic Mirror Control</h1>
                       <p>Current GPU temperature is {}</p>
                       <p>Podcast: <a href="/play">Play</a> <a href="/stop">Stop</a></p>
                       <p>Volume: <a href="/down">down</a> <a href="/up">up</a></p>
                       <p>System: <a href="/shutdown">Shutdown</a> <a href="/restart">Restart</a></p>
                       <div id="podcast-status"></div>
                       <script>
                           document.getElementById("podcast-status").innerHTML="{}";
                       </script>
                       </body>
                       </html>
                    temp = os.popen("/opt/vc/bin/vcgencmd measure_temp").read()
                    self.do_HEAD()
                    status = ''
                    if self.path=='/':
                        status='nothing'
                    elif self.path=='/play':
                        proc = subprocess.Popen(["omxplayer", "-o", "alsa:hw:ALSA", "--no-osd", "/tmp/video.mp4"], preexec_fn=os.setsid)
                        status='Playing Podcast'
                    elif self.path=='/stop':
                        status='Stopping Podcast'
                        os.killpg(os.getpgid(proc.pid), signal.SIGTERM)
                    elif self.path=='/shutdown':
                        status='Shutdown'
                        subprocess.Popen(["sudo", "shutdown", "-h", "now"], preexec_fn=os.setsid)
                    elif self.path=='/restart':
                        status='Restart'
                        subprocess.Popen(["sudo", "reboot"], preexec_fn=os.setsid)
                    elif self.path=='/down':
                        status='Volume down'
                        subprocess.Popen(["amixer", "set", "Master", "12%-"], preexec_fn=os.setsid)
                    elif self.path=='/up':
                        status='Volume up'
                        subprocess.Popen(["amixer", "set", "Master", "12%+"], preexec_fn=os.setsid)
                    self.wfile.write(html.format(temp[5:], status).encode("utf-8"))
            if __name__ == '__main__':
                http_server = HTTPServer((host_name, host_port), MyServer)
                print("Server Starts - %s:%s" % (host_name, host_port))
                try:
                    http_server.serve_forever()
                except KeyboardInterrupt:
                    http_server.server_close()
            • A
              Adrien
              Would it be possible to use a relay to power/unpower the screen ? On the sheet you show pin 3/4 power the backlight correct?
              M Y 2 Replies Last reply Reply Quote 0
                MadScientist @Adrien
                @adrien check out this forum thread. cruunnerr explains different methods on how to turn on/off your screen. He helped me setting up my system which uses a relay and PIR-sensor to power on/off my LCD. I think that’s what you’re looking for.
                • A
                  Adrien
                  Well i’m not sure, i don’t use the magic mirror OS but home made application. I use a pir sensor, i would like to have instant poweron/poweroff without any OSD message on screen. So My question was if i cut the pin 3 or 4 on the backlight connector will it work ? To be clear when the PIR detect someone the relay connect the PIN (3 or 4) after few seconds relay disconnect the PIN (3 or 4)
                    @adrien That should still be possible with the script method described in 5.1. Instead of the power lines for the controller board of the LCD you use the cables that lead to your backlight.
                    I don’t know what LCD you have. Some have an extra inverter or LED driver board. You can take the cables from there. Some have a 40 pin LVDS cable (instead of 30 pin), so you have to check the datasheet which wires are for the backlight. I’d take the VCC wire for the backlight, snip it and connect both lose ends to the relay. That should work.
                    Keep in mind that with this method the LCD is always on, only the backlight is off.
                    • A
                      Adrien
                      Thanks for your help. I use the same model :BenQGC2870H. I would like to combine a solution where i have a minimum power consumption and fast without osd message boot.
                      • Y
                        yep_DD @Adrien
                        @adrien Hi Adrien, that was my initial plan but I use the two relays now for my speakers to avoid the initial crack sound when powering on the amplifier und I use one relay for the monitor power supply and one for the amplifier.
                        • A
                          Adrien @yep_DD
                          @yep_dd Hello, and thanks for your guide :) Did you try to do it ? do you confirm that could work ? Thanks
                          • Y
                            yep_DD
                            @Adrien No problem, I am pretty sure it should work but I have not tried it. I might in the future. I am working on a few other bugifxes as well (amplifier only turns on when sound is played and stuff like that). I also suggest to use the microwave / radar sensor instead of the PIR. it is much cleaner and can go behind the mirror.
                            Regarding the OSD, instead of cutting wires to the backlight this seems like a valuable option. At the moment I can’t try this (I need a friend to help me take down the mirror as it is too heavy), but I will tomorrow: https://www.youtube.com/watch?v=y86AXOZwlgU (TL;DW: press menu button while turning monitor on and disable logo)
                            • A
                              Adrien
                              Interesting solution this is the hidden menu of the display. The problem is the boot time i feel like it takes a long time to boot no ? well i will also try to cut the wire if it doesn’t work properly i will solder them. About the microwave sensor i have a rcwl0516 to test but the problem is the range of detection it detect people from a very large range
                              • Y
                                yep_DD @Adrien
                                @Adrien ah, okay I see… yes that might be a problem in my case it works just fine. I will see about the boot time tomorrow.
                                • Y
                                  yep_DD @Adrien
                                  @adrien Okay, so it is about 3 seconds boot time I am estimating. No logo anymore. Just the annoying “HDMI1” screen on the lower right. Let’s see if that satisfies me or I will cut the wires as well. Have you tried yet?
                                  M A 2 Replies Last reply Reply Quote 0
                                    MadScientist @yep_DD
                                    @yep_dd You could use relay with a small delay to power your backlight. So the screen will only be visible after the “HDMI1” box disappeared. Personally I wouldn’t bother with it, though.
                                    • A
                                      Adrien @yep_DD
                                      @yep_dd I have not yet try, i will do my test as soon as i receive my mirror, but 3 secs look not too long
                                      • Y
                                        @madscientist okay, so after a couple of days I am absolutely satisfied. I turn on my monitor with a small httpserver python script whenever someone is at home and -if it is night- any HUE light is on. I am now thinking of changing this to different energy saving modes in my magicmirror:
                                        • Always On
                                        • On when someone is home
                                        • On when someone is home and any light is on (turns off at night)
                                        • Only on when activated by PIR / Radar Sensor
                                        • A
                                          Adrien
                                          I have removed the boot logo, but it’s around 5 seconds to start the display and the “hdmi” message is there. I will try to cut the wire in the next days.
                                            Daniel3490
                                            @yep_dd
                                            Nice project, I got the same glass but a different monitor.
                                            At my mirror the backlite seems to bright so it’s easy to locate the edge of the monitor.
                                            Could you take some pictures for me to be sure it’s my monitor and not a general problem with the type of glas?
                                            If it’s different to yours I might have to invest in a different monitor. 😅
                                            • 2 / 4
