Strip Down Guide for BenQ 28" VA Monitor GC2870H
Well i’m not sure, i don’t use the magic mirror OS but home made application. I use a pir sensor, i would like to have instant poweron/poweroff without any OSD message on screen. So My question was if i cut the pin 3 or 4 on the backlight connector will it work ? To be clear when the PIR detect someone the relay connect the PIN (3 or 4) after few seconds relay disconnect the PIN (3 or 4)
@adrien That should still be possible with the script method described in 5.1. Instead of the power lines for the controller board of the LCD you use the cables that lead to your backlight.
I don’t know what LCD you have. Some have an extra inverter or LED driver board. You can take the cables from there. Some have a 40 pin LVDS cable (instead of 30 pin), so you have to check the datasheet which wires are for the backlight. I’d take the VCC wire for the backlight, snip it and connect both lose ends to the relay. That should work.
Keep in mind that with this method the LCD is always on, only the backlight is off.
Thanks for your help. I use the same model :BenQGC2870H. I would like to combine a solution where i have a minimum power consumption and fast without osd message boot.
@adrien Hi Adrien, that was my initial plan but I use the two relays now for my speakers to avoid the initial crack sound when powering on the amplifier und I use one relay for the monitor power supply and one for the amplifier.
@yep_dd Hello, and thanks for your guide :) Did you try to do it ? do you confirm that could work ? Thanks
@Adrien No problem, I am pretty sure it should work but I have not tried it. I might in the future. I am working on a few other bugifxes as well (amplifier only turns on when sound is played and stuff like that). I also suggest to use the microwave / radar sensor instead of the PIR. it is much cleaner and can go behind the mirror.
Regarding the OSD, instead of cutting wires to the backlight this seems like a valuable option. At the moment I can’t try this (I need a friend to help me take down the mirror as it is too heavy), but I will tomorrow: https://www.youtube.com/watch?v=y86AXOZwlgU (TL;DW: press menu button while turning monitor on and disable logo)
Interesting solution this is the hidden menu of the display. The problem is the boot time i feel like it takes a long time to boot no ? well i will also try to cut the wire if it doesn’t work properly i will solder them. About the microwave sensor i have a rcwl0516 to test but the problem is the range of detection it detect people from a very large range
@Adrien ah, okay I see… yes that might be a problem in my case it works just fine. I will see about the boot time tomorrow.
@adrien Okay, so it is about 3 seconds boot time I am estimating. No logo anymore. Just the annoying “HDMI1” screen on the lower right. Let’s see if that satisfies me or I will cut the wires as well. Have you tried yet?
@yep_dd You could use relay with a small delay to power your backlight. So the screen will only be visible after the “HDMI1” box disappeared. Personally I wouldn’t bother with it, though.
@yep_dd I have not yet try, i will do my test as soon as i receive my mirror, but 3 secs look not too long
@madscientist okay, so after a couple of days I am absolutely satisfied. I turn on my monitor with a small httpserver python script whenever someone is at home and -if it is night- any HUE light is on. I am now thinking of changing this to different energy saving modes in my magicmirror:
- Always On
- On when someone is home
- On when someone is home and any light is on (turns off at night)
- Only on when activated by PIR / Radar Sensor
I have removed the boot logo, but it’s around 5 seconds to start the display and the “hdmi” message is there. I will try to cut the wire in the next days.
@yep_dd
Nice project, I got the same glass but a different monitor.
At my mirror the backlite seems to bright so it’s easy to locate the edge of the monitor.
Could you take some pictures for me to be sure it’s my monitor and not a general problem with the type of glas?
If it’s different to yours I might have to invest in a different monitor. 😅 -
@daniel3490 hi Daniel, it is bit hard to take down the mirror by myself, i have to wait until I have a friend over to help me. I don’t really see the edges of my monitor unless it is really really dark.
Hi @yep_DD
Fantastic Work !
May I ask how did you connect your rcwl0516 sensor and what module did you use to integrate it with MM? Are there any instructions I can follow?
Thanks.
@bachoo786 The sensor should have three pins: VCC, GND and signal out. You connect them the same way you connect a PIR sensor and it should also work with the same MM module MMM-PIR-Sensor.
Hi @bachoo786
thank you so much. As @MadScientist pointed out the three pins are connected directly to the Raspberry. For evaluating the state I use a small http server (see below). The important parts are where the you can find anything with
monitorStatusIf you want I can reduce the code to what is important for you. This is the complete server which allows control of
- ARD Livestream
- ARD Tagesschau
- Lowering / Increasing volume
- Radar Sensor (just the last couple lines of code (search for: GPIO.add_event_detect)
- Powerin On / Off Monitor by http Request (used if no one is at home / and at night)
For me the radar sensor is just a backup. I use the power control mainly like this:
- If someone is at home and it is between sunrise / sunset, turn on the monitor(1)
- If someone is at home but it is night and all lights are off, turn off the monitor(1)
- If someone is in front of the monitor turn it on by radar
(1) is done via FHEM (a home automation running on another raspberry, it calls my mirror like this: 10.0.1.49/on (monitor on) 10.0.1.49/off (monitor off) 10.0.1.49/up or /down (for volume) and so on.
#!/usr/bin/python3 -u host_name = '10.0.1.49' # Change this to your Raspberry Pi IP address host_port = 8000 proc = '' monitorstatus = 'unknown' import RPi.GPIO as GPIO from pathlib import Path import os import subprocess import signal from subprocess import call from time import sleep from http.server import BaseHTTPRequestHandler, HTTPServer SENSOR_PIN = 24 GPIO.setmode(GPIO.BCM) GPIO.setup(SENSOR_PIN, GPIO.IN) class MyServer(BaseHTTPRequestHandler): def monitor_on(channel): #define initial status of Monitor if monitorstatus!="on": status='Monitor on by Radar Sensor' #monitorstatus='on' subprocess.Popen(["/usr/bin/vcgencmd", "display_power", "1"], preexec_fn=os.setsid) def do_HEAD(self): self.send_response(200) self.send_header('Content-type', 'text/html') self.end_headers() def do_GET(self): global proc global monitorstatus html = ''' <html> <body style="width:960px; margin: 20px auto;"> <h1>Magic Mirror Control</h1> <p>Current GPU temperature is {}</p> <p>Podcast: <a href="/play">Play</a> <a href="/stop">Stop</a></p> <p>ARD Livestream: <a href="/ard">Play</a> <a href="/stop">Stop</a></p> <p>Volume: <a href="/down">down</a> <a href="/up">up</a></p> <p>System: <a href="/shutdown">Shutdown</a> <a href="/restart">Restart</a></p> <p>Monitor: <a href="/on">On</a> <a href="/off">Off</a></p> <div id="podcast-status"></div> <script> document.getElementById("podcast-status").innerHTML="{}"; </script> </body> </html> ''' temp = os.popen("/opt/vc/bin/vcgencmd measure_temp").read() self.do_HEAD() status = '' if self.path=='/': #GPIO.setmode(GPIO.BCM) #GPIO.setwarnings(False) #GPIO.setup(17, GPIO.IN) status='nothing' elif self.path=='/play': if proc=='': my_file = Path("/home/pi/MagicMirror/video.mp4") if my_file.is_file(): statinfo = os.stat('/home/pi/MagicMirror/video.mp4') if statinfo.st_size > 0: proc = subprocess.Popen(["omxplayer", "-o", "alsa:hw:ALSA", "--no-osd", "/home/pi/MagicMirror/video.mp4"], preexec_fn=os.setsid) status='Playing Podcast' else: proc = subprocess.Popen(["omxplayer", "-o", "alsa:hw:ALSA", "--no-osd", "/home/pi/MagicMirror/Loading.mp4"], preexec_fn=os.setsid) status='Not yet available' else: proc = subprocess.Popen(["omxplayer", "-o", "alsa:hw:ALSA", "--no-osd", "/home/pi/MagicMirror/Loading.mp4"], preexec_fn=os.setsid) status='Not yet available' else: status='Stopping Podcast' os.killpg(os.getpgid(proc.pid), signal.SIGTERM) proc='' elif self.path=='/ard': if proc=='': proc = subprocess.Popen(["livestreamer", "hlsvariant://daserste_live-lh.akamaihd.net/i/daserste_de@91204/master.m3u8", "best", "-vnp", "omxplayer -o alsa:hw:ALSA --no-osd --timeout 20"], preexec_fn=os.setsid) status='Playing ARD Livestream' else: status='Stopping Stream' os.killpg(os.getpgid(proc.pid), signal.SIGTERM) proc='' elif self.path=='/stop': if proc!='': status='Stopping Podcast' os.killpg(os.getpgid(proc.pid), signal.SIGTERM) proc='' else: status='Nothing to stop' elif self.path=='/shutdown': status='Shutdown' subprocess.Popen(["sudo", "shutdown", "-h", "now"], preexec_fn=os.setsid) elif self.path=='/restart': status='Restart' subprocess.Popen(["sudo", "reboot"], preexec_fn=os.setsid) elif self.path=='/down': status='Volume down' subprocess.Popen(["amixer", "set", "Master", "8%-"], preexec_fn=os.setsid) elif self.path=='/up': status='Volume up' subprocess.Popen(["amixer", "set", "Master", "8%+"], preexec_fn=os.setsid) elif self.path=='/on': if monitorstatus!="on": #switch on Monitor if status was off (by httpRequest NOT Radar) status='Monitor on' monitorstatus='on' subprocess.Popen(["/usr/bin/vcgencmd", "display_power", "1"], preexec_fn=os.setsid) elif self.path=='/off': if monitorstatus!="off": #switch off Monitor if status was on (by httpRequest NOT Radar) status='Monitor off' monitorstatus='off' subprocess.Popen(["/usr/bin/vcgencmd", "display_power", "0"], preexec_fn=os.setsid) self.wfile.write(html.format(temp[5:], status).encode("utf-8")) if __name__ == '__main__': http_server = HTTPServer((host_name, host_port), MyServer) print("Server Starts - %s:%s" % (host_name, host_port)) try: GPIO.add_event_detect(SENSOR_PIN , GPIO.RISING, callback=MyServer.monitor_on) #detect radar sensor and enable Monitor http_server.serve_forever() except KeyboardInterrupt: http_server.server_close() GPIO.cleanup() -
@MadScientist @yep_DD Thanks for the replies. Is there anyway to limit the distance that the radar sensor senses? I have my magic mirror in the bath room and it faces the wooden door which I believe will be detecting motion through it and I don’t want that.
