Unsolved MMM-PC-Stats
It’s not showing anything like that, only a hundred (and counting) of the one I posted
Did you uncomment the console.log in the process data function
Yeppers!
I don’t need the error message
Then there should be an output
processStats: function(data) { this.Stats = data; this.loaded = true; console.log(this.Stats); // for checking in dev console }, processSensors: function(data) { this.Sensors = data; console.log(this.Sensors); // for checking in dev console },
I can’t read your picture so I can’t see what’s there. AN object maybe?
strange thing is that if I use your original one it shows some info, just not temps…
Well maybe your board doesn’t have temp sensors. Try this: Type
sensor
in a terminal window -
sensors
