MMM-PC-Stats
Please. not a picture unless it’s readable like the picture below. Paste the output in a code block so I can see it. I’m old and blind
This post is deleted! -
It’s not showing anything like that, only a hundred (and counting) of the one I posted
Did you uncomment the console.log in the process data function
Yeppers!
I don’t need the error message
Then there should be an output
processStats: function(data) { this.Stats = data; this.loaded = true; console.log(this.Stats); // for checking in dev console }, processSensors: function(data) { this.Sensors = data; console.log(this.Sensors); // for checking in dev console }, -
I can’t read your picture so I can’t see what’s there. AN object maybe?
strange thing is that if I use your original one it shows some info, just not temps…
Well maybe your board doesn’t have temp sensors. Try this: Type
sensorin a terminal window -
sensors
{cpu: {…}, ram: {…}}cpu: {name: "AMD Turion(tm) 64 X2 Mobile Technology TL-58", threads: Array(2)}ram: {free: "1.27", total: "3.87", unit: "GB"}__proto__: Object MMM-PC-Stats.js:126 Uncaught (in promise) TypeError: Cannot read property 'ISA adapter' of undefined at Class.getDom (MMM-PC-Stats.js:126) at main.js:110 at new Promise (<anonymous>) at updateDom (main.js:109) at Object.updateDom (main.js:514) at Class.updateDom (module.js:358) at Class.socketNotificationReceived (MMM-PC-Stats.js:262) at module.js:246 at r.<anonymous> (socketclient.js:25) at r.emit (index.js:83) getDom @ MMM-PC-Stats.js:126 (anonymous) @ main.js:110 updateDom @ main.js:109 updateDom @ main.js:514 updateDom @ module.js:358 socketNotificationReceived @ MMM-PC-Stats.js:262 (anonymous) @ module.js:246 (anonymous) @ socketclient.js:25 r.emit @ index.js:83 r.onevent @ index.js:83 MMSocket.self.socket.onevent @ socketclient.js:19 r.onpacket @ index.js:83 (anonymous) @ index.js:83 r.emit @ index.js:83 r.ondecoded @ index.js:83 (anonymous) @ index.js:83 r.emit @ index.js:83 a.add @ index.js:83 r.ondata @ index.js:83 (anonymous) @ index.js:83 r.emit @ index.js:83 r.onPacket @ index.js:83 (anonymous) @ index.js:83 r.emit @ index.js:83 r.onPacket @ index.js:83 r.onData @ index.js:83 ws.onmessage @ index.js:83 -
Can you open the threads array?
jim@jim-Aspire-4520:~$ sensors Command 'sensors' not found, but can be installed with: sudo apt install lm-sensors -
YOu installed the dependencie?
Yeppers.
How do I open the threads array?
I can reinstall the dependencies if you want me to
Comment out
console.log(this.Stats)so you only get the sensors output -
@mykle1 ok
