    MMM-PC-Stats
    41 Posts 3 Posters 23.3k Views 3 Watching
      Mykle1 Project Sponsor Module Developer @Mykle1
        @mykle1
        This is better. I can see the tree and it’s readable
        • justjim1220J Offline
          justjim1220 Module Developer @Mykle1
          @mykle1
          It’s not showing anything like that, only a hundred (and counting) of the one I posted
          Jim Hallock - 1995
            Mykle1 Project Sponsor Module Developer @justjim1220
            @justjim1220
            Did you uncomment the console.log in the process data function
            justjim1220J Mykle1M 2 Replies Last reply Reply Quote 0
              @mykle1
              Yeppers!
              Jim Hallock - 1995
                @mykle1
                I don’t need the error message
                Mykle1M justjim1220J 2 Replies Last reply Reply Quote 0
                  @mykle1
                  Then there should be an output
                    @mykle1
                    processStats: function(data) {
                            this.Stats = data;
                            this.loaded = true;
                    		console.log(this.Stats); // for checking in dev console
                    	processSensors: function(data) {
                            this.Sensors = data;
                    		console.log(this.Sensors); // for checking in dev console
                    Jim Hallock - 1995
                      @justjim1220
                      I can’t read your picture so I can’t see what’s there. AN object maybe?
                        strange thing is that if I use your original one it shows some info, just not temps…
                        Jim Hallock - 1995
                          @justjim1220
                          Well maybe your board doesn’t have temp sensors. Try this: Type sensor in a terminal window
                            @mykle1
                            sensors
                              @mykle1
                              {cpu: {…}, ram: {…}}cpu: {name: "AMD Turion(tm) 64 X2 Mobile Technology TL-58", threads: Array(2)}ram: {free: "1.27", total: "3.87", unit: "GB"}__proto__: Object
                              MMM-PC-Stats.js:126 Uncaught (in promise) TypeError: Cannot read property 'ISA adapter' of undefined
                                  at Class.getDom (MMM-PC-Stats.js:126)
                                  at main.js:110
                                  at new Promise (<anonymous>)
                                  at updateDom (main.js:109)
                                  at Object.updateDom (main.js:514)
                                  at Class.updateDom (module.js:358)
                                  at Class.socketNotificationReceived (MMM-PC-Stats.js:262)
                                  at module.js:246
                                  at r.<anonymous> (socketclient.js:25)
                                  at r.emit (index.js:83)
                              getDom @ MMM-PC-Stats.js:126
                              (anonymous) @ main.js:110
                              updateDom @ main.js:109
                              updateDom @ main.js:514
                              updateDom @ module.js:358
                              socketNotificationReceived @ MMM-PC-Stats.js:262
                              (anonymous) @ module.js:246
                              (anonymous) @ socketclient.js:25
                              r.emit @ index.js:83
                              r.onevent @ index.js:83
                              MMSocket.self.socket.onevent @ socketclient.js:19
                              r.onpacket @ index.js:83
                              (anonymous) @ index.js:83
                              r.ondecoded @ index.js:83
                              a.add @ index.js:83
                              r.ondata @ index.js:83
                              r.onPacket @ index.js:83
                              r.onData @ index.js:83
                              ws.onmessage @ index.js:83
                              Jim Hallock - 1995
                                @justjim1220
                                Can you open the threads array?
                                  @mykle1
                                  jim@jim-Aspire-4520:~$ sensors
                                  Command 'sensors' not found, but can be installed with:
                                  sudo apt install lm-sensors
                                  Jim Hallock - 1995
                                    @justjim1220
                                    YOu installed the dependencie?
                                      @mykle1
                                      Yeppers.
                                      How do I open the threads array?
                                      I can reinstall the dependencies if you want me to
                                      Jim Hallock - 1995
                                        @mykle1
                                        Comment out console.log(this.Stats) so you only get the sensors output
                                          @mykle1 ok
                                          Jim Hallock - 1995
                                            @justjim1220
                                            Take a screenshot of just the output, not the whole screen. I might be able to see it then
