    MMM-PC-Stats
    41 Posts 3 Posters 24.5k Views 3 Watching
    • Mykle1M
      Mykle1 Project Sponsor Module Developer @Mykle1
      @mykle1
      I don’t need the error message
      Mykle1M justjim1220J 2 Replies Last reply
      • Mykle1M
        @mykle1
        Then there should be an output
        • justjim1220J
          justjim1220 Module Developer @Mykle1
          @mykle1
          processStats: function(data) {
                  this.Stats = data;
                  this.loaded = true;
          		console.log(this.Stats); // for checking in dev console
          	processSensors: function(data) {
                  this.Sensors = data;
          		console.log(this.Sensors); // for checking in dev console
          Jim Hallock - 1995
          Mykle1M 1 Reply Last reply
          • Mykle1M
            Mykle1 Project Sponsor Module Developer @justjim1220
            @justjim1220
            I can’t read your picture so I can’t see what’s there. AN object maybe?
            • justjim1220J
              strange thing is that if I use your original one it shows some info, just not temps…
              Jim Hallock - 1995
              • Mykle1M
                @justjim1220
                Well maybe your board doesn’t have temp sensors. Try this: Type sensor in a terminal window
                • Mykle1M
                  @mykle1
                  sensors
                  • justjim1220J
                    @mykle1
                    {cpu: {…}, ram: {…}}cpu: {name: "AMD Turion(tm) 64 X2 Mobile Technology TL-58", threads: Array(2)}ram: {free: "1.27", total: "3.87", unit: "GB"}__proto__: Object
                    MMM-PC-Stats.js:126 Uncaught (in promise) TypeError: Cannot read property 'ISA adapter' of undefined
                        at Class.getDom (MMM-PC-Stats.js:126)
                        at main.js:110
                        at new Promise (<anonymous>)
                        at updateDom (main.js:109)
                        at Object.updateDom (main.js:514)
                        at Class.updateDom (module.js:358)
                        at Class.socketNotificationReceived (MMM-PC-Stats.js:262)
                        at module.js:246
                        at r.<anonymous> (socketclient.js:25)
                        at r.emit (index.js:83)
                    getDom @ MMM-PC-Stats.js:126
                    (anonymous) @ main.js:110
                    updateDom @ main.js:109
                    updateDom @ main.js:514
                    updateDom @ module.js:358
                    socketNotificationReceived @ MMM-PC-Stats.js:262
                    (anonymous) @ module.js:246
                    (anonymous) @ socketclient.js:25
                    r.emit @ index.js:83
                    r.onevent @ index.js:83
                    MMSocket.self.socket.onevent @ socketclient.js:19
                    r.onpacket @ index.js:83
                    (anonymous) @ index.js:83
                    r.ondecoded @ index.js:83
                    a.add @ index.js:83
                    r.ondata @ index.js:83
                    r.onPacket @ index.js:83
                    r.onData @ index.js:83
                    ws.onmessage @ index.js:83
                    Jim Hallock - 1995
                    • Mykle1M
                      @justjim1220
                      Can you open the threads array?
                      • justjim1220J
                        @mykle1
                        jim@jim-Aspire-4520:~$ sensors
                        Command 'sensors' not found, but can be installed with:
                        sudo apt install lm-sensors
                        Jim Hallock - 1995
                        • Mykle1M
                          @justjim1220
                          YOu installed the dependencie?
                          justjim1220J Mykle1M 2 Replies Last reply
                          • justjim1220J
                            @mykle1
                            Yeppers.
                            How do I open the threads array?
                            I can reinstall the dependencies if you want me to
                            Jim Hallock - 1995
                            • Mykle1M
                              @mykle1
                              Comment out console.log(this.Stats) so you only get the sensors output
                              justjim1220J 1 Reply Last reply
                              • justjim1220J
                                @mykle1 ok
                                Jim Hallock - 1995
                                • Mykle1M
                                  @justjim1220
                                  Take a screenshot of just the output, not the whole screen. I might be able to see it then
                                  • Mykle1M
                                    pop@HPEu:~/MagicMirror$ sensors
                                    nouveau-pci-0100
                                    Adapter: PCI adapter
                                    fan1:        1110 RPM
                                    temp1:        +39.0°C  (high = +95.0°C, hyst =  +3.0°C)
                                                           (crit = +105.0°C, hyst =  +5.0°C)
                                                           (emerg = +135.0°C, hyst =  +5.0°C)
                                    coretemp-isa-0000
                                    Adapter: ISA adapter
                                    Core 0:       +29.0°C  (high = +83.0°C, crit = +99.0°C)
                                    Core 1:       +30.0°C  (high = +83.0°C, crit = +99.0°C)
                                    Core 2:       +29.0°C  (high = +83.0°C, crit = +99.0°C)
                                    Core 3:       +28.0°C  (high = +83.0°C, crit = +99.0°C)
                                    f71858fg-isa-0a00
                                    +3.3V:        +3.31 V
                                    3VSB:         +3.31 V
                                    Vbat:         +3.20 V
                                    fan1:        1910 RPM
                                    fan2:         998 RPM
                                    fan3:           0 RPM  ALARM
                                    temp1:        +29.2°C  (high = +70.0°C, hyst = +60.0°C)
                                    temp2:        +15.4°C  (high = +100.0°C, hyst = +85.0°C)
                                    temp3:        +32.5°C  (high = +100.0°C, hyst = +85.0°C)
                                    pop@HPEu:~/MagicMirror$ ^C
                                    • justjim1220J
                                      @mykle1
                                      Objectacpitz-virtual-0: {Virtual device: {…}}k8temp-pci-00c3: {PCI adapter: {…}}nouveau-pci-0090: {PCI adapter: {…}}__proto__: Object
                                      moment-timezone-with-data.js:481 Moment Timezone has no data for American/Chicago. See http://momentjs.com/timezone/docs/#/data-loading/.
                                      logError @ moment-timezone-with-data.js:481
                                          at main.js:110
                                          at module.js:246
                                          at main.js:110
                                          at Class.socketNotificationReceived (MMM-PC-Stats.js:268)
                                          at module.js:246
                                      Jim Hallock - 1995
                                      • justjim1220J
                                        @mykle1
                                        jim@jim-Aspire-4520:~/MagicMirror$ sensors
                                        k8temp-pci-00c3
                                        Core0 Temp:   +69.0°C
                                        Core0 Temp:   +67.0°C
                                        Core1 Temp:   +69.0°C
                                        Core1 Temp:   +68.0°C
                                        acpitz-virtual-0
                                        Adapter: Virtual device
                                        temp1:        +71.0°C  (crit = +100.0°C)
                                        nouveau-pci-0090
                                        GPU core:     +1.20 V  (min =  +1.00 V, max =  +1.20 V)
                                        temp1:        +64.0°C  (high = +95.0°C, hyst =  +3.0°C)
                                                               (crit = +105.0°C, hyst =  +2.0°C)
                                        Jim Hallock - 1995
                                        • Mykle1M
                                          @justjim1220
                                          Ok, I see it. In dev tools you can expand the output to see the tree
                                          • justjim1220J
                                            @mykle1
                                            there is a lot of things to expand, how much do you need?
                                            Objectacpitz-virtual-0: Virtual device: temp1: name: "temp1"type: "temperature"value: 80__proto__: Objectconstructor: ƒ Object()arguments: (...)assign: ƒ assign()caller: (...)create: ƒ create()defineProperties: ƒ defineProperties()defineProperty: ƒ defineProperty()entries: ƒ entries()freeze: ƒ freeze()getOwnPropertyDescriptor: ƒ getOwnPropertyDescriptor()getOwnPropertyDescriptors: ƒ getOwnPropertyDescriptors()getOwnPropertyNames: ƒ getOwnPropertyNames()getOwnPropertySymbols: ƒ getOwnPropertySymbols()getPrototypeOf: ƒ getPrototypeOf()is: ƒ is()isExtensible: ƒ isExtensible()isFrozen: ƒ isFrozen()isSealed: ƒ isSealed()keys: ƒ keys()length: 1name: "Object"preventExtensions: ƒ preventExtensions()prototype: {constructor: ƒ, __defineGetter__: ƒ, __defineSetter__: ƒ, hasOwnProperty: ƒ, __lookupGetter__: ƒ, …}seal: ƒ seal()setPrototypeOf: ƒ setPrototypeOf()values: ƒ values()__proto__: ƒ ()[[FunctionLocation]]: <unknown>hasOwnProperty: ƒ hasOwnProperty()isPrototypeOf: ƒ isPrototypeOf()propertyIsEnumerable: ƒ propertyIsEnumerable()toLocaleString: ƒ toLocaleString()toString: ƒ toString()valueOf: ƒ valueOf()__defineGetter__: ƒ __defineGetter__()__defineSetter__: ƒ __defineSetter__()__lookupGetter__: ƒ __lookupGetter__()__lookupSetter__: ƒ __lookupSetter__()get __proto__: ƒ __proto__()set __proto__: ƒ __proto__()__proto__: Objectconstructor: ƒ Object()hasOwnProperty: ƒ hasOwnProperty()isPrototypeOf: ƒ isPrototypeOf()propertyIsEnumerable: ƒ propertyIsEnumerable()toLocaleString: ƒ toLocaleString()toString: ƒ toString()valueOf: ƒ valueOf()__defineGetter__: ƒ __defineGetter__()__defineSetter__: ƒ __defineSetter__()__lookupGetter__: ƒ __lookupGetter__()__lookupSetter__: ƒ __lookupSetter__()get __proto__: ƒ __proto__()set __proto__: ƒ __proto__()__proto__: Objectk8temp-pci-00c3: PCI adapter: __proto__: Objectconstructor: ƒ Object()hasOwnProperty: ƒ hasOwnProperty()isPrototypeOf: ƒ isPrototypeOf()propertyIsEnumerable: ƒ propertyIsEnumerable()toLocaleString: ƒ toLocaleString()toString: ƒ toString()valueOf: ƒ valueOf()__defineGetter__: ƒ __defineGetter__()__defineSetter__: ƒ __defineSetter__()__lookupGetter__: ƒ __lookupGetter__()__lookupSetter__: ƒ __lookupSetter__()get __proto__: ƒ __proto__()set __proto__: ƒ __proto__()__proto__: Objectconstructor: ƒ Object()hasOwnProperty: ƒ hasOwnProperty()isPrototypeOf: ƒ isPrototypeOf()propertyIsEnumerable: ƒ propertyIsEnumerable()toLocaleString: ƒ toLocaleString()toString: ƒ toString()valueOf: ƒ valueOf()__defineGetter__: ƒ __defineGetter__()__defineSetter__: ƒ __defineSetter__()__lookupGetter__: ƒ __lookupGetter__()__lookupSetter__: ƒ __lookupSetter__()get __proto__: ƒ __proto__()set __proto__: ƒ __proto__()nouveau-pci-0090: PCI adapter: {GPU core: {…}, temp1: {…}}__proto__: Object__proto__: constructor: ƒ Object()hasOwnProperty: ƒ hasOwnProperty()isPrototypeOf: ƒ isPrototypeOf()propertyIsEnumerable: ƒ propertyIsEnumerable()toLocaleString: ƒ toLocaleString()toString: ƒ toString()valueOf: ƒ valueOf()__defineGetter__: ƒ __defineGetter__()__defineSetter__: ƒ __defineSetter__()__lookupGetter__: ƒ __lookupGetter__()__lookupSetter__: ƒ __lookupSetter__()get __proto__: ƒ __proto__()set __proto__: ƒ __proto__()
                                            Jim Hallock - 1995
