    Temp suddenly showing 239 degrees
    19 Posts 11 Posters 15.0k Views 10 Watching
    • G
      gverbist
      nope,didnt come from messing around…Just happened like that
        d3r
        I have the same problem. Temperature is in the hundreds. I didn’t play around with the code.
        • RedNaxR
          RedNax Module Developer
          The error is with the openweathermap api payload:
          {"temp":295.06,"pressure":1026,"humidity":68,"temp_min":293.15,"temp_max":297.75},
          What units are your guys using in config.js?
          The above result only appears when it’s not defined at all.metric or emperial yield valid results. I guess it’s kelvin?
          D 1 Reply Last reply
            d3r @RedNax
            @RedNax
            I’m using degrees C.
            I forgot to mention the it’s just the current temperature that’s showing temps in the hundreds. The temperature forecast is still working fine.
            • RedNaxR
              You’re getting degrees Kelvin… Something’s wrong with your units definition…
              Have a look at the units entry here: https://github.com/MichMich/MagicMirror/tree/master/modules/default/currentweather
                d3r
                Something must have happened. I didn’t change the code. I’ll check it when I get home.
                  digbeta
                  I have the same issue. Suddenly Current is shown in Kelvin. Setting the units in config.js changes nothing. Alternatively I installed the MMM-WunderGround module and it is showing correctly plus it’s LOADS better. Hourly + extended.
                    McSorley
                    Happened to me yesterday. Seemed to resolve itself today.
                    C 1 Reply Last reply
                      cyberphox @McSorley
                        cyberphox
                        Same thing is happening to me on a new install. Tried even adding units line to config but doesn’t matter what you select it always shows Kelvin. FYI the temperature forecast displays correctly, just not current temp. May have to ditch this and go with a new weather module.
                        • KirAsh4K
                          KirAsh4 Moderator
                          No matter what I do, I can’t seem to reproduce this odd temperature display. I’ve even started from scratch with a different rpi, completely blank to having MM up and running … no odd temperature.
                          • W
                            weezer05
                            Hi there,
                            I experienced this the other day, and I checked again - my new pi 3 is still showing an incorrect temperature reading as well. It seems as though the temperature is set to ‘Kelvin’, though I set the temperature to ‘imperial’, within the config.js configuration file.
                            /* Magic Mirror Config Sample
                             * MIT Licensed.
                            var config = {
                                    port: 8080,
                                    language: 'en',
                                    timeFormat: 12,
                                    units: 'imperial',
                            • W
                              weezer05
                              After looking around, I see that github member p0akley seems to have identified an issue 5 days ago that matches this description. Following his instructions I was able to resolve the issue with my Pi 3.
                              Seems there is a small adjustment needed in the file:
                              modules/default/currentweather/currentweather.js
                              Link to explanation / resolution:
                              https://github.com/MichMich/MagicMirror/commit/25ddf2c65178e2b8afe0709b48d5d30054208c04
                              • KirAsh4K
                                KirAsh4 Moderator
                                That’s been in the 'develop' branch. Not pushed to 'master' yet. With this being a “biggie” for everyone who’s running the master branch, perhaps @MichMich might consider pushing it to the master branch sooner rather than later.
                                And my apologies earlier for not having spotted it. I always run the develop branch. #livingontheedge :)
                                • MichMichM
                                  MichMich
                                  If one of you can confirm the develop branch fixes the issue, I’ll push the changes to the master branch.
                                  J 1 Reply Last reply
                                  • W
                                    weezer05
                                    Been trying to reproduce this now for the past hour, and I can’t get it to show up incorrectly again. I double checked line 167 of the currentweather.js file on the develop branch, and it does include the correction mentioned earlier which initially resolved my issue.
                                      jtmoore81 @MichMich
                                      @michmich Was this ever pushed? I believe I’m having the same issue.
