    Temp suddenly showing 239 degrees
    19 Posts 11 Posters 15.0k Views 10 Watching
    • RedNaxR
      RedNax Module Developer
      You’re getting degrees Kelvin… Something’s wrong with your units definition…
      Have a look at the units entry here: https://github.com/MichMich/MagicMirror/tree/master/modules/default/currentweather
        d3r
        Something must have happened. I didn’t change the code. I’ll check it when I get home.
          digbeta
          I have the same issue. Suddenly Current is shown in Kelvin. Setting the units in config.js changes nothing. Alternatively I installed the MMM-WunderGround module and it is showing correctly plus it’s LOADS better. Hourly + extended.
            McSorley
            Happened to me yesterday. Seemed to resolve itself today.
            C 1 Reply Last reply
              cyberphox @McSorley
                cyberphox
                Same thing is happening to me on a new install. Tried even adding units line to config but doesn’t matter what you select it always shows Kelvin. FYI the temperature forecast displays correctly, just not current temp. May have to ditch this and go with a new weather module.
                • KirAsh4K
                  KirAsh4 Moderator
                  No matter what I do, I can’t seem to reproduce this odd temperature display. I’ve even started from scratch with a different rpi, completely blank to having MM up and running … no odd temperature.
                  • W
                    weezer05
                    Hi there,
                    I experienced this the other day, and I checked again - my new pi 3 is still showing an incorrect temperature reading as well. It seems as though the temperature is set to ‘Kelvin’, though I set the temperature to ‘imperial’, within the config.js configuration file.
                    /* Magic Mirror Config Sample
                     * MIT Licensed.
                    var config = {
                            port: 8080,
                            language: 'en',
                            timeFormat: 12,
                            units: 'imperial',
                    • W
                      weezer05
                      After looking around, I see that github member p0akley seems to have identified an issue 5 days ago that matches this description. Following his instructions I was able to resolve the issue with my Pi 3.
                      Seems there is a small adjustment needed in the file:
                      modules/default/currentweather/currentweather.js
                      Link to explanation / resolution:
                      https://github.com/MichMich/MagicMirror/commit/25ddf2c65178e2b8afe0709b48d5d30054208c04
                      • KirAsh4K
                        KirAsh4 Moderator
                        That’s been in the 'develop' branch. Not pushed to 'master' yet. With this being a “biggie” for everyone who’s running the master branch, perhaps @MichMich might consider pushing it to the master branch sooner rather than later.
                        And my apologies earlier for not having spotted it. I always run the develop branch. #livingontheedge :)
                        • MichMichM
                          MichMich
                          If one of you can confirm the develop branch fixes the issue, I’ll push the changes to the master branch.
                          J 1 Reply Last reply
                          • W
                            weezer05
                            Been trying to reproduce this now for the past hour, and I can’t get it to show up incorrectly again. I double checked line 167 of the currentweather.js file on the develop branch, and it does include the correction mentioned earlier which initially resolved my issue.
                              jtmoore81 @MichMich
                              @michmich Was this ever pushed? I believe I’m having the same issue.
