    Temp suddenly showing 239 degrees
    19 Posts 11 Posters 13.4k Views 10 Watching
      d3r
      I have the same problem. Temperature is in the hundreds. I didn’t play around with the code.
      • RedNaxR Offline
        RedNax Module Developer
        The error is with the openweathermap api payload:
        {"temp":295.06,"pressure":1026,"humidity":68,"temp_min":293.15,"temp_max":297.75},
        What units are your guys using in config.js?
        The above result only appears when it’s not defined at all.metric or emperial yield valid results. I guess it’s kelvin?
          d3r @RedNax
          @RedNax
          I’m using degrees C.
          I forgot to mention the it’s just the current temperature that’s showing temps in the hundreds. The temperature forecast is still working fine.
          • RedNaxR Offline
            You’re getting degrees Kelvin… Something’s wrong with your units definition…
            Have a look at the units entry here: https://github.com/MichMich/MagicMirror/tree/master/modules/default/currentweather
              d3r
              Something must have happened. I didn’t change the code. I’ll check it when I get home.
                digbeta
                I have the same issue. Suddenly Current is shown in Kelvin. Setting the units in config.js changes nothing. Alternatively I installed the MMM-WunderGround module and it is showing correctly plus it’s LOADS better. Hourly + extended.
                  McSorley
                  Happened to me yesterday. Seemed to resolve itself today.
                    cyberphox @McSorley
                      cyberphox
                      Same thing is happening to me on a new install. Tried even adding units line to config but doesn’t matter what you select it always shows Kelvin. FYI the temperature forecast displays correctly, just not current temp. May have to ditch this and go with a new weather module.
                      • KirAsh4K Offline
                        KirAsh4 Moderator
                        No matter what I do, I can’t seem to reproduce this odd temperature display. I’ve even started from scratch with a different rpi, completely blank to having MM up and running … no odd temperature.
