    Temp suddenly showing 239 degrees
    19 Posts 11 Posters 12.6k Views 10 Watching
    • G Offline
      gverbist
      since yesterday without any change to the code the current temperature in the default module shows an additional 9 in the temp. For example the temperature is 21 degrees. On the mirror this shows 291 degrees.
      Anyone seen this before?
        Mate3
        i was messing around with Traffic modules, thought it was something i did cause mine showed 300 degress
        • G Offline
          gverbist
          nope,didnt come from messing around…Just happened like that
            d3r
            I have the same problem. Temperature is in the hundreds. I didn’t play around with the code.
            • RedNaxR Offline
              RedNax Module Developer
              The error is with the openweathermap api payload:
              {"temp":295.06,"pressure":1026,"humidity":68,"temp_min":293.15,"temp_max":297.75},
              What units are your guys using in config.js?
              The above result only appears when it’s not defined at all.metric or emperial yield valid results. I guess it’s kelvin?
                d3r @RedNax
                @RedNax
                I’m using degrees C.
                I forgot to mention the it’s just the current temperature that’s showing temps in the hundreds. The temperature forecast is still working fine.
                • RedNaxR Offline
                  You’re getting degrees Kelvin… Something’s wrong with your units definition…
                  Have a look at the units entry here: https://github.com/MichMich/MagicMirror/tree/master/modules/default/currentweather
                    d3r
                    Something must have happened. I didn’t change the code. I’ll check it when I get home.
                      digbeta
                      I have the same issue. Suddenly Current is shown in Kelvin. Setting the units in config.js changes nothing. Alternatively I installed the MMM-WunderGround module and it is showing correctly plus it’s LOADS better. Hourly + extended.
                        McSorley
                        Happened to me yesterday. Seemed to resolve itself today.
