Followed wiki, but the screen does not rotate
Hello, I installed the latest version of MM.
My problem, i cannot rotate my screen. I followed the wiki manual von MichMich.
I added the following two lines to /boot/config.txt
#Enable the Open GL driver to decrease Electron's CPU usage dtoverlay=vc4-kms-v3dand I added the following line to ~/.config/lxsession/LXDE-pi/autostart
@xrandr --output HDMI-1 --rotate rightBut the screen does not rotate.
Could it be a problem, that there is a Monitor/USB Switch between the raspberry and the monitor?
I would be very grateful if someone could help me.
Thank you in advance.
Lars
@klinge said in Followed wiki, but the screen does not rotate:
Try it without the Monitor/USB Switch. If it works, then it’s the switch. If it doesn’t, something else is amiss.
I tried it without the switch. But unfortunately it still doesn´t work.
With the risk of sounding like the helpdesk.“did you reboot between attemps”
And to be sure, you are using the hdmi port?
My Monitor has a DVI Interface, so I am using an hdmi dvi adapter. Could it be that? What could I do to rotate with DVI?
Its about using the hdmi output of the pi. And it looks you’re doing that. But you can try hooking up the pi to another monitor, e.g. a tv to rule it out?
