    MMM-Random Fact
    Scheduled Pinned Locked Moved Education
    59 Posts 12 Posters 46.7k Views 11 Watching
    • L Offline
      lauxtert
      System Language german
      • L Offline
        lauxtert
        after the second reboot it went, awsone module, thanks for the answer
          Mykle1 Project Sponsor Module Developer @lauxtert
          @lauxtert
          Have you installed the dependencies as per the README file?
            @lauxtert said in Random Fact:
            You’re welcome, mate. :-)
              You know what? This is a pretty damn good module. Informative and fun. I’m only sorry that it wasn’t my idea. :-)
              Well done @cowboysdude.
              • F Offline
                Fonfon
                Hi good module
                For another language
                i suppose in config file
                language: ‘german’
                that its ?
                • L Offline
                  lauxtert
                  The language was set automatically, after a reboot of the pi it ran then.
                    Ramez @lauxtert
                    @lauxtert @cowboysdude same here it stays in" getting a fact" (in my language)…restarting does nothing and setting global config language also does nothing only english is working! here is the error I get
                    {node:1148} UnhandeledPromiseRejectWarning: Unhandeled promise rejection {rejection id: 1}: Error
                    {node:1148} [DEP0018] DeprecationWarning: Unhandeled promise rejection are deprecated. In the future, promise rejections that are not handeled will terminate the Node.js process with a non-zer exit code.
                    • lavolp3L Offline
                      lavolp3 Module Developer @Ramez
                      My module fails as well and I blame the following message in my developer’s console
                      [Violation] 'message' handler took 767ms
                      It is not directly linked to the module but is coming up since I had it installed just now
                      How to troubleshoot modules
                      MMM-soccer v2, MMM-AVStock
                      • lavolp3L Offline
                        lavolp3 Module Developer @lavolp3
                        @lavolp3 module works after a complete reboot. Sorry for the bothering :-)
                          Ramez @lavolp3
                          @lavolp3 glad it’s working…could you try to change it’s language and see if it still works?
                          • lavolp3L Offline
                            @ramez to be honest, it doesn’t work again. Can’t really find the reason for that.
                            My confige entry:
                                    disabled: false,
                                    module: 'MMM-rfacts',
                                    position: 'top_right',
                                        lang: "de",  //facts will be translated to this language according to ISO-639$
                                        updateInterval: 10 * 60 * 1000, // every 10 minutes
                                        animationSpeed: 10,
                                        initialLoadDelay: 875, // 0 seconds delay
                                        retryDelay: 1500,
                                        fadeSpeed: 7
                            IN the pm2 logs I only get this
                            0|mm       | (node:10423) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 53): Error
                            • cowboysdudeC Offline
                              cowboysdude Module Developer @lavolp3
                              @lavolp3 said in Random Fact:
                              animationSpeed: 10,
                              retryDelay: 1500,
                              fadeSpeed: 7
                              Do a git pull…should be fixed now :) Check the config below…
                              Actually this is THE only thing you need in your config.js file …
                                  disabled: false,
                                Ramez @cowboysdude
                                @cowboysdude sorry, but still same error
                                  cowboysdude Module Developer @Ramez
                                  @ramez Not really sure as I cannot duplicate your error and no one else seems to be having the issue.
                                    I just downloaded the most recent version and fired it up.
                                    • lavolp3L Offline
                                      Well for me this module does not work as well (only showing “Eine Tatsache bekommen” in German) and I have again Unhandled Rejection Warnings, which are not errors however… but I have the feeling they are related to the problem.
                                      (node:25288) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 1): Error
                                      0|mm       | (node:25288) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js process with a non-zero exit code.
                                      0|mm       | (node:25288) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 2): Error
                                      I only get these when I activate this module
                                        Mykle1 Project Sponsor Module Developer @lavolp3
                                        I’m not seeing that at all and I have plenty of modules loading along with it. Have you tried running this module by itself?
                                        • joela85J Offline
                                          joela85
                                          Is there a config option to show/hide the “Random Fact” title if you just want the fact?
                                          Alternatively, would positioning and colour customisation of the title be done in CSS?
                                            Mykle1 Project Sponsor Module Developer @joela85
                                            @joela85
                                            Both can be achieved in custom.css file
                                            .MMM-rfacts .title {
                                                display:none;
                                                (or positioning and colour customisation)
                                            .MMM-rfacts .description  {
                                                (positioning and colour customisation code here)
