    MMM-Random Fact
    Scheduled Pinned Locked Moved Education
    59 Posts 12 Posters 46.7k Views 11 Watching
    • L Offline
      lauxtert
      Nice module just all the time is “getting a fact…”
      What can do?
      Mykle1M R 2 Replies Last reply Reply Quote 0
        Mykle1 Project Sponsor Module Developer @lauxtert
        @lauxtert
        I just installed it and it fires right up. What language is set in your config?
        • L Offline
          lauxtert
          System Language german
          • L Offline
            lauxtert
            after the second reboot it went, awsone module, thanks for the answer
              @lauxtert
              Have you installed the dependencies as per the README file?
                @lauxtert said in Random Fact:
                You’re welcome, mate. :-)
                  You know what? This is a pretty damn good module. Informative and fun. I’m only sorry that it wasn’t my idea. :-)
                  Well done @cowboysdude.
                  • F Offline
                    Fonfon
                    Hi good module
                    For another language
                    i suppose in config file
                    language: ‘german’
                    that its ?
                    • L Offline
                      lauxtert
                      The language was set automatically, after a reboot of the pi it ran then.
                        Ramez @lauxtert
                        @lauxtert @cowboysdude same here it stays in" getting a fact" (in my language)…restarting does nothing and setting global config language also does nothing only english is working! here is the error I get
                        {node:1148} UnhandeledPromiseRejectWarning: Unhandeled promise rejection {rejection id: 1}: Error
                        {node:1148} [DEP0018] DeprecationWarning: Unhandeled promise rejection are deprecated. In the future, promise rejections that are not handeled will terminate the Node.js process with a non-zer exit code.
                        • lavolp3L Offline
                          lavolp3 Module Developer @Ramez
                          My module fails as well and I blame the following message in my developer’s console
                          [Violation] 'message' handler took 767ms
                          It is not directly linked to the module but is coming up since I had it installed just now
                          How to troubleshoot modules
                          MMM-soccer v2, MMM-AVStock
                          • lavolp3L Offline
                            lavolp3 Module Developer @lavolp3
                            @lavolp3 module works after a complete reboot. Sorry for the bothering :-)
                              Ramez @lavolp3
                              @lavolp3 glad it’s working…could you try to change it’s language and see if it still works?
                              • lavolp3L Offline
                                @ramez to be honest, it doesn’t work again. Can’t really find the reason for that.
                                My confige entry:
                                        disabled: false,
                                        module: 'MMM-rfacts',
                                        position: 'top_right',
                                            lang: "de",  //facts will be translated to this language according to ISO-639$
                                            updateInterval: 10 * 60 * 1000, // every 10 minutes
                                            animationSpeed: 10,
                                            initialLoadDelay: 875, // 0 seconds delay
                                            retryDelay: 1500,
                                            fadeSpeed: 7
                                IN the pm2 logs I only get this
                                0|mm       | (node:10423) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 53): Error
                                • cowboysdudeC Offline
                                  cowboysdude Module Developer @lavolp3
                                  @lavolp3 said in Random Fact:
                                  animationSpeed: 10,
                                  retryDelay: 1500,
                                  fadeSpeed: 7
                                  Do a git pull…should be fixed now :) Check the config below…
                                  Actually this is THE only thing you need in your config.js file …
                                      disabled: false,
                                    Ramez @cowboysdude
                                    @cowboysdude sorry, but still same error
                                      cowboysdude Module Developer @Ramez
                                      @ramez Not really sure as I cannot duplicate your error and no one else seems to be having the issue.
                                        I just downloaded the most recent version and fired it up.
                                        • lavolp3L Offline
                                          Well for me this module does not work as well (only showing “Eine Tatsache bekommen” in German) and I have again Unhandled Rejection Warnings, which are not errors however… but I have the feeling they are related to the problem.
                                          (node:25288) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 1): Error
                                          0|mm       | (node:25288) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js process with a non-zero exit code.
                                          0|mm       | (node:25288) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 2): Error
                                          I only get these when I activate this module
                                            Mykle1 Project Sponsor Module Developer @lavolp3
                                            I’m not seeing that at all and I have plenty of modules loading along with it. Have you tried running this module by itself?
