    trouble booting magicmirror
    11 Posts 2 Posters 4.4k Views 2 Watching
    • T Offline
      tbs86
      hello all this is my first mirror build and still fairly new to the raspberry pi. i have two problems currently.
      The first problem is towards the end of the tutorial. I got the software installed and it says to disable the wifi power management. When i type in the command sudo nano /etc/network/interfaces it ame to a some what different looking screen then whats posted. I do not have the wlan0 section i guess you can say. After googling it i was able to disable it temporarily but once it rebooted it went back to Wifi management on. My question is how to i turn it off permanently?
      Second problem is when trying to boot the config file for MM i type
      cd MagicMirror/config
      then cp config
      and i get
      "cp: missing destination file operand after 'config'
      Try 'cp --help' for more information."
      So its not letting me boot the program at all. What am i doing wrong i have tried reinstalling the program but it says its already installed. Not sure what to do here any help would be appreciated!
      Im running a pi3 with raspbian-stretch 2018-10-09
        Mykle1 Project Sponsor Module Developer @tbs86
        @tbs86
        Let’s start with your second problem. When you say “when trying to boot the config file” do you mean open the config file? Did you already make a copy of the config.js.sample and rename it to config.js? It looks as if you’re attempting to make a copy of the config.js file, so cp config should be cp config.js.
        There’s an easier way to accomplish this if you are not familiar with terminal commands. This will walk you through that.
        https://forum.magicmirror.builders/topic/4528/how-to-create-a-working-config-for-absolute-beginners
        T 2 Replies Last reply Reply Quote 0
        • T Offline
          tbs86 @Mykle1
          @mykle1
          I will give this a try thank you
          • T Offline
            tbs86 @Mykle1
            @mykle1 I don’t think I made a copy and yes I’m trying to open the config file as the tutorial says
            • T Offline
              tbs86
              I type npm start and get a error.
              Run-start.sh: 4: run-start.sh: electron: not found
                @tbs86
                Ok, I assume you ran npm start in the MagicMirror directory and received that error. This is a fairly common problem. The installation of dependencies fails at times to install electron properly.
                1. From your desktop(GUI) go to MagicMirror/node_modules folder. Inside this folder you will find the electron folder. Delete the electron folder.
                2. Now, open a terminal and type cd MagicMirror and enter. Now, in the MagicMirror directory type npm install and enter.
                This SHOULD install electron.
                • T Offline
                  tbs86 @Mykle1
                  @mykle1 I do not have any folders in /home/pi/MagicMirror/node_modules
                    @tbs86 said in trouble booting magicmirror:
                    Not one? I think you never installed your dependencies at all. No matter, still run npm install in the MagicMirror directory to install ALL of your dependencies
                    T 1 Reply Last reply Reply Quote 2
                    • T Offline
                      tbs86 @Mykle1
                      @mykle1 thank you that worked! Now it’s telling me I need to create a config file
                      • T Offline
                        tbs86
                        I have edited the config file thank you for your help!!! Much appreciated!
                          @tbs86
                          You can mark the topic as solved
