    assign a symbol to a module
    19 Posts 5 Posters 13.5k Views 5 Watching
    • strawberry 3.141S Offline
      strawberry 3.141 Project Sponsor Module Developer @dominic
      @dominic ou can add a fontawesome icon in the header like the following lines here https://github.com/fewieden/MMM-Fuel/blob/master/MMM-Fuel.js#L49
      and add
      getStyles: function () {
              return ["font-awesome.css"];
        dominic @strawberry 3.141
        @strawberry-3.141 said in assign a symbol to a module:
        return [“font-awesome.css”];
        I add:
         var header = document.createElement("header");   // in the getdom function and
        in the .js file. And now I have to do ?
        how do i musst edit the config file ?
        • yawnsY Offline
          yawns Moderator
          getDom: function() {
          	var symbol =  document.createElement("span");
          	symbol.className = "fa fa-home";
          	wrapper.appendChild(symbol);
          	return wrapper;
          This will result in a “house symbol”
            dominic @yawns
            @yawns said in assign a symbol to a module:
            var wrapper = document.createElement(“div”);
            var symbol = document.createElement(“span”);
            symbol.className = “fa fa-home”;
            return wrapper;
            Thanks. When i add the code, i have the “house” but i have a getdom function with the following code…
            getDom: function(){
            		if(this.dataFile){
                                    var humidityRegExp = /Humidity = (.*?) %/ig;
                                    var humidity = humidityRegExp.exec(this.dataFile)[1];
                                    var temperatureRegExp = /Temperature = (.*?) *C/ig;
                                    var temperature = temperatureRegExp.exec(this.dataFile)[1];
            			wrapper.innerHTML = "r.F.: " + humidity + "%, Temp.: " + temperature + "°C";
            		} else {
            			wrapper.innerHTML = "No data";
            		return wrapper;
            …how do I implement the code in this?
            • yawnsY Offline
              yawns Moderator
              like this:
              	if(this.dataFile){
              		var spacer = document.createElement("span");
              		spacer.innerHTML = " ";
              		var temperature_symbol =  document.createElement("span");
              		temperature_symbol.className = "fa fa-home";
              		var humidity_symbol =  document.createElement("span");
              		humidity_symbol.className = "fa fa-tint";
              		wrapper.appendChild(temperature_symbol);
              		var temperature_text = document.createElement("span");
              		temperature_text.innerHTML = " " + temperature + "°C";
              		wrapper.appendChild(temperature_text);
              		wrapper.appendChild(spacer);
              		wrapper.appendChild(humidity_symbol);
              		var humidity_text = document.createElement("span");
              		humidity_text.innerHTML = " " + humidity + "%";
              		wrapper.appendChild(humidity_text);
              	} else {
              	return wrapper;
              Should give you a house symbol for temperature inside and a droplet for humidity.
                Plati
                @yawns
                I need add a symbol to text (before or behind).
                Code:
                		if(this.config.title !== false){
                			var title = document.createElement("header");
                			title.innerHTML = this.config.title || this.name;
                			wrapper.appendChild(title);
                		var logs = document.createElement("table");
                		for (var i = this.messages.length - 1; i >= 0; i--) {
                			//Create callWrapper
                			var callWrapper = document.createElement("tr");
                			callWrapper.classList.add("normal");
                			var icon =  document.createElement("td");
                			if (this.messages[i].type === "INFO"){
                				icon.className = "fa fa-info";
                			else if (this.messages[i].type === "WARNING"){
                				icon.className = "fa fa-exclamation";
                			else if (this.messages[i].type === "ERROR"){
                				icon.className = "fa fa-exclamation-triangle";
                			else {
                				icon.className = "fa fa-question";
                			//Set caller of row
                			var caller =  document.createElement("td");
                			caller.innerHTML = "[" + this.messages[i].type + "] " + this.messages[i].message + " " + wrapper.appendChild(icon);
                			caller.classList.add("title", "small", "align-left");
                			if(this.config.types.hasOwnProperty(this.messages[i].type)){
                				caller.classList.add(this.config.types[this.messages[i].type]);
                			callWrapper.appendChild(caller);
                			//Set time of row
                			var time =  document.createElement("td");
                			time.innerHTML = this.config.format ? moment(this.messages[i].timestamp).format(this.config.format) : moment(this.messages[i].timestamp).fromNow();
                			time.classList.add("time", "light", "xsmall");
                			callWrapper.appendChild(time);
                			//Add to logs
                			logs.appendChild(callWrapper);
                		wrapper.appendChild(logs);
                		return wrapper;
                This is effect:0_1473698703685_syslog-icon.jpg
                What is wrong?
                • I Offline
                  ianperrin @Plati
                  Hi @Plati
                  The solution depends on how you want to display the table.
                  Do you want
                  • 3 columns in the following order: | Icon | Message | Time |
                  • Or 2 columns laid out as follows: | Message Icon | Time |
                  "Live as if you were to die tomorrow. Learn as if you were to live forever." - Mahatma Gandhi
                    Plati @ianperrin
                    Hi @ianperrin
                    | Icon | Message | Time | should be ok
                    • I Offline
                      ianperrin @Plati
                      @Plati said in assign a symbol to a module:
                      Hi @ianperrin
                      In that case, try this
                      		var iconCell = document.createElement("td");
                      		var icon =  document.createElement("i");
                      		else {
                      		iconCell.appendChild(icon);
                      		callWrapper.appendChild(iconCell);
                      		//Set caller of row
                      		caller.innerHTML = "[" + this.messages[i].type + "] " + this.messages[i].message;
                      • I Offline
                        ianperrin
                        You could also consider making the icon configurable via the options,
                        First add the default values for the options
                        	defaults: {
                        		max: 5,
                        		format: false,
                        		types: {
                        			INFO: "dimmed",
                        			WARNING: "normal",
                        			ERROR: "bright"
                        		icons: {
                        			INFO: "info",
                        			WARNING: "exclamation",
                        			ERROR: "exclamation-triangle"
                        Then change the code to create the icon (and for bonus points, set class for the icon to the same as the message.
                        		if(this.config.icons.hasOwnProperty(this.messages[i].type)){
                        			icon.classList.add("fa", "fa-" + this.config.icons[this.messages[i].type]);
                        		} else {
                        			icon.classList.add("fa", "fa-question");
                        			icon.classList.add(this.config.types[this.messages[i].type]);
                        Warning - this code was entered directly here in the comment so may contain TyoPs ;)
