    assign a symbol to a module
    19 Posts 5 Posters 13.7k Views 5 Watching
      dominic @yawns
      @yawns said in assign a symbol to a module:
      getDom: function() {
      var wrapper = document.createElement(“div”);
      var symbol = document.createElement(“span”);
      symbol.className = “fa fa-home”;
      wrapper.appendChild(symbol);
      return wrapper;
      Thanks. When i add the code, i have the “house” but i have a getdom function with the following code…
      getDom: function(){
      		if(this.dataFile){
                              var humidityRegExp = /Humidity = (.*?) %/ig;
                              var humidity = humidityRegExp.exec(this.dataFile)[1];
                              var temperatureRegExp = /Temperature = (.*?) *C/ig;
                              var temperature = temperatureRegExp.exec(this.dataFile)[1];
      			wrapper.innerHTML = "r.F.: " + humidity + "%, Temp.: " + temperature + "°C";
      		} else {
      			wrapper.innerHTML = "No data";
      		return wrapper;
      …how do I implement the code in this?
      • yawnsY Offline
        yawns Moderator
        like this:
        	if(this.dataFile){
        		var spacer = document.createElement("span");
        		spacer.innerHTML = " ";
        		var temperature_symbol =  document.createElement("span");
        		temperature_symbol.className = "fa fa-home";
        		var humidity_symbol =  document.createElement("span");
        		humidity_symbol.className = "fa fa-tint";
        		wrapper.appendChild(temperature_symbol);
        		var temperature_text = document.createElement("span");
        		temperature_text.innerHTML = " " + temperature + "°C";
        		wrapper.appendChild(temperature_text);
        		wrapper.appendChild(spacer);
        		wrapper.appendChild(humidity_symbol);
        		var humidity_text = document.createElement("span");
        		humidity_text.innerHTML = " " + humidity + "%";
        		wrapper.appendChild(humidity_text);
        	} else {
        	return wrapper;
        Should give you a house symbol for temperature inside and a droplet for humidity.
          Plati
          @yawns
          I need add a symbol to text (before or behind).
          Code:
          		var header = document.createElement("header");
          		if(this.config.title !== false){
          			var title = document.createElement("header");
          			title.innerHTML = this.config.title || this.name;
          			wrapper.appendChild(title);
          		var logs = document.createElement("table");
          		for (var i = this.messages.length - 1; i >= 0; i--) {
          			//Create callWrapper
          			var callWrapper = document.createElement("tr");
          			callWrapper.classList.add("normal");
          			var icon =  document.createElement("td");
          			if (this.messages[i].type === "INFO"){
          				icon.className = "fa fa-info";
          			else if (this.messages[i].type === "WARNING"){
          				icon.className = "fa fa-exclamation";
          			else if (this.messages[i].type === "ERROR"){
          				icon.className = "fa fa-exclamation-triangle";
          			else {
          				icon.className = "fa fa-question";
          			//Set caller of row
          			var caller =  document.createElement("td");
          			caller.innerHTML = "[" + this.messages[i].type + "] " + this.messages[i].message + " " + wrapper.appendChild(icon);
          			caller.classList.add("title", "small", "align-left");
          			if(this.config.types.hasOwnProperty(this.messages[i].type)){
          				caller.classList.add(this.config.types[this.messages[i].type]);
          			callWrapper.appendChild(caller);
          			//Set time of row
          			var time =  document.createElement("td");
          			time.innerHTML = this.config.format ? moment(this.messages[i].timestamp).format(this.config.format) : moment(this.messages[i].timestamp).fromNow();
          			time.classList.add("time", "light", "xsmall");
          			callWrapper.appendChild(time);
          			//Add to logs
          			logs.appendChild(callWrapper);
          		wrapper.appendChild(logs);
          		return wrapper;
          This is effect:0_1473698703685_syslog-icon.jpg
          What is wrong?
          • I Offline
            ianperrin @Plati
            Hi @Plati
            The solution depends on how you want to display the table.
            Do you want
            • 3 columns in the following order: | Icon | Message | Time |
            • Or 2 columns laid out as follows: | Message Icon | Time |
            "Live as if you were to die tomorrow. Learn as if you were to live forever." - Mahatma Gandhi
              Plati @ianperrin
              Hi @ianperrin
              | Icon | Message | Time | should be ok
              • I Offline
                ianperrin @Plati
                @Plati said in assign a symbol to a module:
                Hi @ianperrin
                In that case, try this
                		var iconCell = document.createElement("td");
                		var icon =  document.createElement("i");
                		else {
                		iconCell.appendChild(icon);
                		callWrapper.appendChild(iconCell);
                		//Set caller of row
                		caller.innerHTML = "[" + this.messages[i].type + "] " + this.messages[i].message;
                • I Offline
                  ianperrin
                  You could also consider making the icon configurable via the options,
                  First add the default values for the options
                  	defaults: {
                  		max: 5,
                  		format: false,
                  		types: {
                  			INFO: "dimmed",
                  			WARNING: "normal",
                  			ERROR: "bright"
                  		icons: {
                  			INFO: "info",
                  			WARNING: "exclamation",
                  			ERROR: "exclamation-triangle"
                  Then change the code to create the icon (and for bonus points, set class for the icon to the same as the message.
                  		if(this.config.icons.hasOwnProperty(this.messages[i].type)){
                  			icon.classList.add("fa", "fa-" + this.config.icons[this.messages[i].type]);
                  		} else {
                  			icon.classList.add("fa", "fa-question");
                  			icon.classList.add(this.config.types[this.messages[i].type]);
                  Warning - this code was entered directly here in the comment so may contain TyoPs ;)
                    Plati
                    @ianperrin nice! I still have a lot to learn. I’m just beginning to learn JS, etc.
                    Now is almost perfect:
                    Now only center the icons and reduce the spacing between the lines.
                    • I Offline
                      ianperrin @Plati
                      @Plati glad to help - and we’re all learning here so don’t worry!
                      Fontawesome provides lots of support for managing the display of icons, so if the icons are throwing the alignment in the table out try making the icons Fixed Width by adding “fa-fw” to the icon e.g. icon.classList.add("fa", "fa-fw", "fa-" …
                      Alternatively, set the icon font-size to the same as the message, by using the inbuilt MM styles, e.g. iconCell.classList.add("small");
                      or a combination of both :)
                        dominic @yawns
                        @yawns Hi, Thanks it works.
                        I have an other question.
                        how can I get the values ​​, that they will displayed in two lines?
