    Camera module
    26 Posts 13 Posters 34.5k Views 13 Watching
      James
      Great, I will try with PS3 EYE later.
      Thanks,
        James @alexyak
        @alexyak I installed the both modules and here’s some issue need to be solved.
        1. In your readme.md of camera, the sample config code need to add the missing “{}” after config:
                                module: 'camera',
                                position: 'upper_third',
                                        selfieInterval: 3,  // Time interval in seconds before the photo will be taken.
                                        emailConfig: {
                                                service: 'Hotmail', // Email provider to use to send email with a photo.
                                                auth: {
                                                        user: '<name@email.com>', // Your email account
                                                        pass: '<password>'        // Your password for email account
        1. The voicecontrol module run well, it shows tips in the screen and could recognize my voice.
        2. The three voice command works, I didn’t receive any email and I need to say “hide camera” to let the countdown disappear.
        3. Another issue is if I don’t enter some email info, the module seems to be stacked on the screen.
        4. Is there a place I could find the selfie pics in Pi?
        Thanks for you and your great modules.
          James
            James @alexyak
            @alexyak @paviro when I wanna to post the errors in mm-error-0.log, shows “Post content was flagged as spam by Akismet.com”.
            • paviroP Offline
              paviro
              Upload as a file or inline?
              – The Doctor
                James @paviro
                @paviro no permission for me to upload a file, I will try inline
                  James @alexyak
                  @alexyak
                  ALSA lib confmisc.c:1286:(snd_func_refer) Unable to find definition 'cards.bcm2835.pcm.front.0:CARD=0'
                  ALSA lib conf.c:4259:(_snd_config_evaluate) function snd_func_refer returned error: No such file or directory
                  ALSA lib conf.c:4738:(snd_config_expand) Evaluate error: No such file or directory
                  ALSA lib pcm.c:2239:(snd_pcm_open_noupdate) Unknown PCM front
                  ALSA lib pcm.c:2239:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.rear
                  ALSA lib pcm.c:2239:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.center_lfe
                  ALSA lib pcm.c:2239:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.side
                  ALSA lib confmisc.c:1286:(snd_func_refer) Unable to find definition 'cards.bcm2835.pcm.surround51.0:CARD=0'
                  ALSA lib pcm.c:2239:(snd_pcm_open_noupdate) Unknown PCM surround21
                    James
                    ALSA lib confmisc.c:1286:(snd_func_refer) Unable to find definition 'cards.bcm2835.pcm.iec958.0:CARD=0,AES0=4,AES1=130,AES2=0,AES3=2'
                    ALSA lib pcm.c:2239:(snd_pcm_open_noupdate) Unknown PCM iec958
                    ALSA lib pcm.c:2239:(snd_pcm_open_noupdate) Unknown PCM spdif
                    ALSA lib pcm.c:2239:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.hdmi
                    ALSA lib pcm.c:2239:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.modem
                    ALSA lib pcm.c:2239:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.phoneline
                    ALSA lib pulse.c:243:(pulse_connect) PulseAudio: Unable to connect: Connection refused
                    Cannot connect to server socket err = No such file or directory
                    Cannot connect to server request channel
                    jack server is not running or cannot be started
                      James
                      Between the above two error codes, there are several similar code with different “PCM surroundNo.” end (21, 40, 41, 50, 51, 71) like:
                        alexyak @James
                        @James thank you for reporting the bugs. I will try to fix them soon.
                        The code doesn’t save the photo into the file. The image data base64 encoded is passed from the camera module to the node_helper. I could add this, but am I afraid of filling up the space on the RPI.
                        Which provider did you configure the nodemailer with?
