    Camera module
    26 Posts 13 Posters 34.5k Views 13 Watching
      James
        James @alexyak
        @alexyak @paviro when I wanna to post the errors in mm-error-0.log, shows “Post content was flagged as spam by Akismet.com”.
        • paviroP Offline
          paviro
          Upload as a file or inline?
          – The Doctor
            James @paviro
            @paviro no permission for me to upload a file, I will try inline
              James @alexyak
              @alexyak
              ALSA lib confmisc.c:1286:(snd_func_refer) Unable to find definition 'cards.bcm2835.pcm.front.0:CARD=0'
              ALSA lib conf.c:4259:(_snd_config_evaluate) function snd_func_refer returned error: No such file or directory
              ALSA lib conf.c:4738:(snd_config_expand) Evaluate error: No such file or directory
              ALSA lib pcm.c:2239:(snd_pcm_open_noupdate) Unknown PCM front
              ALSA lib pcm.c:2239:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.rear
              ALSA lib pcm.c:2239:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.center_lfe
              ALSA lib pcm.c:2239:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.side
              ALSA lib confmisc.c:1286:(snd_func_refer) Unable to find definition 'cards.bcm2835.pcm.surround51.0:CARD=0'
              ALSA lib pcm.c:2239:(snd_pcm_open_noupdate) Unknown PCM surround21
                James
                ALSA lib confmisc.c:1286:(snd_func_refer) Unable to find definition 'cards.bcm2835.pcm.iec958.0:CARD=0,AES0=4,AES1=130,AES2=0,AES3=2'
                ALSA lib pcm.c:2239:(snd_pcm_open_noupdate) Unknown PCM iec958
                ALSA lib pcm.c:2239:(snd_pcm_open_noupdate) Unknown PCM spdif
                ALSA lib pcm.c:2239:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.hdmi
                ALSA lib pcm.c:2239:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.modem
                ALSA lib pcm.c:2239:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.phoneline
                ALSA lib pulse.c:243:(pulse_connect) PulseAudio: Unable to connect: Connection refused
                Cannot connect to server socket err = No such file or directory
                Cannot connect to server request channel
                jack server is not running or cannot be started
                  James
                  Between the above two error codes, there are several similar code with different “PCM surroundNo.” end (21, 40, 41, 50, 51, 71) like:
                    alexyak @James
                    @James thank you for reporting the bugs. I will try to fix them soon.
                    The code doesn’t save the photo into the file. The image data base64 encoded is passed from the camera module to the node_helper. I could add this, but am I afraid of filling up the space on the RPI.
                    Which provider did you configure the nodemailer with?
                      James @alexyak
                      @alexyak Hotmail. And one thing I need to confirm with you is that “email & password” are filled in between “‘’” or “<>”?
                        James @alexyak
                        @alexyak bug report:
                        1. pm2 won’t restart MM after a reboot and press Alt+F4 for the first time. (This occurs randomly, I tested for several times even if not the first time to press Alt+F4 after a reboot)
                        2. I need to run “pm2 restart mm” to get MM restart again.
                        3. After this sometimes the modules not work. I’m not sure which one is. camera or voicecontrol? Errors ouputs as follows:
                        Expression 'r' failed in 'src/hostapi/alsa/pa_linux_alsa.c', line: 2097
                        Expression 'PaAlsaStreamComponent_FinishConfigure( &self->capture, hwParamsCapture, inParams, self->primeBuffers, realSr, inputLatency )' failed in 'src/hostapi/alsa/pa_linux_alsa.c', line: 2731
                        Expression 'PaAlsaStream_Configure( stream, inputParameters, outputParameters, sampleRate, framesPerBuffer, &inputLatency, &outputLatency, &hostBufferSizeMode )' failed in 'src/hostapi/alsa/pa_linux_alsa.c', line: 2843
                          File "./modules/voicecontrol/snowboy/kws-multiple.py", line 34, in <module>
                            detector = snowboydecoder.HotwordDetector(models, sensitivity=sensitivity)
                          File "/home/pi/MagicMirror/modules/voicecontrol/snowboy/snowboydecoder.py", line 115, in __init__
                            stream_callback=audio_callback)
                          File "/usr/lib/python2.7/dist-packages/pyaudio.py", line 747, in open
                            stream = Stream(self, *args, **kwargs)
                          File "/usr/lib/python2.7/dist-packages/pyaudio.py", line 442, in __init__
                            self._stream = pa.open(**arguments)
                        IOError: [Errno Unanticipated host error] -9999
                        1. Finally, I received Selfie, that the email & passward need to be filled in without “<>”. You may change the sample config code in the readme.md as well :)
                        Thanks,
