    Camera module
    26 Posts 13 Posters 37.7k Views 13 Watching
    • A
      alexyak
      I’ve just published the camera module. Besides displaying a video feed on your mirror, it could also take photos and email them.
      [card:alexyak/camera]
      J 3 Replies Last reply Reply Quote 2
        James
        Great, I will try with PS3 EYE later.
        Thanks,
          James @alexyak
          @alexyak I installed the both modules and here’s some issue need to be solved.
          1. In your readme.md of camera, the sample config code need to add the missing “{}” after config:
                                  module: 'camera',
                                  position: 'upper_third',
                                          selfieInterval: 3,  // Time interval in seconds before the photo will be taken.
                                          emailConfig: {
                                                  service: 'Hotmail', // Email provider to use to send email with a photo.
                                                  auth: {
                                                          user: '<name@email.com>', // Your email account
                                                          pass: '<password>'        // Your password for email account
          1. The voicecontrol module run well, it shows tips in the screen and could recognize my voice.
          2. The three voice command works, I didn’t receive any email and I need to say “hide camera” to let the countdown disappear.
          3. Another issue is if I don’t enter some email info, the module seems to be stacked on the screen.
          4. Is there a place I could find the selfie pics in Pi?
          Thanks for you and your great modules.
            James
              James @alexyak
              @alexyak @paviro when I wanna to post the errors in mm-error-0.log, shows “Post content was flagged as spam by Akismet.com”.
                paviro
                Upload as a file or inline?
                – The Doctor
                  James @paviro
                  @paviro no permission for me to upload a file, I will try inline
                    James @alexyak
                    @alexyak
                    ALSA lib confmisc.c:1286:(snd_func_refer) Unable to find definition 'cards.bcm2835.pcm.front.0:CARD=0'
                    ALSA lib conf.c:4259:(_snd_config_evaluate) function snd_func_refer returned error: No such file or directory
                    ALSA lib conf.c:4738:(snd_config_expand) Evaluate error: No such file or directory
                    ALSA lib pcm.c:2239:(snd_pcm_open_noupdate) Unknown PCM front
                    ALSA lib pcm.c:2239:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.rear
                    ALSA lib pcm.c:2239:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.center_lfe
                    ALSA lib pcm.c:2239:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.side
                    ALSA lib confmisc.c:1286:(snd_func_refer) Unable to find definition 'cards.bcm2835.pcm.surround51.0:CARD=0'
                    ALSA lib pcm.c:2239:(snd_pcm_open_noupdate) Unknown PCM surround21
                      James
                      ALSA lib confmisc.c:1286:(snd_func_refer) Unable to find definition 'cards.bcm2835.pcm.iec958.0:CARD=0,AES0=4,AES1=130,AES2=0,AES3=2'
                      ALSA lib pcm.c:2239:(snd_pcm_open_noupdate) Unknown PCM iec958
                      ALSA lib pcm.c:2239:(snd_pcm_open_noupdate) Unknown PCM spdif
                      ALSA lib pcm.c:2239:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.hdmi
                      ALSA lib pcm.c:2239:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.modem
                      ALSA lib pcm.c:2239:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.phoneline
                      ALSA lib pulse.c:243:(pulse_connect) PulseAudio: Unable to connect: Connection refused
                      Cannot connect to server socket err = No such file or directory
                      Cannot connect to server request channel
                      jack server is not running or cannot be started
                        James
                        Between the above two error codes, there are several similar code with different “PCM surroundNo.” end (21, 40, 41, 50, 51, 71) like:
                        • A
                          alexyak @James
                          @James thank you for reporting the bugs. I will try to fix them soon.
                          The code doesn’t save the photo into the file. The image data base64 encoded is passed from the camera module to the node_helper. I could add this, but am I afraid of filling up the space on the RPI.
                          Which provider did you configure the nodemailer with?
                            James @alexyak
                            @alexyak Hotmail. And one thing I need to confirm with you is that “email & password” are filled in between “‘’” or “<>”?
                              James @alexyak
                              @alexyak bug report:
                              1. pm2 won’t restart MM after a reboot and press Alt+F4 for the first time. (This occurs randomly, I tested for several times even if not the first time to press Alt+F4 after a reboot)
                              2. I need to run “pm2 restart mm” to get MM restart again.
                              3. After this sometimes the modules not work. I’m not sure which one is. camera or voicecontrol? Errors ouputs as follows:
                              Expression 'r' failed in 'src/hostapi/alsa/pa_linux_alsa.c', line: 2097
                              Expression 'PaAlsaStreamComponent_FinishConfigure( &self->capture, hwParamsCapture, inParams, self->primeBuffers, realSr, inputLatency )' failed in 'src/hostapi/alsa/pa_linux_alsa.c', line: 2731
                              Expression 'PaAlsaStream_Configure( stream, inputParameters, outputParameters, sampleRate, framesPerBuffer, &inputLatency, &outputLatency, &hostBufferSizeMode )' failed in 'src/hostapi/alsa/pa_linux_alsa.c', line: 2843
                                File "./modules/voicecontrol/snowboy/kws-multiple.py", line 34, in <module>
                                  detector = snowboydecoder.HotwordDetector(models, sensitivity=sensitivity)
                                File "/home/pi/MagicMirror/modules/voicecontrol/snowboy/snowboydecoder.py", line 115, in __init__
                                  stream_callback=audio_callback)
                                File "/usr/lib/python2.7/dist-packages/pyaudio.py", line 747, in open
                                  stream = Stream(self, *args, **kwargs)
                                File "/usr/lib/python2.7/dist-packages/pyaudio.py", line 442, in __init__
                                  self._stream = pa.open(**arguments)
                              IOError: [Errno Unanticipated host error] -9999
                              1. Finally, I received Selfie, that the email & passward need to be filled in without “<>”. You may change the sample config code in the readme.md as well :)
                              Thanks,
                                James
                                • cowboysdudeC
                                  That’s pretty cool! Great job!
                                    jeremytripp
                                    Tested the voice control + camera module today and got both working. Thanks @James for the tip on the missing config curly brackets. Was starting to drive me crazy as no JS Linters were picking it up.
                                    For future reference, the voice control module now comes pre-packaged with the three camera commands by default in the voicecontrol.js file, so in your config.js file, you only need to add:
                                        module: 'voicecontrol',
                                        position: 'bottom_left'
                                    In fact, if you do add the config: definitions and any keywords to your config.js file, it actually overrides the three default camera commands. With that said, is it best practice to add additional keyword commands to voicecontrol.js OR to remove the defaults from voicecontrol.js and place everything in config.js?
                                    I also get the ALSA lib error messages in Terminal after quitting the mirror, as well as the countdown bug James mentions after taking a picture, but everything seems to work and I DID receive the email no problem (using Gmail, after following @alexyak’s instructions on “Allowing Less Secure Apps” and “Allowing Access To Your Gmail Account”).
                                    All in all, awesome work, Alex! Thrilled to now have 3 of your modules running on my mirror as I’m running motion sensor too!
                                      jeremytripp
                                      Follow up: I tried both configurations and it only works when all voice command keywords are in voicecontrol.js, so that answers my question, I suppose!
                                      • T
                                        thereisnotry87 @jeremytripp
                                        @jeremytripp First of all thanks to post your experience, it was very self-explanatory. So…did you get these kind of ALSA lib error messages?
                                        *ALSA lib pcm_dmix.c:1022:(snd_pcm_dmix_open) unable to open slave*
                                        *ALSA lib pcm.c:2239:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.rear
                                        ALSA lib pcm.c:2239:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.side*
                                        *ALSA lib pcm.c:2239:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.hdmi*
                                        ALSA lib pcm.c:2239:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.phoneline*
                                        *ALSA lib pulse.c:243:(pulse_connect) PulseAudio: Unable to connect: Connection refused*
                                        *Cannot connect to server socket err = No such file or directory
                                        Cannot connect to server request channel*
                                        *jack server is not running or cannot be started*
                                        I’ve already seen that @James got similar errors but at least for him it worked (video display top centred and taking pictures). In my case nothing happens when I send the voice command.
                                        Any suggestions? I love the support of this community.
                                        • T
                                          thereisnotry87
                                          Mmm first it would be nice to check if the microphone is recording…anyway can anyone suggest me an IDE at least to make a good code debugging? Because I’m currently working with a text editor on Rasp pi.
                                          • V
                                            vageesh79 @James
                                            @James Hi Can you please tell how you get the ps camera working on your pi. I have been doing that but i cannot get it to work.
