    MMM-NOAA3 - Font size
    8 Posts 3 Posters 1.9k Views
    • V
      vortex
      just installed MMM-NOAA3 module and every thing is fine so far - great module.
      However, I think the font size is far too small. I can hardly read the numbers and letters. Can someone help me how I can increase the font size? I know there is a custom css. but Ihonestly, I m not really familiar with that.
      What do I have to add/to change in order to increase the size of the letters and numbers - only for this module?
      Thanks !
      Best regards!
      • cowboysdudeC
        In the css files you can see each classList and go into your css file and adjust the font sizes :)
        There are a few places and putting them all in your custom.css would take a while…
        So make a backup copy of the css you are want to change and have at it ;)
        • V
          vortex
          thanks for your reply. Unfortunately I am not very familiar with this. Can you please tell me which parameter i ahve to change to increase font size?
          Apart from that, I di a git pull update yesterday (MM showed a notification about an update) and now I do not have the icons anymore… what can I do now?
          Thanks!
          Best regards
          • cowboysdudeC
            cowboysdude Module Developer @vortex
            @vortex Not sure what that happened because the only thing updated was the moon data…
            What provider are you using?
            • V
              vortex
              thanks for help. some icons re-appeared, some are still missing.
              I m using weatherbit as provider.
              I still have issues with the font size - I do not know what I have to change.
              Best regards!
              • cowboysdudeC
                @vortex ahhhhhhhhh yeah that one has been a thorn in my side… I will look at it tonight and see what’s going on. Sounds to me like you don’t have all the images in your image directory ;)
                • MedoM
                  Medo
                  I also have a problem with the font size of MMM-NOAA3
                  Can anyone tell me please, where to customize the font size of this lower part of the module:
                  I tried every part of the original css file in my custom.css but nothing had the right effect…
                  Thanks!
                  MedoM 1 Reply Last reply Reply Quote 0
                  • MedoM
                    Medo @Medo
                    @myself: ;-)
                    Found the solution by myself. I had the “.xsmall” part copied over from the original css file in my custom.css
                    This one is used to scale the font size…
