    MMM-NOAA3 - Font size
    8 Posts 3 Posters 2.9k Views 4 Watching
    • cowboysdudeC Offline
      In the css files you can see each classList and go into your css file and adjust the font sizes :)
      There are a few places and putting them all in your custom.css would take a while…
      So make a backup copy of the css you are want to change and have at it ;)
      • V Offline
        vortex
        thanks for your reply. Unfortunately I am not very familiar with this. Can you please tell me which parameter i ahve to change to increase font size?
        Apart from that, I di a git pull update yesterday (MM showed a notification about an update) and now I do not have the icons anymore… what can I do now?
        Thanks!
        Best regards
          cowboysdude Module Developer @vortex
          @vortex Not sure what that happened because the only thing updated was the moon data…
          What provider are you using?
          • V Offline
            vortex
            thanks for help. some icons re-appeared, some are still missing.
            I m using weatherbit as provider.
            I still have issues with the font size - I do not know what I have to change.
            Best regards!
              @vortex ahhhhhhhhh yeah that one has been a thorn in my side… I will look at it tonight and see what’s going on. Sounds to me like you don’t have all the images in your image directory ;)
              • MedoM Offline
                Medo
                I also have a problem with the font size of MMM-NOAA3
                Can anyone tell me please, where to customize the font size of this lower part of the module:
                I tried every part of the original css file in my custom.css but nothing had the right effect…
                Thanks!
                MedoM 1 Reply Last reply Reply Quote 0
                • MedoM Offline
                  Medo @Medo
                  @myself: ;-)
                  Found the solution by myself. I had the “.xsmall” part copied over from the original css file in my custom.css
                  This one is used to scale the font size…
