    Simple daily countdown timer
    20 Posts 4 Posters 10.2k Views 4 Watching
      andreasm80
      Hi again!
      I managed to get the module installed and configured before their bedtime today, today they were in their beds even a couple of minutes before bedtime ;-) ;-)
      So I can confirm the module is working, haha.
      Thanks for your time and help with this @Sean, the extra features you added was spot on!
      Thanks to both of you for your contributions. I am aslo using two of your modules @Mykle1 (Earth and Lunartic).
        Mykle1 Project Sponsor Module Developer @andreasm80
        @andreasm80 said in Simple daily countdown timer:
        Ahh, in that case, I thank you twice! :thumbsup:
          Richard238 @Mykle1
          @mykle1 I just added this module as it looks good for something I would like to do.
          However, nothing happens. MM starts up OK, but the module doesn’t show.
                  disabled: false,
                  module: 'MMM-EventHorizon',
                  position: 'bottom_right',
                      size: "large", // small, medium or large
          	    countUp: "yes", // Yes or no (when timer ends)
                      date: "2018-12-03", // (YYYY-MM-DD)  Date timer will end
                      time: "00:00:01", // (HH:MM:SS)    Exact time you want timer to end
          	    text1: "Open the damn pool", // 1st line of text during timer. About 18 characters total.
                      text2: "Winter sucked ass", // 2nd line of text during timer. About 18 characters total.
                      endText1: "It's gonna be fun", // 1st line of text when timer ends. About 18 characters total.
                      endText2: "Where's my bikini", // 2nd line of text when timer ends. About 18 characters total.
          GitHub shows - disabled: f,
          Here it shows - disabled: false,
          Is that an issue?
          Thanks.
          ? Mykle1M 2 Replies Last reply Reply Quote 0
            A Former User @Richard238
            @richard238
            true/false is a predefined javascript type. ‘false’ (without quotation marks) is right.
              Mykle1 Project Sponsor Module Developer @Richard238
              @richard238 said in Simple daily countdown timer:
              I just checked the repo. I inserted vars for true and false in my config so I don’t have to type the entire word. A little trick my guru taught me. However, I don’t find that in the config example there.
                      disabled: false,
                      position: 'bottom_center',
                          date: "2018-07-04",                  // (YYYY-MM-DD)  Date timer will end
                Richard238
                OK, got it working now.
                Had to fudge the time to make it work for GMT.
                How do you change the time zone properly?
                  Because this is an iframe/module that is not very easy to do. However, I can tell you how to fix yours. I’ll make it easy.
                  In your MMM-EventHorizon.js file, lines 38, 41, 44, 50, 52 and 54 (see picture) at the end of each line, between the last 2 “/” is the value n179. See it in the picture? For GMT you would change that to n136. Change only that in each line. Save.
                    Richard238
                    @mykle1 said in Simple daily countdown timer:
                    n179
                    					if (this.config.countUp == "yes" && this.config.size == "small"){
                    						// small
                    						iframe.src = "http://free.timeanddate.com/countdown/i6f519yg/n136/cf12/cm0/cu4/ct0/cs0/ca0/cr0/ss0/cac0ff/cpc0ff/pc000/tcfff/fs100/szw256/szh108/tat" + this.config.text1 + "/tac0ff/tpt" + this.config.endText1 + "/tpc0ff/mat" + this.config.text2 + "/mac0ff/mpt" + this.config.endText2 + "/mpc0ff/iso" + this.config.date + "T" + this.config.time;
                    					} else if (this.config.countUp == "yes" && this.config.size == "medium") {
                    						// medium
                    						iframe.src = "http://free.timeanddate.com/countdown/i6f519yg/n136/cf12/cm0/cu4/ct0/cs0/ca0/cr0/ss0/cac0ff/cpc0ff/pc000/tcfff/fs100/szw320/szh135/tat" + this.config.text1 + "/tac0ff/tpt" + this.config.endText1 + "/tpc0ff/mat" + this.config.text2 + "/mac0ff/mpt" + this.config.endText2 + "/mpc0ff/iso" + this.config.date + "T" + this.config.time;
                    					} else if (this.config.countUp == "yes" && this.config.size == "large") {
                    					  // large
                    						iframe.src = "http://free.timeanddate.com/countdown/i6f519yg/n136/cf12/cm0/cu4/ct0/cs0/ca0/cr0/ss0/cac0ff/cpc0ff/pc000/tcfff/fs100/szw576/szh243/tat" + this.config.text1 + "/tac0ff/tpt" + this.config.endText1 + "/tpc0ff/mat" + this.config.text2 + "/mac0ff/mpt" + this.config.endText2 + "/mpc0ff/iso" + this.config.date + "T" + this.config.time;
                            if (this.config.countUp != "yes" && this.config.size == "small"){
                                iframe.src = "http://free.timeanddate.com/countdown/i64zeztz/n136/cf100/cm0/cu4/ct5/cs0/ca0/cr0/ss0/cac33d9ff/cpc000/pct/tcfff/fs100/szw192/szh81/tat" + this.config.text1 + "/tac33d9ff/tpt" + this.config.endText1 + "/tpc33d9ff/mat" + this.config.text2 + "/mac33d9ff/mpt" + this.config.endText2 + "/mpc33d9ff/iso" + this.config.date + "T" + this.config.time + "/bo2/pd2";
                            } else if (this.config.countUp != "yes" && this.config.size == "medium") {
                                iframe.src = "http://free.timeanddate.com/countdown/i67bgd3d/n136/cf12/cm0/cu4/ct0/cs1/ca0/cr0/ss0/cac0ff/cpc0ff/pct/tcfff/fs100/szw448/szh189/tat" + this.config.text1 + "/tac0ff/tpt" + this.config.endText1 + "/tpc0ff/mat" + this.config.text2 + "/mac0ff/mpt" + this.config.endText2 + "/mpc0ff/iso" + this.config.date + "T" + this.config.time + "/bo2/pd2";
                            } else if (this.config.countUp != "yes" && this.config.size == "large") {
                                iframe.src = "http://free.timeanddate.com/countdown/i67bgd3d/n136/cf12/cm0/cu4/ct0/cs1/ca0/cr0/ss0/cac0ff/cpc0ff/pct/tcfff/fs100/szw576/szh243/tat" + this.config.text1 + "/tac0ff/tpt" + this.config.endText1 + "/tpc0ff/mat" + this.config.text2 + "/mac0ff/mpt" + this.config.endText2 + "/mpc0ff/iso" + this.config.date + "T" + this.config.time + "/bo2/pd2";
                    Changed n179 to n136, as shown.
                    Stopped and restarted MM.
                    Did not change time in config.js, and expected results to now be incorrect, but there’s no change.
                    The module still shows the correct time for my countdown.
                      @richard238
                      Ok, give me some time. I’m in the middle of trying to fix another module at the same time. In the meantime, continue to use it with your “fudging” if you like. Sorry about the inconvenience.
                        @richard238
                        Ok, wait. I just did exactly what I asked you to do yours and tested it. It works as I said it would. I set the date and time for midnight tonight. As you can see from my screenshot, my clock reports the current time of 5:57pm, yet MMM-EventHorizon reports the correct time if I were in GMT. I think you have something else going on there.
                        R ? 2 Replies Last reply Reply Quote 1
                          Richard238 @Mykle1
                          @mykle1 Peculiar. I’ve no idea why it’s giving different results for you.
                          I’ll have a play when I have time, but for now the ‘fudge-fix’ (deducting five hours in config.js) works ok for me.
                          Thank you!
                            Richard238
                            Well this is very odd.
                            Another MM stop/start seems to have fixed it.
                            Happy days! :)
                              A Former User @Mykle1
                              @mykle1
                              @Mykle1 Sorry for unrelated issue, but, what is the font name of your left side clock of above image?
                                Mykle1 Project Sponsor Module Developer @Guest
                                @sean
                                @import url('https://fonts.googleapis.com/css?family=Titillium+Web');
                                #clock {
                                    font-size: 40px;
                                    font-family: 'Titillium Web', sans-serif;
