    run Linux command from a mm2 module
    20 Posts 5 Posters 7.5k Views 5 Watching
      sdetweil @Mykle1
      @mykle1 let me see what I can do.
      Will be tomorrow.
        A Former User @Mykle1
        @mykle1
        You can use Regular Expression for getting matched text with pattern.
        var s = stdout
        var fan1 = new RegExp("fan1\:\s+([0-9]+ RPM)")
        var fan1_found = s.match(fan1)
        console.log(fan1_found, fan1_found[1])
        Not tested in real PC, so there could be a mistake.
        • Mykle1M
          Mykle1 Project Sponsor Module Developer @Guest
          @sean
          First, thank you for your input. I do appreciate it.
          1. Adding your suggestion results in an uncaught exception. . . TypeError: Cannot read property ‘1’ of null
          2. Using your suggestion and taking out the “[1]” results in an array with a single object
            @mykle1
            null means not found. Maybe my regular espression pattern was wrong. As I wrote, it was not tested.
            However if you find proper expression pattern, it will return matched string. Google it about regular expression. That is a standard way to search or replace text by pattern in most of program languages.
            • Mykle1M
              @sean
              ok thank you. This seems like a good place to start.
              https://www.regular-expressions.info/
                @mykle1
                • https://www.w3schools.com/jsref/jsref_obj_regexp.asp
                • https://www.w3schools.com/jsref/jsref_match.asp
                  See these also.
                • Mykle1M
                  @sean
                  See these also.
                  Thanks!
                  • Mykle1M
                    @sdetweil said in run Linux command from a mm2 module:
                    Will be tomorrow.
                    Thanks! Anything you can offer will be much appreciated.
                    This what I have, and sent to the module.js
                      @mykle1
                      test.js
                      var str = `nouveau-pci-0100↵Adapter: PCI adapter↵fan1:        1170 RPM↵temp1:        +43.0°C  (high = +95.0°C, hyst =  +3.0°C)↵                       (crit = +105.0°C, hyst =  +5.0°C)↵                       (emerg = +135.0°C, hyst =  +5.0°C)↵↵coretemp-isa-0000↵Adapter: ISA adapter↵Core 0:       +46.0°C  (high = +83.0°C, crit = +99.0°C)↵Core 1:       +41.0°C  (high = +83.0°C, crit = +99.0°C)↵Core 2:       +46.0°C  (high = +83.0°C, crit = +99.0°C)↵Core 3:       +38.0°C  (high = +83.0°C, crit = +99.0°C)↵↵f71858fg-isa-0a00↵Adapter: ISA adapter↵+3.3V:        +3.31 V  ↵3VSB:         +3.30 V  ↵Vbat:         +3.20 V  ↵fan1:        1910 RPM↵fan2:        1069 RPM↵fan3:           0 RPM  ALARM↵temp1:        +34.5°C  (high = +70.0°C, hyst = +60.0°C)↵temp2:        +29.5°C  (high = +100.0°C, hyst = +85.0°C)↵temp3:        +36.4°C  (high = +100.0°C, hyst = +85.0°C)↵↵`
                      var pattern = [
                        "(fan[0-9]):[\\s]+([0-9]+ RPM)",
                        "(temp[0-9]):[\\s]+(\\+[0-9\\.]+°C)",
                      for (i = 0; i < pattern.length; i++) {
                        var rx = new RegExp(pattern[i], "g")
                        var found
                        do {
                          found = rx.exec(str)
                          if (found) console.log(found[1], found[2])
                        } while(found)
                      RESULT
                      • Mykle1M
                        @sean said in run Linux command from a mm2 module:
                        RESULT
                        Excellent sean! Working here as well. You have my eternal gratitude. :thumbsup:
                        EDIT
                        Using your example above as a guide I was able to add to the pattern array successfully.
                        My addition
                        "(Core [0-9]):[\\s]+(\\+[0-9\\.]+°C)"
                        Result
                        Now I’ll do the ones I want. Thank you again, sean. This is awesome!
                          sdetweil @Mykle1
                          @mykle1 @sean nice work. Sorry I ran out of time.
                          • Mykle1M
                            No worries, bro. I appreciate your interest and concern. I’m sure I’ll need help in the future. You can get in on that. :-)
