    MMM-MyScoreboard
    277 Posts 60 Posters 623.3k Views 63 Watching
    • BKeyportB Offline
      BKeyport Module Developer
      Cool, Thanks, Vince - I’ve merged your updates into my fork, and I’m playing with it now. Thinking about playing around with the other (what I would consider) improvement cases I wanna do, having two or three modules to show scoreboards that are all different does irritate me to no end… :)
      • BKeyportB Offline
        FWIW, I seem to have a legit bug - the group “Pac-12” seems to go random on teams in NCAAF. (using my fork of VinP’s fork of the module), I’ve overridden it by putting all the teams in individually for now.
        • BKeyportB Offline
          Vince, Your mod works perfectly - once I undo mine.
          Thanks for the head start to see how it’s modified. Will be fun to learn.
            cyberphox
            Anyone else missing a few NFL logos lately?
            • BKeyportB Offline
              Happens from time to time. I just turned off the logos…
                j.e.f.f Project Sponsor Module Developer @cyberphox
                @cyberphox Is this on the original codebase or a fork? Mine looks like this:
                • Jeff
                • W Offline
                  Wedee @j.e.f.f
                  @j-e-f-f
                  Using your repo - not the fork. Getting this today.
                  • W Offline
                    Wedee @Wedee
                    @j-e-f-f
                    Just double checked…
                    Git Pull “Up to date”
                    And pulling from original repo…
                      j.e.f.f Project Sponsor Module Developer @Wedee
                      @wedee try deleting the module and reinstalling. Not sure you’re getting the most latest. Something happened with hit on the last update where things got a little out of sync.
                      Not saying this will solve your issue but will eliminate one factor.
                      I’m wondering if this is a memory issue…
                        cyberphox @j.e.f.f
                        @j-e-f-f I just deleted the whole folder and reinstalled and still missing a few…although i did have a fork installed a few weeks ago…not sure if that did anything
                          @cyberphox do all of the logos appear of you change your config to just show you NFL? Or if you configure it for just one of the teams that isn’t showing? I’m beginning to think the issue might be video memory.
                          I remember when I configured my Pi I increased the amount of video memory allocated specifically because this needed to be run in the GUI desktop environment. Not sure how it behaves under the default settings.
                            cyberphox
                            Just tested with only NFL showing…I get this:
                            • V Offline
                              vinp Module Developer @cyberphox
                              @cyberphox can you try getting to your MM via URL in a remote browser http://yourPi-IPaddress:8080 ? You can then look at Developer Tools in Chrome/Firefox etc and dig into the image element that should be showing for each team. My fork works fine for images of the NFL. It takes the image URL via the ESPN feed for the logo. The original code, has local images for each team.
                                cyberphox
                                Running it in a Docker container on Synology…got it remotely open on Chrome…got the Developer Tools open…
                                I do have a logos folder with all the Team logos there so not sure why only a few show
                                Looks like the Was log for example is pointing to a file that does exist:
                                  @cyberphox OH I see the problem! The file name is WAS.svg not Was.svg (Notice the difference in case). That should be an easy fix to simply force uppercase. Will publish a fix tonight.
                                    @cyberphox OK this should be fixed now. Do a git pull and let me know if it’s resolved for you.
                                      cyberphox
                                      How the heck did I not see this myself? I seriously even checked the first let to see if it was a capital issue…should’ve kept going! lol
                                      Seems fixed! Thanks man!
                                        Achilles
                                        Happy New Year all!
                                        I am not seeing NHL scores now. Actually, I only have one team that I am trying to follow (Tampa Bay Lightning) and that score is failing to pop up in the Scoreboard now. I did do a git pull a week ago, but my results are the same. Am I missing something?
                                          j.e.f.f Project Sponsor Module Developer @Achilles
                                          @achilles I messed up with the commits and in my attempt to fix it, I might have left all installs in an odd state, where a git pull doesn’t seem to work. Please delete the module directory and reinstall to get the latest code. Hopefully that will fix your issue. Give it a shot and post back letting me know if it worked.
                                            Achilles
                                            @j-e-f-f Thanks!
                                            That did the trick! Much appreciated for the help!
                                            • 10
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 9 / 14
