    MMM-EyeCandy not refreshing
    12 Posts 4 Posters 8.0k Views 4 Watching
      Mykle1 Project Sponsor Module Developer @colel83
      @colel83 said in MMM-EyeCandy not refreshing:
      Anyone else using this module with success?
      I am! :-)
      I assure you, the module is updating as expected. Can you give me the url that you are trying to use it with and I will test it?
        colel83
        I sure can, it’s http://images.intellicast.com/WxImages/RadarLoop/dsm_None_anim.gif
        Thanks for your help! I let it sit for over 2 hours last weekend and the timestamps on the radar images never changed. The site updates the loop every 15 minutes roughly.
          @colel83
          Ok, I tested your url and the module does update as expected, including the radar image from the url. I ran MM on my left monitor and a google Chromium window on my right monitor. MMM-EyeCandy (set to 5 minute update) updated and refreshed the url as expected. The url in the Chromium window did not, unless manually refreshed. I cannot reproduce the behavior you are expressing.
          I would start by deleting your current installation of MMM-EyeCandy and doing a fresh installation of the module. It only takes a second. Then please post your config entry for EyeCandy here, in a code block so I can have a look at it for you
          C 2 Replies Last reply Reply Quote 0
            A Former User
              Mykle1 Project Sponsor Module Developer @Guest
              @sean
              It’s working just fine for me
                colel83 @Mykle1
                  colel83 @Mykle1
                  @mykle1
                  Your module is working just fine. After hiding other modules one at a time, it appears that the module MMM-ecobee is preventing the EyeCandy module from refreshing. I don’t have any experience with coding so I can’t even begin to figure out why this might happen but I appreciate your help in solving this for me. If I use the auto refresh module to refresh the entire mirror every 10 minutes everything seems to work okay so I guess that is what I will have to do. Thanks again for the help and thanks for the EyeCandy module!!
                  Mykle1M 2 Replies Last reply Reply Quote 1
                    That is odd. I don’t use the ecobee module so I can’t speak to that. I’m glad EyeCandy is working for you now. Have fun.
                      @colel83
                      I thought I might tell you this. I went to your url site and got one of my own. I now have EyeCandy displaying my own personalized radar.
                        colel83
                        :thumbs_up: :thumbs_up:
                        KamiSchamiK 1 Reply Last reply Reply Quote 1
