    Which type of mirror to use
    14 Posts 6 Posters 12.1k Views 7 Watching
      radokristof
      Hi Everyone!
      I have started developing my mirror. However I couldn’t find exact information about which glass will look the best. Should it be acrylic or anything else? The transmittance should be 50/50 or more like 70/30?
      Thanks!
        j.e.f.f Project Sponsor Module Developer @radokristof
        @radokristof Between glass and acrylic, if you have a smaller mirror, then it probably doesn’t matter, and acrylic should save you a bit of money. On a larger mirror, you might see some distortion due to the acrylic flexing.
        Transmittance depends on the brightness of your room. If the location of your mirror will get a lot of natural light, then you’ll want a higher level of transmittance. If it’s in a darker location, then 20 - 30% transmittance will be fine.
        • lavolp3L Offline
          lavolp3 Module Developer @j.e.f.f
          @j-e-f-f said in Which type of mirror to use:
          I can’t really agree on transmittance. Isn’t 20-30% much too high for a darker room?
          The glass I have in mind as one of the best experienced is Pilkington MirroPane ChromeSpy.
          It has a transmittance of 8% and I hear that’s very good for rooms with natural lighting…
          My current view:
          Two values are important in terms of glass: Reflectance and transmittance.
          Highest possible reflectance is always best as I would assume. Values of >60% are good. The more the better
          Transmittance of < 10% is best for darker rooms
          Transmittance of > 5% is best for lit rooms.
          Please correct me if I’m wrong…
          How to troubleshoot modules
          MMM-soccer v2, MMM-AVStock
            j.e.f.f Project Sponsor Module Developer @lavolp3
            @lavolp3 I guess it depends on the glass itself. I’m using glass from Academy Glass (https://www.academyglassandmirror.ca/) with 20% transmittance and in a dark room picture is very clear. When the room is bright, sometimes it’s difficult to see the smart display stuff.
              radokristof
              Thanks!
              In general it is a dark place where the mirror will be placed (in the anteroom), it has no window, but because of this, we turn on the light almost always when we are there. So I don’t know what will be better. But it depends on screen brightness also, right?
              I think in general when the lights on, it is considered as a normal room.
              D lavolp3L 2 Replies Last reply Reply Quote 0
                dazza120 @radokristof
                @radokristof yep also the location, bathroom get the glass when the bathroom steams up it won’t scratch as easy as the acrylic, I’ve gone for pilkington mirrorview 50/50
                • lavolp3L Offline
                  lavolp3 Module Developer @radokristof
                  @radokristof I have a mirror in quite a dark room installed, where usually we have lights on.
                  I use a glass called mirastar in this
                  Reflectance 58%.
                  Transmission 3%.
                  In this case the transmittance of 3% is well enough. All of the modules can be seen very well although I have to admit that I have played with the css styles making all the brightness levels a bit brighter. When lighting is on the monitor frame can only be seen when you look very closely.
                  However, I’m not completely satisfied with the reflection of the glass. There is a brown tint to it and the mirror looks a bit too dark.
                  Hopefully today I’ll pick up my new Chrome Spy then I have a comparison.
                  @j-e-f-f I was hoping that at least these values are comparable since they are physical ones and should not be limited to a glass brand.
                  J M 2 Replies Last reply Reply Quote 0
                    @lavolp3 said in Which type of mirror to use:
                    Heh! Like most things in life it appears that standards are seldom very standard!
                      MickyVi @lavolp3
                      @lavolp3
                      ciao lavolp3,
                      it’s the same one I bought, I picked it up yesterday, but I’m not that satisfied either, did you find any solution about it?
                      I’m quite disappointed with this, it took me several weeks to develop and two weeks to get the glass ready. :-(
                      Ciao
                      • lavolp3L Offline
                        lavolp3 Module Developer @MickyVi
                        @mickyvi Ciao Micky,
                        Meanwhile I am using a mirror provided by Goldjunge_Chriz though one of his mirror distribution activities. I think the chrome spy is nearly as good and better than the mirastar.
                        Very important is the monitor. You need to play with brightness (as low as possible), contrast (as high as possible) and ( in my case) also the control of each rgb color to get best results for the black background.
                        Also don’t forget that you can set brightness of the text to a higher level via css.
                        But none of the mirrors i have used are even close to an actual mirror. It is different.
                          MickyVi @lavolp3
                          @lavolp3
                          Ciao Volpe,
                          in the meantime, thanks for the advice, I tried and in fact I managed to increase the brightness of the text a little (I didn’t succeed as you indicated via css). In any case, it is really a monitor problem (I recovered them from the basket of PCs to be disposed of in the company), they are 2 nb Hp 250 G6 Beo monitors, they are not too bad, but they are not missing the top, I tried to put a tablet behind the glass and the result is really good both in terms of black and in terms of brightness.
                          Who knows’ that in the future, if I find two identical ones (I have two mirrors in the bathroom …) I might think about it.
                          Anyway, thanks for the suggestions and now, I launch into the setting of the RCWL-0516 sensor that I saw that you are in the trenches with that too, I want to try this one that has already integrated the rotary for the sensitivity:
                          [link text](https://www.amazon.it/CQRobot-10-525GHz-Microwave-Compatible-Measurement/dp/B089NKGWQQ/ref=pd_day0_3/257-4432238-8577840?pd_rd_w=mQj2z&pf_rd_p=2a4cbc0a-de25-48fb-acfc-b5dc3175ff51&pf_rd_r=G0GKYXH5QQKMFX9KP3YA&pd_rd_r=7c5d2780-ea90-4384-bbc8-59108d4791ef&pd_rd_wg=n7WUF&pd_rd_i=B089NKGWQQ&psc=1)
                          Ciao thank you
                          • lavolp3L Offline
                            @mickyvi said in Which type of mirror to use:
                            Ciao thank you
                            Grazie.
                            This one is very very expensive but interesting. Let us know if you’re satisfied with it.
                            FYI, this is how I manipulate CSS to get brighter text:
                            .dimmed {
                              color: #aaaaaa;
                            .normal {
                              color: #fdfdfd;
                            .bright {
                              color: #ffffff;
                            body {
                              color: #fdfdfd;
                            The selectors are usually used in the modules to highlight or dim text. The body color property is the fallback in case no other selector is used. So I set it as the same color as normal.
                            You can find all the selectors in main.css where less birght colors have been used. In custom.css you can overwrite the properties.
                            StoffbeuteluweS M 2 Replies Last reply Reply Quote 1
                            • StoffbeuteluweS Offline
                              Stoffbeuteluwe Project Sponsor @lavolp3
                              @lavolp3 thanks will try today …
                                MickyVi @lavolp3
                                @lavolp3
                                Ciao,
                                I think I will try the one recommended in this tutorial first, it all arrived yesterday, this afternoon I start the tests (… and the swearing …: -) …), my hands are big and my sight it’s not much …
                                I will also try the css code to increase the brightness of the characters.
                                I am attaching some photos on the state of the work, I would say that I am at a good point, too bad for the infrared pir that stole some time, if I knew that there was this tutorial I passed directly to the doppler sensors …
                                That’s okay, art that comes in :-)
