    MMM-DarkSkyForecast - Yet ANOTHER weather module
    334 Posts 67 Posters 933.2k Views 74 Watching
      Smotx @j.e.f.f
      @j-e-f-f
      I want to reduce free space identified by “red areas” on this screen :
      alt text
      J 2 Replies Last reply
        j.e.f.f Project Sponsor Module Developer @Smotx
        @smotx screenshot didn’t come through. You don’t need to host the image on Imagur. You can upload it directly when editing your post. Just drag it in, or hit the cloud/upload icon.
        • BKeyportB
          BKeyport Module Developer
          It’s showing for me, @j-e-f-f
            @smotx Yeah coming through for me now too. Weird.
            OK from the top down:
            • The first two regions are actually spacing that accommodates the icon when it appears (It’s currently not appearing due to a bug I fixed today. Do a git pull to update the module and restart MM. You’ll see once the icon is in place, that the vertical space is better used. Keep in mind that the icons are square, and some of them only use a portion of the square. Nonetheless the square still takes up that amount of space. Here’s what it should look like:
            You can decrease the space under the header a bit with this:
            .MMM-DarkSkyForecast .module-header {
              margin-bottom: 5px; /* adjust to taste */
            Keep in mind this will also affect the header above the forecast if you have configured it to be there. That can be controlled independently as follows:
            .MMM-DarkSkyForecast .module-header.forecast-header {
              margin-bottom: 10px; /* adjust to taste */
            * the next one below the extra current conditions is margin above the summary.  Adjust it as follows:
            .MMM-DarkSkyForecast .summary {
            margin-top: 10px; /* adjust to taste */
            You can also affect the margin underneath the summary in a similar way:
            * The following four below are controlled by the line-height of the time and day displays:
            .MMM-DarkSkyForecast .wrapper.tiled .forecast-container .forecast-item .time,
            .MMM-DarkSkyForecast .wrapper.tiled .forecast-container .forecast-item .day-name {
            line-height: 20px; /* adjust to taste */
            Put all of the CSS changes in your `custom.css` file.  Don't make changes to `MMM-DarkSkyForecast.css` as they will be overwritten if you update the module to a newer version.
              Smotx @j.e.f.f
              @j-e-f-f
              Thx a lot
              it’s good now, it remains 2 spaces a little wide, but it does not exceed more on the next module, thank you again.
              J 1 Reply Last reply
                dan-o
                @j-e-f-f came home to see the icon working, which was strange. anyway, grabbed your recent update and it works great. thank you SO MUCH for your time on this :)
                D 1 Reply Last reply
                  dan-o @dan-o
                  @dan-o said in MMM-DarkSkyForecast - Yet ANOTHER weather module:
                  Looks like I spoke too soon :(. Was working after a restart. Walked by the mirror just now and no icon present.
                    @smotx you can control the width of the module in CSS. It defaults to 300px, but if you need it wider or narrower you can use this:
                    .MMM-DarkSkyForecast .module-content {
                      width: 250px; /* adjust this to taste */
                      j.e.f.f Project Sponsor Module Developer @dan-o
                      @dan-o hmmm… will look into this some more. For now, if you disable the animated icons you will at least get the static one reliably.
                        I left this running on my mirror overnight and my main icon disappeared at some point as well, but it was back this morning. I have a few theories as to why.
                        The way the animated icons work is that they get drawn real-time by JavaScript, which means I need to wait until the DOM update is finished before executing the draw command. I thought I had licked that with my last update but the combination of the Nunjucks templating system seems to be adding a latency I’m not accounting for.
                        Will continue working on this over the next couple of days. Turn off animated icons for now as a work around.
                        • A
                          Arjan Project Sponsor
                          Is it possible to disable the main icon via the config?
                          I’m running two configs of MMM-DarkSlyForecast next to each other. One with 9 hour forecast and the other one with 6 day forecast.
                          Because of this I have 2 main icons that are the same. See picture below.
                          Is it possible to disable one of them via the config?
                            j.e.f.f Project Sponsor Module Developer @Arjan
                            @arjan yes. Here are a few config options for you:
                            showCurrentConditions: false will turn off the main icon and the current temparature display (the two big items).
                            showExtraCurrentConditions: false will turn off the the additional current conditions immediately below the big icon and temperature.
                            This module is programmed it with this type of usage in mind, so it supports multiple instances to work independently. I do something similar on my kitchen display centre.
                            A 1 Reply Last reply
                            • A
                              Arjan Project Sponsor @j.e.f.f
                              @j-e-f-f Thanks. I overlooked that one.
                                @dan-o @Smotx I think I’ve licked the disappearing icon issue for good now. I tested a fix on my mirror for 24 hours, and the icon was visible every time I checked up on it. Please do a git pull in the MMM-DarkSkyForecast directory and restart MM. Let me know if it’s fixed.
                                  dan-o
                                  @j-e-f-f Pulled just now. Will let you know if I run into the issue again!
                                  Appreciate ya!
                                    Johans @j.e.f.f
                                    @j-e-f-f installed latest version of your nicely build weather forecast module, but now I see that my personal web player is not working anymore.
                                    All content is displayed on the mirror, but there is no reaction when I press a play button (seems play buttons are disabled)
                                    To show the player on my mirror I’ve abused the widget module.
                                    It shows me 6 radio stations and a selection button for MP3’s on the SD card of the raspberry. (All simple stuff – so far no rocket science)
                                    I’m sure problem is related towards the installation of your weather module, as I did a rebuild on another SD card to try -out.
                                    Removing and re-installing your module or the widget module was no solution so far.
                                    Started mirror in dev mode, but here also I don’t see any problem.
                                    As I read here that you updated this module to use the Nunjucks html templating system, I suspect it has a relation with my html code I’m using in the widget module.
                                    See below code in the config. Perhaps somebody can port this code according the Nunjucks html. (sound lick chinees for me  )
                                       		disabled: false,
                                       		module: "MMM-Widget",
                                          	        position: "middle_center",
                                        		pages: {"Page1": "lower_third"},
                                       		widgets: [
                                       	        { //insert your script or html codes here.
                                       	        html:`
                                                           <!-- TradingView Widget BEGIN -->
                                       		<html lang="en">
                                       		<head>
                                       		<title>JSTAL MIRROR PLAYER</title>
                                       		<meta charset="UTF-8">
                                       		<meta name="viewport" content="width=device-width, initial-scale=1">
                                       		<link rel="stylesheet" type="text/css" href="http://localhost:8080/modules/MyPlayer/css/styles.css">   <!-- page design -->
                                       	        <link rel="stylesheet" href="https://cdnjs.cloudflare.com/ajax/libs/font-awesome/4.7.0/css/font-awesome.min.css">
                                       		<script src="https://ajax.googleapis.com/ajax/libs/jquery/2.1.1/jquery.min.js"></script>  <!-- For audio play -->
                                       		<style>
                                       		</style>
                                       		</head>
                                       		<body>
                                       		<div class="header">
                                       		  <h1>Mirror Webradio / MP3 Player</h1>
                                       		</div>
                                       		<div class="row">
                                       		  <div class="main">
                                       		     <p>My Radio Stations</p>
                                       			 <img src="http://localhost:8080/modules/MyPlayer/images/JoeFM.jpg" style="width:5%;">
                                       			 <audio id="myAudio0" src="http://icecast-qmusic.cdp.triple-it.nl:80/JOEfm_be_live_128.mp3" preload="false" controls="true" volume="1.0"></audio>
                                       		     <script>   <!-- Script play pause toggle -->
                                       			 var myAudio0 = document.getElementById("myAudio0");
                                       				function togglePlay() {
                                       				return myAudio0.paused ? myAudio0.play() : myAudio0.pause();
                                       			 </script> <br>
                                       			 <img src="https://upload.wikimedia.org/wikipedia/commons/0/09/Qmusiclogo2015red.jpg" style="width:5%;">
                                       			 <audio id="myAudio1" src="http://icecast-qmusic.cdp.triple-it.nl:80/Qmusic_be_live_96.mp3" preload="false" controls="true" volume="1.0"></audio>
                                       			 var myAudio1 = document.getElementById("myAudio1");
                                       				return myAudio1.paused ? myAudio1.play() : myAudio1.stoppause();
                                       			 </script> <br>
                                       			 <img src="https://pbs.twimg.com/profile_images/1612540320/FAMILYRADIO_LOGO_WEB_400x400.jpg" style="width:5%;">
                                       			 <audio id="myAudio2" src="http://www.clubfmserver.be:8000/family.mp3" preload="false" controls="true" volume="1.0"></audio>
                                       			 var myAudio2 = document.getElementById("myAudio2");
                                       				return myAudio2.paused ? myAudio2.play() : myAudio2.pause();
                                       			 </script> <br>
                                       		    <img src="https://upload.wikimedia.org/wikipedia/commons/3/36/MNM_logo.png" style="width:5%;">
                                       			 <audio id="myAudio3" src="http://icecast.vrtcdn.be/mnm_hits-high.mp3" preload="false" controls="true" volume="1.0"></audio>
                                       			 var myAudio3 = document.getElementById("myAudio3");
                                       				return myAudio3.paused ? myAudio3.play() : myAudio3.pause();
                                       			 </script> <br>
                                       		     <img src="https://upload.wikimedia.org/wikipedia/commons/thumb/1/19/Radio_2_Logo.svg/1000px-Radio_2_Logo.svg.png" style="width:5%;">
                                       			 <audio id="myAudio4" src="http://icecast.vrtcdn.be/ra2ovl-high.mp3" preload="false" controls="true" volume="1.0"></audio>
                                       			 var myAudio4 = document.getElementById("myAudio4");
                                       				return myAudio4.paused ? myAudio4.play() : myAudio4.pause();
                                       			 </script> <br>
                                       		     <img src="https://pbs.twimg.com/profile_images/1476072724/Logo-alta-resolucao-MusicCityGame.jpg" style="width:5%;">
                                       			 <audio id="myAudio5" src="http://stream2.intronic.nl:80/citymusic" preload="false" controls="true" volume="1.0"></audio>
                                       			 var myAudio5 = document.getElementById("myAudio5");
                                       				return myAudio5.paused ? myAudio5.play() : myAudio5.pause();
                                       			 </script> <br>
                                       		        <hr><p>Select and Play MP3 from Local database folder </p>
                                       		        <input type="file" id="songs" multiple> <br> <br>
                                       			<i class="fa fa-music"></i>
                                       		        <audio controls id="myAudio" autoplay></audio>
                                       					var songs = document.getElementById("songs"),
                                       						myAudio = document.getElementById("myAudio");
                                       						function next(n){
                                       						  var url = URL.createObjectURL(files[n]);
                                       						  myAudio.setAttribute('src', url);
                                       						  myAudio.play();
                                       						var _next = 0,
                                       						files,
                                       						len;
                                       						songs.addEventListener('change', function() {
                                       						  files = songs.files;
                                       						  len = files.length;
                                       						  if(len){
                                       						next(_next);
                                       						myAudio.addEventListener("ended", function(){
                                       						   _next += 1;
                                       						   next(_next);
                                       						   console.log(len, _next);
                                       						   if((len-1)==_next){
                                       						 _next=-1;
                                       				 </script>
                                       		</body>
                                       		<!-- TradingView Widget END -->
                                                           `,    // Ends of Widget - important to set!
                                       	        width: "460px",
                                       	        height: "525px",
                                       	        backgroundColor: "#256d7b"   //"#FFF"
                                    For people interested here the CSS details as well.
                                    /* add here some separate css data */
                                    /* Style the body margin: 0  */
                                    body {
                                        font-family: Arial;
                                        margin: auto;
                                        width: 450px;
                                        height: 500px;
                                        border: 3px solid #256d7b;
                                    /* Header/logo Title  - color = #1abc9c/#008080  of #256d7b */
                                    .header {
                                        padding: 5px;
                                        text-align: center;
                                        background: #256d7b;
                                        color: white;
                                    /* Increase the font size of the heading */
                                    .header h1 {
                                        font-size: 20px;
                                    /* Main column   color = #fcfcfc or white */
                                    .main {
                                        -ms-flex: 60%; /* IE10 */
                                        flex: 60%;
                                        background-color: #fcfcfc;
                                        padding: 20px;
                                        text-align: center;
                                    /* Draw up a vertical line */
                                    hr.vertical
                                       width: 5px;
                                       height: 100%; /* or height in PX */
                                    .slider {
                                      position: absolute;
                                      cursor: pointer;
                                      top: 0;
                                      left: 0;
                                      right: 0;
                                      bottom: 0;
                                      background-color: #ca2222;
                                      -webkit-transition: .4s;
                                      transition: .4s;
                                       border-radius: 34px;
                                    .slider:before {
                                      position: absolute;
                                      content: "";
                                      height: 26px;
                                      width: 26px;
                                      left: 4px;
                                      bottom: 4px;
                                      background-color: white;
                                      transition: .4s;
                                      border-radius: 50%;
                                    input:checked + .slider {
                                      background-color: #2ab934;
                                    input:focus + .slider {
                                      box-shadow: 0 0 1px #2196F3;
                                    input:checked + .slider:before {
                                      -webkit-transform: translateX(26px);
                                      -ms-transform: translateX(26px);
                                      transform: translateX(55px);
                                    /*------ ADDED CSS ---------*/
                                    .slider:after
                                     content:'OFF';
                                     color: white;
                                     display: block;
                                     position: absolute;
                                     transform: translate(-50%,-50%);
                                     top: 50%;
                                     left: 50%;
                                     font-size: 10px;
                                     font-family: Verdana, sans-serif;
                                    input:checked + .slider:after
                                      content:'ON';
                                    Maybe there are other ways to embed my player on the mirror, but for now MMM-Widget was the only thing I found to do.
                                    Hope somebody can help me out.
                                    Thx.
                                    J J 2 Replies Last reply
                                      j.e.f.f Project Sponsor Module Developer @Johans
                                      @johans If you disable the MMM-DarkSkyForecast module do you get your web player functionality back?
                                        Johans @Johans
                                        @johans
                                        I’ll guess something went wrong when I paste the code
                                        			disabled: false,
                                        			widgets: [
                                        		        html:`
                                        			<html lang="en">
                                        			<head>
                                        			<style>
                                        			</style>
                                        			</head>
                                        			<body>
                                        			</div>
                                        			<div class="row">
                                        			  <div class="main">
                                        				 </script> <br>
                                        				 </script> <br>
                                        				 </script> <br>
                                        				 </script> <br>
                                        				 </script> <br>
                                        				 </script> <br>
                                        							function next(n){
                                        							  myAudio.play();
                                        							var _next = 0,
                                        							files,
                                        							len;
                                        							  len = files.length;
                                        							  if(len){
                                        							next(_next);
                                        							   _next += 1;
                                        							   next(_next);
                                        							   if((len-1)==_next){
                                        							 _next=-1;
                                        					 </script>
                                        			</body>
                                        		        width: "460px",
                                        		        height: "525px",
                                          Johans @j.e.f.f
                                          @j-e-f-f
                                          No, It doesn’t come back.
                                          I made a new installation on fresh SD card.
                                          All works fine without installing your module, after that it’s not working anymore.
                                            Johans @Johans
                                            When I run directly in the browser, it’s OK, but thats not the main goal, should run via the MagicMirror.
                                            • 16
                                            • 17
                                            • 4 / 17
