    Timer on Module
    22 Posts 4 Posters 8.1k Views 4 Watching
      A Former User
      job: function() {
        setInterval(()=>{
          this.updateDom() // this will execute your getDom()
        }, yourInterval)
      notificationReceived: function (noti, payload, sender) {
        if (noti == “DOM_OBJECT_CREATED”) this.job()
      getDom: function () {
        //making  your video DOM here.
      D 1 Reply Last reply
        dsmtweaker @Guest
        @sean Sorry for being so new at this. And thank you for all of the help. I tried using your code.
        get: function() {
        setInterval(()=>{this.updateDom()}, 60000)
        notificationRecieved: function (noti, payload, sender) {
        if (noti = “DOM_OBJECT_CREATED”) this.job()
        getDom: function ()
        			var video =  document.createElement("video");
        			video.src = this.config.videoSRC;
        			video.autoplay = true;
        			video.loop = this.config.loop;
        But I get “Uncaught SyntaxError: Unexpected token (” from notificationRecieved: function (noti, payload, sender) {
          sdetweil @dsmtweaker
          @dsmtweaker you missed some of the job function
          this.updateDom()
          }, yourInterval)
            dsmtweaker @sdetweil
            @sdetweil It is there in the get:function
             get: function() {setInterval(()=>{this.updateDom()}, 60000)
            		if (noti = "DOM_OBJECT_CREATED") this.job()
            getDom: fuction ()
              @dsmtweaker i hate code posting on this forum…
              note that
              getDom: fuction () is spelled wrong
              and also missing the open brace
                there are 3 routines (functions)… in seans post
                // worker function
                job: function() {
                  // start a recurring timer that will tell MM to get the module updated dom content
                  // this uses an inline function, be careful of braces and parens  matching
                  setInterval(()=>{
                    this.updateDom() // this will execute your getDom(), after 'yourInterval' time
                  }, yourInterval)
                // the function called when notifications are received from the system
                   // if the notification is "dom is created", then call our worker function
                // the function called for the module to provide its dom content
                  @sdetweil I made all the corrections noted.
                  but on if (noti == “DOM_OBJECT_CREATED”) this.job() I am still getting the error SyntaxError: Invalid or unexpected token
                  Mykle1M S 2 Replies Last reply
                  • Mykle1M
                    Mykle1 Project Sponsor Module Developer @dsmtweaker
                    @dsmtweaker said in Timer on Module:
                    Excuse me for jumping in but the curly quotes containing DOM_OBJECT_CREATED will cause that error. Try:
                    if (noti == "DOM_OBJECT_CREATED") this.job()
                    The difference is slight, but enough.
                      @dsmtweaker its the darned cut/paste of the double quotes… in the web posting it shows the MS word document style quotes which cause an error with the javascript parser…
                      overtype those double quotes with the text editor…
                        A Former User
                        I’m back. Sorry for my prior mistypo and unsufficient post. I was typing that on my phone.
                        start: function() {
                          this.timer = null
                          this.videoDom = null
                        getDom: function() {
                          var container =  document.createElement("div")
                          video.id = "VIDEO"
                          video.style.display = "none"
                          container.appendChild(video)
                          this.videoDom = video
                          return container
                        // Just create DOMs in getDom(). It's better to control DOMs outside of getDom().
                        notificationReceived: function(noti, payload, sender) {
                          if (noti == "DOM_OBJECT_CREATED") this.work()
                        //DOM_OBJECT_CREATED would be the best time to start your job. Your DOM would be created and be ready to work on that message.
                        work: function(src = null, interval = null) {
                          clearTimer(this.timer)
                          interval = (interval) ? interval : this.config.interval
                          src = (src) ? src : this.config.videoSRC
                          this.playVideo(src)
                          this.timer = setTimeout(()=>{
                            this.work()
                          }, interval)
                        //setTimeout is better than setInterval.
                        // you can repeat this function by interval. you can change interval and src with parameters of this function.
                        playVideo: function(src) {
                          this.videoDom.src = src
                          if (this.videoDom.style.display == "none") this.videoDom.style.display = "block"
                          this.videoDom.play()
                          // assign src to your videoDom and play it.
                        Not tested on real device, so maybe somthig is missed, but this is basic approach.
                        I didn’t use updateDom because there is no need to redraw whole module just for playing video.
                          dsmtweaker @Guest
                          @sean Thank you, and everyone else for all the help. It’s refreshing to find a forum that doesn’t automatically start bashing beginners.
                          I think my knowledge is just not ready for something this advanced yet. I used your code, and tried changes here and there to make it work, but still no luck. I am no longer getting any errors in the console. But nothing happens(ie- no video ever loads/plays) this is where I got the code so far…
                          Module.register(“MMM-htmlvideo”,{
                          // Default module config.
                          defaults: {
                          	videoSRC: 'https://www.mid-americantitle.com/wp-content/uploads/output_HD7205.mp4',
                          	loop: true,
                          // get stylesheet
                          getStyles: function() {
                          	return ["htmlvideo.css"];
                          start: function() {
                            this.timer = null
                          video.id = "VIDEO"
                           return container
                           interval = (interval) ? interval : 30000
                            this.playVideo(src)
                             this.work()
                            }, interval)
                          I tried changing “interval” with actual numbers, as well as changing the source in multiple locations. Still just get a black screen.
                          ? 1 Reply Last reply
                            A Former User @dsmtweaker
                            @dsmtweaker
                            Sorry there were another mistypes. DOM_OBJECT_CREATED => DOM_OBJECTS_CREATED (and clearTimer => clearTimeout)
                            use this. tested.
                            Module.register("test",{
                              defaults: {
                                loop: true,
                                interval: 36000,
                              start: function() {
                                this.timer = null
                                video.id = "VIDEO"
                                return container
                                if (noti == "DOM_OBJECTS_CREATED") this.work()
                                clearTimeout(this.timer)
                                this.playVideo(src)
                                  this.work()
                                }, interval)
                            Anyway, your video is already repeating by loop: true, why you need to repeat it with timer?
                            D 2 Replies Last reply
                              dsmtweaker @Guest
                              @sean You are a genius, thank you so much.
                              Extra bonus, do you know of anyway to use a local source, instead of a web source?
                              IE- videoSRC: “/home/pi/content/videos/video1.mp4”
                              It’s not necessary, I just figured running something locally instead of from the web
                              would help reduce lag/buffer/tearing etc.
                                dsmtweaker @Guest
                                @sean said in Timer on Module:
                                Because I don’t want it to loop. I want it to play in intervals. Like maybe every 15 minutes it runs the video(once)
                                  @dsmtweaker
                                  If your local content locates under MagicMirror and it’s sub directory, you can contact via http.
                                  ~/MagicMirror/YOUR_RESOURCE => http://localhost:8080/YOUR_RESOURCE
                                  ~/MagicMirror/modules/MMM-SOMETHING/SOMEWHERE/SOME => http://localhost:8080/modules/MMM-SOMETHING/SOMEWHERE/SOME
                                  But other location… hmmm I’m not sure whether symbolic_link would work. If not so, you need another approach. - more complex… just to move your content under MagicMirror would be simpler.
