    Timer on Module
    22 Posts 4 Posters 7.7k Views 4 Watching
      sdetweil @dsmtweaker
      @dsmtweaker you missed some of the job function
      this.updateDom()
      }, yourInterval)
        dsmtweaker @sdetweil
        @sdetweil It is there in the get:function
         get: function() {setInterval(()=>{this.updateDom()}, 60000)
        	notificationRecieved: function (noti, payload, sender) {
        		if (noti = "DOM_OBJECT_CREATED") this.job()
        getDom: fuction ()
        			var video =  document.createElement("video");
        			video.src = this.config.videoSRC;
        			video.autoplay = true;
        			video.loop = this.config.loop;
          @dsmtweaker i hate code posting on this forum…
          note that
          getDom: fuction () is spelled wrong
          and also missing the open brace
            there are 3 routines (functions)… in seans post
            // worker function
            job: function() {
              // start a recurring timer that will tell MM to get the module updated dom content
              // this uses an inline function, be careful of braces and parens  matching
              setInterval(()=>{
                this.updateDom() // this will execute your getDom(), after 'yourInterval' time
              }, yourInterval)
            // the function called when notifications are received from the system
            notificationReceived: function (noti, payload, sender) {
               // if the notification is "dom is created", then call our worker function
              if (noti == “DOM_OBJECT_CREATED”) this.job()
            // the function called for the module to provide its dom content
            getDom: function () {
              //making  your video DOM here.
              @sdetweil I made all the corrections noted.
              but on if (noti == “DOM_OBJECT_CREATED”) this.job() I am still getting the error SyntaxError: Invalid or unexpected token
              Mykle1M S 2 Replies Last reply Reply Quote 0
                Mykle1 Project Sponsor Module Developer @dsmtweaker
                @dsmtweaker said in Timer on Module:
                Excuse me for jumping in but the curly quotes containing DOM_OBJECT_CREATED will cause that error. Try:
                if (noti == "DOM_OBJECT_CREATED") this.job()
                The difference is slight, but enough.
                  @dsmtweaker its the darned cut/paste of the double quotes… in the web posting it shows the MS word document style quotes which cause an error with the javascript parser…
                  overtype those double quotes with the text editor…
                    A Former User
                    I’m back. Sorry for my prior mistypo and unsufficient post. I was typing that on my phone.
                    start: function() {
                      this.timer = null
                      this.videoDom = null
                    getDom: function() {
                      var container =  document.createElement("div")
                      video.id = "VIDEO"
                      video.style.display = "none"
                      container.appendChild(video)
                      this.videoDom = video
                      return container
                    // Just create DOMs in getDom(). It's better to control DOMs outside of getDom().
                    notificationReceived: function(noti, payload, sender) {
                      if (noti == "DOM_OBJECT_CREATED") this.work()
                    //DOM_OBJECT_CREATED would be the best time to start your job. Your DOM would be created and be ready to work on that message.
                    work: function(src = null, interval = null) {
                      clearTimer(this.timer)
                      interval = (interval) ? interval : this.config.interval
                      src = (src) ? src : this.config.videoSRC
                      this.playVideo(src)
                      this.timer = setTimeout(()=>{
                        this.work()
                      }, interval)
                    //setTimeout is better than setInterval.
                    // you can repeat this function by interval. you can change interval and src with parameters of this function.
                    playVideo: function(src) {
                      this.videoDom.src = src
                      if (this.videoDom.style.display == "none") this.videoDom.style.display = "block"
                      this.videoDom.play()
                      // assign src to your videoDom and play it.
                    Not tested on real device, so maybe somthig is missed, but this is basic approach.
                    I didn’t use updateDom because there is no need to redraw whole module just for playing video.
                      dsmtweaker @Guest
                      @sean Thank you, and everyone else for all the help. It’s refreshing to find a forum that doesn’t automatically start bashing beginners.
                      I think my knowledge is just not ready for something this advanced yet. I used your code, and tried changes here and there to make it work, but still no luck. I am no longer getting any errors in the console. But nothing happens(ie- no video ever loads/plays) this is where I got the code so far…
                      Module.register(“MMM-htmlvideo”,{
                      // Default module config.
                      defaults: {
                      	videoSRC: 'https://www.mid-americantitle.com/wp-content/uploads/output_HD7205.mp4',
                      	loop: true,
                      // get stylesheet
                      getStyles: function() {
                      	return ["htmlvideo.css"];
                      start: function() {
                        this.timer = null
                      video.id = "VIDEO"
                       return container
                       interval = (interval) ? interval : 30000
                        this.playVideo(src)
                         this.work()
                        }, interval)
                      I tried changing “interval” with actual numbers, as well as changing the source in multiple locations. Still just get a black screen.
                        A Former User @dsmtweaker
                        @dsmtweaker
                        Sorry there were another mistypes. DOM_OBJECT_CREATED => DOM_OBJECTS_CREATED (and clearTimer => clearTimeout)
                        use this. tested.
                        Module.register("test",{
                          defaults: {
                            loop: true,
                            interval: 36000,
                          start: function() {
                            this.timer = null
                            video.id = "VIDEO"
                            return container
                            if (noti == "DOM_OBJECTS_CREATED") this.work()
                            clearTimeout(this.timer)
                            this.playVideo(src)
                              this.work()
                            }, interval)
                        Anyway, your video is already repeating by loop: true, why you need to repeat it with timer?
                          dsmtweaker @Guest
                          @sean You are a genius, thank you so much.
                          Extra bonus, do you know of anyway to use a local source, instead of a web source?
                          IE- videoSRC: “/home/pi/content/videos/video1.mp4”
                          It’s not necessary, I just figured running something locally instead of from the web
                          would help reduce lag/buffer/tearing etc.
                            dsmtweaker @Guest
                            @sean said in Timer on Module:
                            Because I don’t want it to loop. I want it to play in intervals. Like maybe every 15 minutes it runs the video(once)
                              @dsmtweaker
                              If your local content locates under MagicMirror and it’s sub directory, you can contact via http.
                              ~/MagicMirror/YOUR_RESOURCE => http://localhost:8080/YOUR_RESOURCE
                              ~/MagicMirror/modules/MMM-SOMETHING/SOMEWHERE/SOME => http://localhost:8080/modules/MMM-SOMETHING/SOMEWHERE/SOME
                              But other location… hmmm I’m not sure whether symbolic_link would work. If not so, you need another approach. - more complex… just to move your content under MagicMirror would be simpler.
