    Installing MagicMirror2 on Ubuntu Mate 16.04 issue with electron
    8 Posts 4 Posters 5.5k Views 4 Watching
    • L
      lagoon7
      Having an install issue with electron on Ubuntu MATE 16.04 LTS. I have installed via the raspberry pi script 2 times but this error is different.
      I am installing this on a brand new raspberry pi 3.
      Can anyone help with the electron issue?
      > sh run-start.sh
      /home/neo/MagicMirror/node_modules/electron/index.js:9
        throw new Error('Electron failed to install correctly, please delete node_modules/electron and try installing again')
      Error: Electron failed to install correctly, please delete node_modules/electron and try installing again
          at Object. (/home/neo/MagicMirror/node_modules/electron/index.js:9:9)
          at Module._compile (module.js:570:32)
          at Object.Module._extensions..js (module.js:579:10)
          at Module.load (module.js:487:32)
          at tryModuleLoad (module.js:446:12)
          at Function.Module._load (module.js:438:3)
          at Module.require (module.js:497:17)
          at require (internal/module.js:20:19)
          at Object. (/home/neo/MagicMirror/node_modules/electron/cli.js:3:16)
      npm ERR! Linux 4.4.38-v7+
      npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "start"
      npm ERR! node v6.10.3
      npm ERR! npm  v3.10.10
      npm ERR! code ELIFECYCLE
      npm ERR! magicmirror@2.1.1 start: `sh run-start.sh`
      npm ERR! Exit status 1
      npm ERR!
      npm ERR! Failed at the magicmirror@2.1.1 start script 'sh run-start.sh'.
      npm ERR! If you do, this is most likely a problem with the magicmirror package,
      npm ERR! not with npm itself.
      npm ERR!     sh run-start.sh
      npm ERR!     npm bugs magicmirror
      npm ERR! Or if that isn't available, you can get their info via:
      npm ERR!     npm owner ls magicmirror
      bheplerB 1 Reply Last reply
      • bheplerB
        bhepler Module Developer @lagoon7
        @lagoon7 Yeah, for starters don’t use the script to install on a Raspberry Pi running Raspian Jessie to install on an Ubuntu operating system. The script only works on Raspberry Pi running the Raspian OS. You’ll want to follow the manual installation instructions (and be prepared to make some changes).
        1. Install Node & NPM.
        2. Install Electron.
        3. Install Git.
        4. Clone the MagicMirror repository to your home folder.
        I may have forgotten one or two steps from when I installed it on an Ubuntu Fitlet. At that point, it operates more-or-less like any other Magic Mirror installation.
        • L
          lagoon7
          Still coming up with a blank screen. However no messages from the console. I am using the sample config file as well.
          • bheplerB
            @lagoon7 Yeah, I knew I forgot a step.
            After you clone the MagicMirror repository to your home folder, you need to install all of the dependencies. Type cd ~/MagicMirror followed by npm install and wait for it to install all the extra stuff for the MagicMirror framework. Once it’s done, type npm start and it should take over your screen and show you the interface.
              maykesplana
              Hello all!
              I’m new to this forum.
              Looking for some information on how to install MagicMirror on a 32 bit Ubuntu (trying it on Ubuntu Mate) I saw someone installed it on a Pi.
              The question: Has anybody tried it on a 32Bit OS? Is the installation of MagicMirror still the same as 2 years ago?
              @lagoon7 did you get it working on Ubuntu Mate?
              cheers!
              Mykle1M 1 Reply Last reply
              • Mykle1M
                Mykle1 Project Sponsor Module Developer @maykesplana
                @maykesplana
                It has been a while since I installed MM on a 32bit version of ubuntu but it definitely will work. When you have ubuntu settled on your device you’ll have to do a manual installation of MM. The install script will only work for the Pi2 and Pi3
                Here is MM running on 32bit ubuntu with Hello Lucy
                https://www.youtube.com/watch?v=OjHeJd2avhw&feature=youtu.be
                  maykesplana @Mykle1
                  @mykle1
                  Thanks, I got it working on a NUC, (ubuntu 16.04.5) I’m now looking at adding modules to MM. While learning how to do that, I was overwhelmed with the information from Github :) .
                  The installation of MM was easy once I got my Ubuntu install working. This one is a 64Bit though. I have a device with Atom CPU in it and will try to install the 32Bit Ubuntu next time as it was unsuccessful try last night.
                  cheers!
                  • Mykle1M
                    @maykesplana said in Installing MagicMirror2 on Ubuntu Mate 16.04 issue with electron:
                    If that Atom CPU is 64bit then use the 64bit version of ubuntu. However, the 32bit version of ubuntu works quite well with MM. Have a look here. There’s a video link under the last picture. You can watch how well it works.
                    https://forum.magicmirror.builders/topic/6376/macmirror
