    Attach the monitor with glue to the mirror?
    12 Posts 6 Posters 11.6k Views 5 Watching
    • cowboysdudeC Offline
      cowboysdude Module Developer @Guest
      @pmauchle said in Attach the monitor with glue to the mirror?:
      My mirror is heavier than the monitor ;) But how should I attach the mirror to the monitor if the monitor is way smaller? Any ideas?
      Have someone make you a small frame out of hardwood … this is what I do … I’m not a programmer but I am a contractor so I can build…
      My frame is made out of mahogany and I love it… but what I’m suggesting is have someone take your total thickness and dado out U shaped channels to put around both…
        A Former User
        Yeah of course I can use a frame, but I don’t want a frame ;) I already have a mirror with a frame! I bought some strong glue and It works perfectly :)
        cowboysdudeC yawnsY 2 Replies Last reply Reply Quote 0
          @pmauchle Awesome! :)
          • yawnsY Offline
            yawns Moderator @Guest
            This thread is worthless without pics … ;)
            Or you could present it in the Show your mirror category
              cowboysdude Module Developer @yawns
              @yawns Pictures are always cool!
                amcolash
                One thing to note: I noticed that the mirror coating on my magic mirror is very delicate. I am not sure if other people have ordered from TAP Plastics.
                Adhesives seem dangerous as it could rip that backing of the foil-like mirror coating right off!
                • bheplerB Offline
                  bhepler Module Developer
                  I completed my box construction yesterday. My solution to the monitor-is-smaller-than-box problem was to build an internal bracing system using a couple of channels for the edge of the monitor. It sounds more complicated than it is.
                  Monitor braces:
                  Monitor braces
                  Everything in place:
                  Assembled
