    MMM-voice ugly hdmi banner
    Scheduled Pinned Locked Moved Feature Requests
    42 Posts 3 Posters 26.5k Views 3 Watching
      dazza120 @sdetweil
      @sdetweil i have followed it as best as i could i have the package installed and have located the motion folder in my user directory but for the life of me i cant find this motion.conf file to insert your script.
        motion config is done in /etc/motion/motion.conf
        i just added a line in the readme about that
          dazza120 @sdetweil
          @sdetweil thank you, i have located it with your help, ill work on this when im not at work thanks, so its just a case of adding one of your scripts? think ill just use the start one
            sdetweil @dazza120
            @dazza120 its just one script… external_motion… you pass it a parm, started or ended
            you need to configue both started and ended, else it can’t sleep thinking motion is still going on
            note that because it is in the /etc folder tree, you must use sudo in front of your editor to get write permission
              dazza120 @sdetweil
              @sdetweil motion.conf won’t let me edit it, or rather the pi won’t any way around this?
                sudo nano /etc/motion/motion.conf
                nano or whatever editor you choose…
                  also just noticed that the execute bit is not set on the script… SO
                  cd modules/MMM-SleepWake
                  chmod +x external_motion
                    dazza120 @sdetweil
                    @sdetweil so is it just this part i need to put on_event_start /home/pi/MagicMirror/modules/MMM-SleepWake/external_motion started
                      sdetweil @dazza120
                      @dazza120 correct… and right below it the same with ended as the parm for the motion ended notice
                        dazza120 @sdetweil
                        @sdetweil im leaving it with the ; in the command line?
                          sdetweil @dazza120
                          @dazza120 the example doesn’t have ;
                          on_event_start /home/{userid}/MagicMirror/modules/MMM-SleepWake/external_motion started
                            dazza120 @sdetweil
                            @sdetweil no it this is what its like i hope this is correct?
                            # Command to be executed when an event starts. (default: none)
                            # An event starts at first motion detected after a period of no motion defined $
                            ; on_event_start /home/pi/MagicMirror/modules/MMM-SleepWake/external_motion sta$
                            # Command to be executed when an event ends after a period of no motion
                            # (default: none). The period of no motion is defined by option event_gap.
                            ; on_event_end value /home/pi/MagicMirror/modules/MMM-SleepWake/external_motion$
                              ok, that ; is a comment in the motion conf file, just like #… have to remove it
                              note that the on event end has an extra token there that neds to be removed
                              on_event_end value
                                dazza120 @sdetweil
                                @sdetweil yes it is do i have to remove the # aswell?
                                  sdetweil @dazza120
                                  @dazza120 no, there is no # on those two lines
                                    dazza120 @sdetweil
                                    @sdetweil no on the two lines above it
                                      sdetweil @dazza120
                                      @dazza120 no, those are comments to explain what these lines do
                                        dazza120 @sdetweil
                                        @sdetweil ok cool so this is how i have it now
                                        # An event starts at first motion detected after a period of no motion defined by event_gap
                                         on_event_end /home/pi/MagicMirror/modules/MMM-SleepWake/external_motion ended
                                          sdetweil @dazza120
                                          @dazza120 looks good
                                            dazza120 @sdetweil
                                            @sdetweil thanks ive done this command chmod +x external_motion but i don’t see an outcome it just re turns to pi@raspberrypi:~/MagicMirror/modules/MMM-SleepWake
                                            whole commandline below
                                            pi@raspberrypi:~/MagicMirror/modules/MMM-SleepWake $ chmod +x external_motion
                                            • 2 / 3
